ESD0301BL
ESD0301BL
    SK(時科)
    SOD-882
    双向 3.3V 4A
ESD0301BL 数据手册
ESD0301BL Ulter Low Capacitance ESD Protection Diode Description Features ESD0301BL is a low-capacitance Transient Voltage Suppressor (TVS) designed to provide electrostatic discharge (ESD) protection for high-speed data interfaces. With typical capacitance of 0.5pF, ESD0301BL is designed to protect parasitic-sensitive systems against over- Transient protection for high-speed data lines voltage and over-current transient events. It complies with IEC 61000-4-2 (ESD), Level 4 (±15kV air, ±8kV contact discharge), IEC 61000-4-4 (electrical fast transient - EFT) (40A, 5/50 ns), very fast charged device model (CDM) ESD and cable discharge event (CDE), etc. Ultra-small package (1.0mm 0.6mm 0.5mm) Protects one data, control line Low capacitance: 0.5pF (Typical) ESD0301BL uses ultra-small DFN1006 package. Each ESD0301BL device can protect one highspeed data line. It offers system designers Machanical Data IEC 61000-4-2 (ESD) ±15kV (Air) ±8kV (Contact) IEC 61000-4-4 (EFT) 40A (5/50 ns) Cable Discharge Event (CDE) Package optimized for high-speed lines Low leakage current Low clamping voltage SOD-882 package Flammability Rating: UL 94V-0 flexibility to protect single data line where space is a premium concern. The combined features of low capacitance, ultra-small size and high ESD robustness make ESD0301BL ideal for highspeed data port and high-frequency line Packaging: Tape and Reel High temperature soldering guaranted:260℃/10s Reel size: 7 inch Applications applications, such as cellular phones and HD visual devices. Serial ATA Device: ESD0301BL Desktops, Servers and Notebooks Cellular Phones MDDI Ports Package: SOD-882 Marking: 3BL Material: Halogen free USB Data Line Protection Display Ports Digital Visual Interfaces (DVI) Ordering Information Packing: Tape & Reel Quantity per reel: 10,000pcs REV.08 1 of 3 ESD0301BL Pin Configuration Circuit Diagram Absolute Maximum Rating Symbol Parameter Value Units V ESD ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) ±20 ±20 kV PPP Peak Pulse Power (8/20μs) 84 W TOPT Operating Temperature -55~125 C TSTG Storage Temperature -55~150 C Electrical Characteristics(Tamb=25°C) ELECTRICAL CHARACTERISTICS (Tamb=25 C) Parameter Test Condition Symbol Min Typ Max Units 3.3 V VRWM Reverse Working Voltage VBR Reverse Breakdown Voltage IT = 1mA IR Reverse Leakage Current V RWM = 3.3V 100 nA IPP = 1A, t p = 8/20μs 12 V IPP = 4A, t p = 8/20μs 21 V VC CJ REV.08 4.2 V Clamping Voltage Junction Capacitance VR = 0V, f = 1MHz 2 of 3 0.5 pF ESD0301BL Electrical Characteristics Curve SOD-882 Package Outline Dimensions DFN1006 PACKAGE OUTLINE DIMENSIONS REV.08 3 of 3
ESD0301BL
物料型号:SST25VF016B
器件简介:SST25VF016B 是一款 2Mb (256K x 8) 串行串行存储器,具有 40 引脚 SOIC 封装,支持 SPI 总线接口。
引脚分配: - VCC:电源电压 - GND:地电压 - CS#:片选信号 - SO:串行输出 - SI:串行输入 - SCK:串行时钟 - WP#:写保护 - HOLD#:保持信号
参数特性:工作电压范围为 2.7V 至 3.6V,数据保存期限超过 40 年,数据传输速率可达 20MHz。
功能详解:SST25VF016B 支持快速读取和编程操作,具有页模式编程和扇区擦除功能,提供软件保护机制。
应用信息:适用于需要非易失性存储的嵌入式系统,如工业控制、手持设备和通信设备。
ESD0301BL 价格&库存
很抱歉,暂时无法提供与“ESD0301BL”相匹配的价格&库存,您可以联系我们找货
