CESDXXD5
Rev-1.1
www.elecsuper.com
SuperESD – CESDXXD5
1. Description
The CESDXXD5 is a Transient Voltage Suppressor that designed to protect components which are
connected to data and transmission lines against electrostatic discharge (ESD), electrical fast
Transients (EFT), and lightning. All pins are rated to withstand 30kV ESD pulses using the
IEC61000-4-2 air discharge methods.
2. Features
IEC 61000-4-2 Level 4 ESD Protection
Unidirectional configuration
±30kV Contact Discharge
Low clamping voltage
±30kV Air Discharge
Low leakage current
Protects one power or I/O
250W Peak pulse Power (8/20us)
RoHS compliance
3. Applications
Portable electronics
Set-top box
Control & monitoring systems
Communication systems
Servers, notebooks, and desktop PCs
Digital cameras
4. Ordering Information
Part Number
Package
Material
Packing
Quantity
per reel
Flammability
Rating
Reel Size
CESDXXD5
SOD523
Halogen
Tape & Reel
3000 PCS
UL 94V-0
7 inches
Table-1
Copyright© ElecSuper Incorporated
Ordering information
Contact Us
1 / 6
CESDXXD5
Rev-1.1
www.elecsuper.com
5. Pin Configuration and Functions
Pin
Name
Description
1
IO
Connect to IO
Outline
1
2
GND
Circuit Diagram
Marking 2
1
2
Connect to GND
Table-2
Pin configuration
6. Specification
6.1. Absolute Maximum rating
Over operating free-air temperature range (unless otherwise noted)
Parameters
Symbol
Min.
Max.
Unit
Peak pulse power (tp=8/20us)@25℃
Ppk
250
W
Peak pulse current (tp=8/20us)@25℃
IPP
ESD (IEC61000-4-2 air discharge) @25℃
VESD
±30
kV
ESD (IEC61000-4-2 contact discharge) @25℃
VESD
±30
kV
TJ
150
Operating temperature
TOP
-40
125
Storage temperature
TSTG
-55
150
TL
260
Junction temperature
Lead temperature
Table-3
Refer to
Table-5
A
Contact Us
2 / 6
CESDXXD5
Rev-1.1
www.elecsuper.com
6.2. Electrical Characteristics
Symbol
Description
VRWM
Rated reverse stand-off voltage
VBR
Minimum breakdown voltage @IT = 1mA
VCL
Typical Clamping voltage
IPP
Maximum peak pulse current
IR
Reverse leakage current @VRWM
CO
Typical line capacitance (VIO=0V, VP-P = 30mV, f = 1MHz)
Table-4
Parameters Description
At TA = 25℃ unless otherwise noted
VRWM
VBR
VCL@I=1A
IPP
VCL@I=IPP
IR
CO
(V)
(V)
(V)
(A)
(V)
(uA)
(pF)
CESD3V3D5
3.3
4.5
8.5
16.0
18.0
1.0
200
CESD5V0D5
5.0
6.5
9.5
15.0
20.0
1.0
180
CESD12VD5
12.0
13.3
20.0
8.0
35.0
1.0
100
CESD15VD5
15.0
16.5
25.0
6.0
45.0
1.0
60
CESD24VD5
24.0
26.0
40.0
4.0
55.0
1.0
40
Part Number
Table-5
Electrical Characteristics for All Series
Contact Us
3 / 6
CESDXXD5
Rev-1.1
www.elecsuper.com
7. Typical Characteristic
8. Typical Application
Pic-3
Typical Internet 1G Interface Application
Contact Us
4 / 6
CESDXXD5
Rev-1.1
www.elecsuper.com
9. Dimension
SOD-523
Units: Millimeters
Unit
Max.
Min.
A
0.77
0.51
A1
0.70
0.50
b
0.35
0.25
c
0.15
0.08
D
0.125
0.75
E
1.30
1.10
Table-6
product dimensions
E1
1.70
1.50
E2
0.20
REF.
L
0.07
0.01
θ
7°
REF.
10. Recommended Land Pattern
Note:
1. Controlling dimension: in millimeters
2. General tolerance: ±0.05mm
Contact Us
5 / 6
CESDXXD5
Rev-1.1
www.elecsuper.com
3. The pad layout is for reference only
DISCLAIMER
ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES
(INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND
OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED,
INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR
PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS.
These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for
(1) selecting the appropriate ElecSuper products for your application;
(2) designing, validating and testing your application;
(3) ensuring your application meets applicable standards, and any other safety, security, or other requirements.
These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for
development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of
these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party
intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives
against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are
provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in
conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter
ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products.
Contact Us
6 / 6
很抱歉,暂时无法提供与“CESD24VD5-ES”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.18350
- 200+0.15142
- 600+0.13360
- 3000+0.11837
- 9000+0.10908
- 21000+0.10401
