ES138KW
ES138KW
    ELECSUPER(静芯微)
    SOT-523-3
    类型:N沟道;漏源电压(Vdss):50V;连续漏极电流(Id):300mA;功率(Pd):300mW;导通电阻(RDS(on)@Vgs,Id):1.2Ω@10V,200mA;
ES138KW 数据手册
ES138KW Rev-1.1 www.elecsuper.com SuperMOS – SOT-523 60V BVDSS 1.5Ω RDS(on) 0.25A ID, N-channel MOSFET 1. Description The ES138KW is N-Channel enhancement MOS Field Effect Transistor. Uses advanced trench technology and design to provide excellent RDS(ON) with low gate charge. Device is suitable for use in DC-DC conversion, power switch and charging circuit. Standard Product ES138KW is Pb-free. 2. Features  60V, RDS(ON)=1.5Ω(Typ), VGS=10V  Material: Halogen free RDS(ON)=1.6Ω(Typ), VGS=4.5V  Reliable and rugged  Use trench MOSFET technology  Avalanche Rated  High density cell design for low RDS(on)  Low leakage current 3. Applications  PWM applications  Power management in portable/desktop PCs  Load switch  DC/DC conversion 4. Ordering Information Part Number Package ES138KW SOT-523 Material Packing Halogen Tape & free Reel Table-1 Quantity per Flammability reel Rating 3,000 PCS UL 94V-0 Reel Size 7 inches Ordering information 5. Pin Configuration and Functions Pin Function 1 Gate 2 Source 3 Drain Outline D 3 1 2 G S Table-2 Copyright© ElecSuper Incorporated Circuit Diagram Pin configuration Contact Us 1 / 7 ES138KW Rev-1.1 www.elecsuper.com 6. Specification Absolute Maximum Rating & Thermal Characteristics Ratings at 25 ℃ ambient temperature unless otherwise specified. Parameter Symbol Limit Unit Drain-Source Voltage BVDSS 60 V Gate-Source Voltage VGS ±20 V Continuous Drain Current ID 0.25 A Maximum Power Dissipation PD 150 mW Pulsed Drain Current a IDM 1.0 A Operating Junction Temperature TJ 150 °C Lead Temperature TL 260 °C Storage Temperature Range Tstg -55 to 150 °C Thermal resistance ratings Single Operation Parameter Junction-to-Ambient Thermal Resistance Symbol Typical Unit RθJA 833 °C/W Note: a: Repetitive rating, pulse width limited by junction temperature, tp=10μs, Duty Cycle=1% Copyright© ElecSuper Incorporated Contact Us 2 / 7 ES138KW Rev-1.1 www.elecsuper.com Electrical Characteristics At TA = 25℃ unless otherwise specified Parameter Symbol Test Conditions Min. Typ. Max. Unit OFF CHARACTERISTICS Drain-to-Source Breakdown Voltage BVDSS Zero Gate Voltage Drain Current IDSS Gate-to-source Leakage Current IGSS VGS=0V, ID=10mA 60 V VDS=60V, VGS=0V,TJ=25℃ 1.0 VDS=40V, VGS=0V, TJ=125℃ 100 VDS=0V, VGS=±20V ±10 uA 1.0 1.5 V VGS=10V, ID=0.5A 1.5 1.9 VGS=4.5V, ID=0.2A 1.6 2.5 VGS=2.5V, ID=0.1A 2.73 4.5 uA ON CHARACTERISTICS Gate Threshold Voltage VGS(TH) Drain-to-source On-resistance RDS(on) VGS=VDS, ID=250uA 0.8 Ω CHARGES, CAPACITANCES AND GATE RESISTANCE Input Capacitance CISS Output Capacitance COSS Reverse Transfer Capacitance Total Gate Charge 25 50 9.7 22 CRSS 2.2 5 QG(TOT) 0.65 1 Gate-to-Source Charge QGS Gate-to-Drain Charge QGD VGS=0V, f=1MHz, VDS =25V VGS=4.5V, VDS=25V, ID=0.25A 0.2 pF nC 0.23 SWITCHING CHARACTERISTICS Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time td(ON) tr td(OFF) VGS=10V, VDS=25V, ID=0.5A, RG=6Ω tf 2.3 5 19.2 40 6.3 12 23 50 ns BODY DIODE CHARACTERISTICS Forward Voltage Copyright© ElecSuper Incorporated VSD VGS=0V, IS=0.5A Contact Us 0.86 1.5 V 3 / 7 ES138KW 7. Rev-1.1 www.elecsuper.com Typical Characteristic Copyright© ElecSuper Incorporated Contact Us 4 / 7 ES138KW Copyright© ElecSuper Incorporated Rev-1.1 Contact Us www.elecsuper.com 5 / 7 ES138KW Rev-1.1 www.elecsuper.com 8. Dimension and Patterns (SOT-523) Dimensions in Millimeters Symbol Min. Max. Symbol Min. Max. A 0.700 0.900 e1 0.900 1.100 A1 0.00 0.100 e 0.500TYP A2 0.700 0.800 L 0.400REF b1 0.150 0.250 L1 0.260 0.460 b2 0.250 0.350 θ 0° 8° c 0.100 0.200 D 1.500 1.700 E 0.700 0.900 E1 1.450 1.750 Table-5 Product dimensions Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only Copyright© ElecSuper Incorporated Contact Us 6 / 7 ES138KW Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 7 / 7
ES138KW 价格&库存
很抱歉,暂时无法提供与“ES138KW”相匹配的价格&库存,您可以联系我们找货
ES138KW
