ESD05V32D-LC-ES
ESD05V32D-LC-ES
    ELECSUPER(静芯微)
    SOD-323
    GBLC系列AC印字,单路双向ESD静电防护器件,30KV,CJ:0.8PF;RJ45千兆网口高速通讯防护
ESD05V32D-LC-ES 数据手册
ESD05V32D-LC Rev-1.1 www.elecsuper.com SuperESD - ESD05V32D-LC 1. Description The ESD05V32D-LC is Transient Voltage Suppressor that designed to protect components which are connected to data and transmission lines against electrostatic discharge (ESD), electrical fast transient (EFT), and lightning. All pins are rated to withstand 25kV ESD pulses using the IEC61000-4-2 air discharge method. 2. Features  IEC 61000-4-2 Level 4 ESD Protection  Working voltage: 5.0V - ±25kV Contact Discharge  Low leakage current - ±25kV Air Discharge  RoHS compliant  300W Peak pulse Power (8/20us)  Protecting one bi-directional lines  Low clamping voltage  Junction capacitance: 0.8pF Typ. 3. Applications  Control & monitoring systems  Set-top box  Portable electronics  Communication systems  Servers, notebooks, and desktop PCs 4. Ordering Information Part Number Package Marking Material Packing ESD05V32D-LC SOD-323 AC Halogen free Tape & Reel Table-1 Copyright© ElecSuper Incorporated Quantity per reel 3,000 PCS Flammability Rating Reel Size UL 94V-0 7 inches Ordering information Contact Us 1 / 7 ESD05V32D-LC Rev-1.1 www.elecsuper.com 5. Pin Configuration and Functions Pin Name Description 1 IO1 Connect to IO 2 IO2 Outline 1 Connect to IO Table-2 Circuit Diagram AC 2 2 1 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 300 W Peak pulse current (tp=8/20us)@25℃ IPP 15 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±25 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±25 kV TJ - 150 ℃ Operating temperature TOP -40 125 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 7 ESD05V32D-LC Rev-1.1 www.elecsuper.com 6.2. Electrical Characteristics At TA = 25℃ unless otherwise noted Parameter Symbol Conditions Reverse Stand-off Voltage Min. Typ. VRWM Reverse Breakdown Voltage VBR IT=1mA Max. Units 5.0 V 6.5 V Reverse Leakage Current IR VRWM=5.0V 1 uA Clamping Voltage VC IPP=1A; tp=8/20us 8 V Clamping Voltage VC IPP=15A; tp=8/20us 20 V Junction Capacitance CJ I/O to GND; VR=0V; f=1MHz 0.8 pF Table-4 Electrical Characteristics Symbol VRWM IR VBR Parameters Peak Reverse Working Voltage Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP Copyright© ElecSuper Incorporated Contact Us 3 / 7 ESD05V32D-LC Rev-1.1 www.elecsuper.com 7. Typical Characteristic 8. Typical Application Typical Interface Application Copyright© ElecSuper Incorporated Contact Us 4 / 7 ESD05V32D-LC Rev-1.1 www.elecsuper.com 9. Dimension E A b D A1 E1 A2 θ C L Symbol A A1 A2 b C D E E1 L L1 θ L1 SOD-323 Dimensions in Millimeters Min. Max. 1.000 0.000 0.100 0.800 0.900 0.250 0.350 0.080 0.150 1.200 1.400 1.600 1.800 2.550 2.750 0.475REF 0.250 0.400 0° 8° Table-6 Copyright© ElecSuper Incorporated Dimensions in Inches Min. Max. 0.039 0.000 0.004 0.031 0.035 0.010 0.014 0.003 0.006 0.047 0.055 0.063 0.071 0.100 0.108 0.019REF 0.010 0.016 0° 8° product dimensions Contact Us 5 / 7 ESD05V32D-LC Rev-1.1 www.elecsuper.com 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only 4. Unit: mm Copyright© ElecSuper Incorporated Contact Us 6 / 7 ESD05V32D-LC Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 7 / 7
ESD05V32D-LC-ES 价格&库存
很抱歉,暂时无法提供与“ESD05V32D-LC-ES”相匹配的价格&库存,您可以联系我们找货
ESD05V32D-LC-ES
  • 1+0.26385
  • 10+0.20823
  • 30+0.17723
  • 100+0.15876
  • 500+0.14267
  • 1000+0.13392
库存:3881
