ESN7401
ESN7401
    ELECSUPER(静芯微)
    PDFN-8(3x3)
    1个N沟道 耐压:30V 电流:31A
ESN7401 数据手册
ESN7401 Rev-1.1 www.elecsuper.com SuperMOS - PDFN3X3-8L -30V BVDSS,13mΩ RDS(on), -31A ID P-channel MOSFET 1. Description The ESN7401 is P-Channel enhancement MOS Field Effect Transistor. Uses advanced trench technology and design to provide excellent RDS(ON) with low gate charge. Device is suitable for use in DC-DC conversion, power switch and charging circuit. Standard Product ESN7401 is Pb-free. 2. Features ⚫ -30V, RDS(ON)=13 mΩ(Typ), VGS=-10V ⚫ Material: Halogen free RDS(ON)=17mΩ(Typ), VGS=-4.5V ⚫ Reliable and rugged ⚫ Fast Switching ⚫ Avalanche Rated ⚫ High density cell design for low RDS(on) ⚫ Low leakage current 3. Applications ⚫ PWM applications ⚫ Power management in portable/desktop PCs ⚫ Load switch ⚫ DC/DC conversion 4. Ordering Information Part Number Package Marking Material Quantity per reel Flammability Rating ESN7401 PDFN3X3-8L .ESN7401/LOT Halogen free 5,000 PCS UL 94V-0 5. Pin Configuration and Functions Pin Function 4 Gate 8 7 6 5 1/2/3 Source ESN7401/LOT 5/6/7/8 Drain Copyright© ElecSuper Incorporated Outline 1 2 3 Circuit Diagram 4 Contact Us 1 / 7 ESN7401 Rev-1.1 www.elecsuper.com 6. Specification Absolute Maximum Rating & Thermal Characteristics Ratings at 25 ℃ ambient temperature unless otherwise specified. Symbol Limit Unit Drain-Source Voltage BVDSS -30 V Gate-Source Voltage VGS ±25 V Parameter TC=25°C Continuous Drain Current TC=75°C -31 ID A -24 TC=25°C Maximum Power Dissipation TC=75°C 30 PD W 18 Pulsed Drain Current a IDM -124 A Operating Junction Temperature TJ 150 °C Storage Temperature Range Tstg -55 to +150 °C Thermal resistance ratings Single Operation Parameter Symbol Typical t ≤ 10 s RθJA 40 Steady State RθJC 4.2 Junction-to-Ambient Thermal Resistance Junction-to-Case Thermal Resistance Unit °C/W Note: a: Repetitive rating, pulse width limited by junction temperature, tp=10μs, Duty Cycle=1% Copyright© ElecSuper Incorporated Contact Us 2 / 7 ESN7401 Rev-1.1 www.elecsuper.com Electrical Characteristics At TA = 25℃ unless otherwise specified Parameter Symbol Test Conditions Min. Typ. Max. Unit OFF CHARACTERISTICS Drain-to-Source Breakdown Voltage BVDSS VGS=0V, ID=-250uA -30 V Zero Gate Voltage Drain Current IDSS VGS=0V, VDS=-30V -1 uA Gate-to-source Leakage Current IGSS VGS=±25V, VDS=0V ±100 nA -1.5 -2.0 V VGS=-10V, ID=-8A 13 20 VGS=-4.5V, ID=-7A 17 27 ON CHARACTERISTICS Gate Threshold Voltage VGS(TH) Drain-to-source On-resistance RDS(on) VGS=VDS, ID=-250uA -1.0 mΩ CHARGES, CAPACITANCES AND GATE RESISTANCE Input Capacitance CISS Output Capacitance COSS Reverse Transfer Capacitance CRSS Total Gate Charge QG(TOT) Gate-to-Source Charge QGS Gate-to-Drain Charge QGD VGS=0V VDS =-15V f=1MHz VGS=-10V VDS=-15V ID =-10A 1230 160 pF 145 26.4 6 nC 4.3 SWITCHING CHARACTERISTICS Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time td(ON) tr td(OFF) tf VGS=-10V VDS=-15V RL=1Ω RG=3Ω 18 22 ns 55 42 BODY DIODE CHARACTERISTICS Forward Voltage Copyright© ElecSuper Incorporated VSD VGS=0V, ISD=-10A Contact Us -1.2 V 3 / 7 ESN7401 7. Rev-1.1 www.elecsuper.com Typical Characteristic Copyright© ElecSuper Incorporated Contact Us 4 / 7 ESN7401 Copyright© ElecSuper Incorporated Rev-1.1 Contact Us www.elecsuper.com 5 / 7 ESN7401 Rev-1.1 www.elecsuper.com D L1 H 8. Dimension (PDFN3X3-8L) b E2 L E E1 D1 L3 L2 e A2 A1 A θ Unit: mm COMMON DIMENSIONS: UNITS OF MEASURE=MILLIMETER MILLIMETER MILLIMETER SYMBOL A SYMBOL MIN Typ. MAX 0.700 0.800 0.900 MIN Typ. MAX b 0.200 0.300 0.400 A1 0.152 REF. e 0.550 0.650 0.750 A2 0~0.05 L 0.300 0.400 0.500 0.180 0.330 0.480 D 3.000 3.100 3.200 L1 D1 2.300 2.450 2.600 L2 0~0.100 E 2.900 3.000 3.100 L3 0~0.100 E1 3.150 3.300 3.450 H 0.315 0.415 0.515 E2 1.320 1.520 1.720 θ 8° 10° 12° Table-5 Copyright© ElecSuper Incorporated Product dimensions in millimeter Contact Us 6 / 7 ESN7401 Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 7 / 7
ESN7401 价格&库存
很抱歉,暂时无法提供与“ESN7401”相匹配的价格&库存,您可以联系我们找货
