CESD5V0K5-ES
CESD5V0K5-ES
    ELECSUPER(静芯微)
    SOT-363
    5路单向ESD静电防护器件,30KV,CJ:100PF;笔记本/SIM卡/数码相机/仪器仪表多路防护
CESD5V0K5-ES 数据手册
CESD5V0K5 Rev-1.1 www.elecsuper.com SuperESD - CESD5V0K5 1. Description The CESD5V0K5 is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. 2. Features ⚫ IEC 61000-4-2 Level 4 ESD Protection ⚫ Working voltage: 5V - ±12kV Contact Discharge ⚫ Low leakage current - ±17kV Air Discharge ⚫ RoHS compliant ⚫ 100W Peak pulse Power (8/20us) ⚫ Protecting 5 unidirectional lines ⚫ Low clamping voltage ⚫ Capacitance: 100pF Typ. 3. Applications ⚫ Cellular Handsets and Accessories ⚫ Notebooks & Handhelds ⚫ Cordless Phones ⚫ Digital Cameras ⚫ Personal Digital Assistants (PDA’s) ⚫ Portable Instrumentation 4. Ordering Information Part Number CESD5V0K5 Package Marking SOT363 .5C Material Packing Halogen free Tape & Reel Table-1 Quantity per reel 3,000 PCS Flammability Rating Reel Size UL 94V-0 7 inches Ordering information 5. Pin Configuration and Functions Copyright© ElecSuper Incorporated Contact Us 1 / 7 CESD5V0K5 Rev-1.1 Pin Name Description 1 IO1 Connect to I/O 2 GND Connect to GND 3 IO2 Connect to I/O 4 IO3 Connect to I/O 5 IO4 Connect to I/O 6 IO5 Connect to I/O www.elecsuper.com Outline 6 5 Circuit Diagram 4 6 5 4 1 2 3 5C 1 Table-2 2 3 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 100 W Peak pulse current (tp=8/20us)@25℃ IPP 8 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±17 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±12 kV TJ - 150 ℃ Operating temperature TOP -40 125 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Absolute Maximum rating 6.2. Electrical Characteristics Copyright© ElecSuper Incorporated Contact Us 2 / 7 CESD5V0K5 Rev-1.1 www.elecsuper.com At TA = 25℃ unless otherwise noted Parameter Symbol Conditions Reverse Stand-off Voltage Reverse Breakdown Voltage Min. Typ. VRWM Max. Units 5 V VBR IT=1mA Reverse Leakage Current IR VRWM=5V Clamping Voltage VC IPP=1A; tp=8/20us 9.5 V Clamping Voltage VC IPP=8A; tp=8/20us 15 V Junction Capacitance CJ I/O to GND; VR=0V; f=1MHz 100 pF Table-4 Symbol VRWM IR VBR 6 V 1 uA Electrical Characteristics Parameters Peak Reverse Working Voltage Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP IF Forward Current VF Forward Voltage @ IF 7. Typical Characteristic Copyright© ElecSuper Incorporated Contact Us 3 / 7 CESD5V0K5 Rev-1.1 www.elecsuper.com 8. Typical Application Typical Interface Application Copyright© ElecSuper Incorporated Contact Us 4 / 7 CESD5V0K5 Rev-1.1 www.elecsuper.com 9. Dimension SOT-363 Unit: mm Symbol Min Spec Max Symbol Min Spec Max A 0.900 1.100 E 1.150 1.350 A1 0.000 0.100 E1 2.150 2.450 Table-5 Copyright© ElecSuper Incorporated A2 0.900 1.000 e 0.650 REF b 0.150 0.350 e1 1.200 1.400 c 0.080 0.150 L 0.525 REF D 2.000 2.200 L1 0.2600 0.4600 θ 0° 8° - Product dimensions in millimeter Contact Us 5 / 7 CESD5V0K5 Rev-1.1 www.elecsuper.com 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only Copyright© ElecSuper Incorporated Contact Us 6 / 7 CESD5V0K5 Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 7 / 7
CESD5V0K5-ES 价格&库存
很抱歉,暂时无法提供与“CESD5V0K5-ES”相匹配的价格&库存,您可以联系我们找货
