ESD9L5.0ST5G
Rev-1.1
www.elecsuper.com
SuperESD - ESD9L5.0ST5G
1. Description
The ESD9L5.0ST5G is designed to protect voltage sensitive components from damage or latch-up
due to ESD. Excellent clamping capability, low leakage, and fast response time provide best in class
protection on designs that are exposed to ESD for board level. Because of its small size and
bi-directional design, it is ideal for use in cellular phones, MP3 players, and portable applications that
require audio line protection.
2. Features
IEC 61000-4-2 Level 4 ESD Protection
Working voltage: 5V
±15kV Contact Discharge
Low leakage current
±15kV Air Discharge
RoHS compliant
Protecting one Uni-directional lines
45W Peak pulse Power (8/20us)
Low clamping voltage
3. Applications
Cellular handsets and accessories
Digital cameras
Portable digital assistants
MP3 players
Notebooks & handhelds
Peripherals
4. Ordering Information
Part Number
Package
Marking
Material
Packing
ESD9L5.0ST5G
SOD-923
|DT
Halogen
free
Tape &
Reel
Table-1
Copyright© ElecSuper Incorporated
Quantity
per reel
8,000
PCS
Flammability
Rating
Reel
Size
UL 94V-0
7 inches
Ordering information
Contact Us
1 / 7
ESD9L5.0ST5G
Rev-1.1
www.elecsuper.com
5. Pin Configuration and Functions
Name
Description
Outline
1
IO1
Connect to IO
D
1
2
GND
T
Pin
Circuit Diagram
1
2
2
Connect to GND
Table-2
Pin configuration
6. Specification
6.1. Absolute Maximum rating
Over operating free-air temperature range (unless otherwise noted)
Parameters
Symbol
Min.
Max.
Unit
Peak pulse power (tp=8/20us)@25℃
Ppk
45
W
Peak pulse current (tp=8/20us)@25℃
IPP
4
A
ESD (IEC61000-4-2 air discharge) @25℃
VESD
±15
kV
ESD (IEC61000-4-2 contact discharge) @25℃
VESD
±15
kV
TJ
125
Operating temperature
TOP
-40
125
Storage temperature
TSTG
-55
150
TL
260
Junction temperature
Lead temperature
Table-3
Contact Us
2 / 7
ESD9L5.0ST5G
Rev-1.1
www.elecsuper.com
6.2. Electrical Characteristics
At TA = 25℃ unless otherwise noted
Parameter
Symbol Conditions
Reverse Stand-off Voltage
Min.
Typ.
VRWM
Reverse Breakdown Voltage
Max.
Units
5
V
VBR
IT=1mA
6
V
Reverse Leakage Current
IR
VRWM=5V
Clamping Voltage
VC
IPP=1A; tp=8/20us
8
V
Clamping Voltage
VC
IPP=4A; tp=8/20us
12
V
Junction Capacitance
CJ
I/O to GND; VR=0V; f=1MHz
0.5
pF
1
uA
Table-4 Electrical Characteristics
Symbol
VRWM
IR
VBR
Parameters
Peak Reverse Working Voltage
Reverse Leakage Current @ VRWM
Breakdown Voltage @ IT
IT
Test Current
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
IF
Forward Current
VF
Forward Voltage @ IF
Contact Us
3 / 7
ESD9L5.0ST5G
Rev-1.1
www.elecsuper.com
7. Typical Characteristic
8. Typical Application
Typical Interface Application
Contact Us
4 / 7
ESD9L5.0ST5G
Rev-1.1
www.elecsuper.com
9. Dimension
SOD-923
Unit
Max.
Min.
A
0.38
0.30
A1
0.28
0.20
b
0.27
0.17
c
0.15
0.08
Table-5
D
0.65
0.55
E
0.85
0.75
E1
1.10
0.90
E2
0.15
REF.
L
0.05
0.01
θ
7°
REF.
Product dimensions in millimeter
Contact Us
5 / 7
ESD9L5.0ST5G
Rev-1.1
www.elecsuper.com
10. Recommended Land Pattern
Note:
1. Controlling dimension: in millimeters
2. General tolerance: ±0.05mm
3. The pad layout is for reference only
4. Unit: mm
DISCLAIMER
Contact Us
6 / 7
ESD9L5.0ST5G
Rev-1.1
www.elecsuper.com
ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES
(INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND
OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED,
INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR
PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS.
These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for
(1) selecting the appropriate ElecSuper products for your application;
(2) designing, validating and testing your application;
(3) ensuring your application meets applicable standards, and any other safety, security, or other requirements.
These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for
development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of
these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party
intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives
against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are
provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in
conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter
ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products.
Contact Us
7 / 7
很抱歉,暂时无法提供与“ESD9L5.0ST5G-ES”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.09390
- 8000+0.07680
- 国内价格
- 5+0.17075
- 50+0.13868
- 150+0.12086
- 500+0.11016
- 2500+0.10098
- 5000+0.09591
