ES2J
ES2J
    DOESHARE(德芯)
    SMA(DO-214AC)
    快/超快恢复二极管 SMA(DO-214AC)
ES2J 数据手册
ES2A THUR ES2J ES2A THUR ES2J Super-Fast Surface Mount Rectifiers SMB/DO-214AA General description Super-Fast Surface Mount Rectifiers Reverse Voltage: 50 to 600V Forward Current:2.0A SMB/DO214AA package FEATURES • The plastic package carries Underwriters Laboratory • Flammability Classification 94V-0 • For surface mounted applications • Low reverse leakage • Built-in strain relief ideal for automated placement • High forward surge current capability • High temperature soldering guaranteed • 250 ℃/10 seconds at terminal MECHANICAL DATA • Case: JEDEC DO-214AA molded plastic • Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 Unit: inch (mm) • Polarity: Color band denotes cathode end • Mounting Position: Any • Weight: 0.005 ounce, 0.138 gram Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) Characteristic Marking Code Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage RMS Reverse Voltage Average Rectified Output Current @TL = 75°C Symbol ES2A ES2B ES2C ES2D ES2E ES2G ES2J Unit Mark ES2A ES2B ES2C ES2D ES2E ES2G ES2J N/A VRRM VRWM VR 50 100 150 200 300 400 600 V VR(RMS) 35 70 105 140 210 280 420 V IO 2.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 50 A Forward Voltage VFM @IF = 3.0A Peak Reverse Current @TA = 25°C At Rated DC Blocking Voltage @TA = 100°C 0.95 1.25 1.7 V IRM 5.0 50 µA Reverse Recovery Time (Note 1) trr 35 nS Typical Junction Capacitance (Note 2) Cj 60 pF RJL 40 °C/W Tj, TSTG -55 to +150 °C Typical Thermal Resistance (Note 3) Operating and Storage Temperature Range Note: 1. Measured with IF = 0.5 A, IR = 1 A, Irr = 0.25 A www.doeshare.net ES2A THUR ES2J RATING AND CHARACTERISTIC CURVES www.doeshare.net ES2A THUR ES2J Important Notice and Disclaimer DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. www.doeshare.net
很抱歉,暂时无法提供与“ES2J”相匹配的价格&库存,您可以联系我们找货
