ESD5Z3V3-ES
ESD5Z3V3-ES
    ELECSUPER(静芯微)
    SOD-523(SC-79)
    反向关断电压(典型值):3.3V(MAX) 击穿电压(最小值):4.5V 箝位电压:18V 峰值脉冲电流:16A (8/20US) 极性:UNIDIRECTIONAL
ESD5Z3V3-ES 数据手册
ESD5Z3V3 Rev-1.1 www.elecsuper.com SuperESD – ESD5Z3V3 1. Description The ESD5Z3V3 is a Transient Voltage Suppressor that designed to protect components which are connected to data and transmission lines against electrostatic discharge (ESD), electrical fast Transients (EFT), and lightning. All pins are rated to withstand 30kV ESD pulses using the IEC610004-2 air discharge methods. 2. Features ⚫ IEC 61000-4-2 Level 4 ESD Protection ⚫ Unidirectional configuration - ±30kV Contact Discharge ⚫ Low clamping voltage - ±30kV Air Discharge ⚫ Low leakage current ⚫ Protects one power or I/O ⚫ 250W Peak pulse Power (8/20us) ⚫ RoHS compliance 3. Applications ⚫ Portable electronics ⚫ Set-top box ⚫ Control & monitoring systems ⚫ Communication systems ⚫ Servers, notebooks, and desktop PCs ⚫ Digital cameras 4. Ordering Information Part Number Package Marking Material Packing Quantity per reel ESD5Z3V3 SOD523 ||||N1 Halogen Tape & 3000 PCS Flammability Reel Size Rating UL 94V-0 7 inches Table-1 information free OrderingReel Copyright© ElecSuper Incorporated Contact Us 1 / 6 ESD5Z3V3 Rev-1.1 www.elecsuper.com 5. Pin Configuration and Functions Pin Name Description 1 IO Connect to IO Outline 1 2 GND Marking Circuit Diagram 2 1 2 Connect to GND Table-2 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 250 W Peak pulse current (tp=8/20us)@25℃ IPP - ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±30 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±30 kV TJ - 150 ℃ Operating temperature TOP -40 125 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Refer to Table-5 A Absolute Maximum rating Contact Us 2 / 6 ESD5Z3V3 Rev-1.1 www.elecsuper.com 6.2. Electrical Characteristics Symbol Description VRWM Rated reverse stand-off voltage VBR Minimum breakdown voltage @IT = 1mA VCL Typical Clamping voltage IPP Maximum peak pulse current IR Reverse leakage current @VRWM CO Typical line capacitance (VIO=0V, VP-P = 30mV, f = 1MHz) Table-4 Parameters Description At TA = 25℃ unless otherwise noted VRWM VBR VCL@I=1A IPP VCL@I=IPP IR CO (V) (V) (V) (A) (V) (uA) (pF) 3.3 4.5 8.5 16.0 18.0 1.0 200 Part Number ESD5Z3V3 Table-5 Electrical Characteristics for All Series 7. Typical Characteristic Copyright© ElecSuper Incorporated Contact Us 3 / 6 ESD5Z3V3 Rev-1.1 www.elecsuper.com 8. Typical Application Pic-3 Copyright© ElecSuper Incorporated Typical Internet 1G Interface Application Contact Us 4 / 6 ESD5Z3V3 Rev-1.1 www.elecsuper.com 9. Dimension SOD-523 Units: Millimeters Unit Max. Min. A 0.77 0.51 A1 0.70 0.50 b 0.35 0.25 c 0.15 0.08 Table-6 D 0.125 0.75 E 1.30 1.10 E1 1.70 1.50 E2 0.20 REF. L 0.07 0.01 θ 7° REF. product dimensions 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only Copyright© ElecSuper Incorporated Contact Us 5 / 6 ESD5Z3V3 Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 6 / 6
ESD5Z3V3-ES 价格&库存
很抱歉,暂时无法提供与“ESD5Z3V3-ES”相匹配的价格&库存,您可以联系我们找货
ESD5Z3V3-ES
  • 20+0.10271
  • 200+0.08932
  • 600+0.08187
  • 3000+0.07193
  • 9000+0.06804
  • 21000+0.06599
库存:2576
