GS3M
GS3M
    DOESHARE(德芯)
    SMB(DO-214AA)
    肖特基二极管 SMB(DO-214AA)
GS3M 数据手册
GS3A THUR GS3M GS3A THUR GS3M 3.0 AMP SURFACE MOUNT SILICON RECTIFIERS General description SMB/DO214AA 3.0 AMP SURFACE MOUNT SILICON RECTIFIERS FEATURES • Ideal for surface mount applications • Easy pick and place • Built-in strain relief • Low forward voltage drop MECHANICAL DATA • Case: Molded plastic • Epoxy: UL 94V-0 rate flame retardant • Metallurgically bonded construction • Polarity: Color band denotes cathode end • Mounting position: Any • Weight: 0.093 gram Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER SYMBOLS GS3A GS3B GS3D GS3G GS3J GS3K 100 200 400 600 800 Maximum repetitive peak reverse voltage VRRM 50 Maximum RMS voltage GS3M UNITS 1000 V VRMS 35 70 140 280 420 560 700 V Maximum DC blocking voltage VDC 50 100 200 400 600 800 1000 V Maximum average forward rectified current at TL=90 C I(AV) 3.0 A IFSM 80.0 A VF 1.2 V IR 5.0 250.0 µA CJ 60.0 pF RθJA 13 ℃/W TJ,TSTG -55 to +150 ℃ Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 3.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction and storage temperature range Note: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance Junction to Lead. www.doeshare.net GS3A THUR GS3M Rating And Characteristic Curves Marking: Type number GS3A GS3B GS3D GS3G GS3J GS3K GS3M Marking code S3A S3B S3D S3G S3J S3K S3M www.doeshare.net GS3A THUR GS3M Important Notice and Disclaimer DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. www.doeshare.net
很抱歉,暂时无法提供与“GS3M”相匹配的价格&库存,您可以联系我们找货
