ES5ACG
ES5ACG
    SK(台湾时科)
    SMC(DO-214AB)
    二极管配置:独立式;直流反向耐压(Vr):50V;平均整流电流(Io):5A;正向压降(Vf):1V@5A;反向电流(Ir):5uA@50V;反向恢复时间(trr):35ns;工作温度:-55℃~+1...
ES5ACG 数据手册
ES5ACG THRU ES5JCG Surface Mount Superfast Recovery Rectifier Reverse Voltage – 50 to 600 V Forward Current –5 A PINNING PIN FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Superfast reverse recovery time • Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 2 1 MECHANICAL DATA • Case : SMC • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight : 0.22g / 0.0077oz Top View Marking Code: ES5A~ES5J Simplified outline SMC and symbol Absolute Maximum Ratings and Characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20%. Symbols Parameter ES5AC ES5BC ES5CC G G G ES5DC G ES5EC ES5GC G G ES5JC G Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 150 200 300 400 600 V Maximum RMS voltage V RMS 35 70 105 140 210 280 420 V Maximum DC Blocking Voltage V DC 50 100 150 200 300 400 600 V Maximum Average Forward Rectified Current at T c = 100 °C I F(AV) 5 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 120 A Maximum Forward Voltage at 5 A VF Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Typical Junction Capacitance at V R =4V, f=1MHz Maximum Reverse Recovery Time (1) Typical Thermal Resistance (2) Operating and Storage Temperature Range 1.68 V IR 5 100 μA Cj 50 pF t rr 35 ns RθJA RθJC 35 13 °C/W T j , T stg -55 ~ +150 °C (1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A . (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. REV.08 1.25 1 1 of 3 ES5ACG THRU ES5JCG Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram 50 ohm Noninductive t rr 10 ohm Noninductive +0.5 D.U.T + PULSE GENERATOR Note 2 25Vdc approx 0 - -0.25 1 ohm NonInductive OSCILLOSCOPE Note 1 -1.0 Note:1.Rise Time = 7ns, max. Input Impedance = 1megohm,22pF. 2. Ries Time =10ns, max. Source Impedance = 50 ohms. 10ns/div Set time Base for 10ns/div Fig.3 Typical Reverse Characteristics 7.0 300 6.0 100 I R - Reverse Current ( μ A) Average Forward Current (A) Fig.2 Maximum Average Forward Current Rating 5.0 4.0 3.0 2.0 1.0 Single phase half-wave 60 Hz resistive or inductive load T J =125°C 10 T J =75°C 1.0 T J =25°C 0.1 0.0 25 50 75p 100 e ( 125) 150 0 175 10 T J =25°C 1.0 ES5ACG~ES5DCG ES5ECG/ES5GCG 0.1 ES5JCG 0.01 0.5 1.0 1.5 2.0 2.5 Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 120 100 80 60 40 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 10 100 Number of Cycles REV.08 80 100 100 10 T J=25°C f = 1.0MHz V sig = 50mV p-p 1.0 10 Reverse Voltage (V) Fig.6 Maximum Non-Repetitive Peak Forward Surage Current 1 60 T J =25°C 1 0.1 0.001 0 40 % of PIV.VOLTS Fig.5 Typical Junction Capacitance Junction Capacitance ( pF) Instaneous Forward Current (A) Case Tem eratur °C Fig.4 Typical Forward Characteristics 20 2 of 3 100 ES5ACG THRU ES5JCG PACKAGE OUTLINE SMC Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A SMC mechanical data A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil Marking The recommended mounting pad size 3.8 (150) 4.1 (160) 4.3 (170) 4.1 (160) mm Unit : (mil) REV.08 3 of 3 Type number Marking code ES5ACG ES5A ES5BCG ES5B ES5CCG ES5C ES5DCG ES5D ES5ECG ES5E ES5GCG ES5G ES5JCG ES5J
ES5ACG 价格&库存
很抱歉,暂时无法提供与“ES5ACG”相匹配的价格&库存,您可以联系我们找货
