DT12T10T-B
DT12T10T-B
    DOESHARE(德芯)
    TO-220-3
    DT12T10T-B
DT12T10T-B 数据手册
DT12T Standard Series TRIACs DT12T Standard Series TRIACs SILICON BIDIRECTIONAL THYRISTORS These products 12A TRAIC are packages for third quadrant, DT12T are high commutation performance without snubber circuit. It can be controlled by phase angle trigger or on/off trigger. ITO-220 TO-220F D2PAK TO-262 HA FEATURES • Passivated die for reliability and uniformity • Three-quadrant triggering. • Over 800V VDRM/VRRM • 125 Degree C operation temperature. • Without snubber circuit. • “Green” molding compound, UL flammability classification 94V-0, (No Br. Sb. CI) • Lead free in RoHS II 2015/863/EU compliant • Moisture sensitivity meets industry standard IPC/JEDEC J-STD-020’ RE General description ES APPLICATIONS • General purpose AC switch control • Control loads in Motor, Fan, and Pump. • Solenoid drivers • LED Dimming • Inrush current limiting circuits TO-220 DT12T Standard Series TRIACs ELECTRICAL CHARACTERISTICS (Tj = 25°C, unless otherwise specified.) Absolute Ratings SYMBOL VALUE UNIT Peak repetitive off-state voltage ( Tj = -40 to 125°C, Full sine wave, 50 to 60 Hz; Gate open) (Note 1) VDRM VRRM 800 V On-stage RMS current (Full sine wave, TC = 100°C ) IT(RMS) 12 A Peak non-repetitive surge current ( one full cycle 60 HZ, Tj = 25°C) ITSM 100 A Circuit fusing consideration ( t = 8.3ms) I2T 41.5 A2S Operating junction temperature range Tj -40 to +125 °C TSTG -40 to +150 °C DO PARAMETER Storage temperature range Note : (1) VDRM and VRRM for all types can be applied on a continuous basis. Blocking voltages shall not be tested with a constant current source such that the voltage ratings of the devices are exceeded. http://www.doeshare.net Version 04, MAY-2020 Page 1 of 10 DT12T Standard Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) Thermal Characteristics PARAMETER SYMBOL Thermal resistance from junction to case, without heatsink, (1) Rth(j-C) Max 12 Junction to ambient, without heatsink, (1) Rth(j-a) Typ 35 Static Characteristics PARAMETER Peak repetitive forward or reverse blocking current ( VAK = rated VDRM and VRRM, gate open) ON Characteristics PARAMETER Peak forward on-state voltage ( ITM = 12 A @ Tj = 25°C) TL Max °C/W Tj = 25°C Tj = 125°C 260 °C SYMBOL MIN. TYP. MAX. UNIT Vto -- -- 0.95 V Rd -- -- 30 mΩ IDRM IRRM -- -- 5 uA -- -- 0.5 mA HA Threshold Voltage (Tj = 125°C) Dynamic resistors (Tj = 125°C) UNIT RE Maximum lead temperature for soldering purposes (1/8” form case for 10 seconds) Note1: without heatsink, unidirectional, continuous & full cycle. VALUE SYMBOL DT12T10 DT12T35 UNIT 1.5 1.5 Max V VD= VDRM , RL=100Ω, Tj=125°C VGD 0.25 0.25 Min V Gate trigger current ( VAK = 12V, RL=100Ω) IGT1 IGT2 IGT3 10 10 10 35 35 35 Max mA Gate trigger voltage ( VAK = 12V, RL=100Ω) VGT1 VGT2 VGT3 1 1 Max V Holding current ( VAK = 12V, RL=100Ω) IH1 IH3 10 50 Max mA Latching current ( VAK = 12V, RL=100Ω) IL1 IL2 IL3 20 30 20 50 80 50 Max mA dI/dt(s) 50 50 Max A/us dV/dt 500 3000 Max V/us Without snubber, Tj = 125°C dI/dt(c) 2 8 Max A/ms 125°C, Gate open, 10V/dt di/dt(c) 10 40 Max A/ms DO ES VTM Critical rate of rise of on-state current, Tj = 125°C VD = 67% VDRM, gate open, Tj = 125°C http://www.doeshare.net Page 2 of 10 DT12T Standard Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) DO ES HA RE DT12T10 Characteristic http://www.doeshare.net Page 3 of 10 DT12T Standard Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) DO ES HA RE DT12T35 Characteristic http://www.doeshare.net Page 4 of 10 DT12T Standard Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) DO ES Voltage Code: Operation Temp Code: Doeshare Standar products T for Triac series 16 for 16A, 1 for 1A T for 3Q, F for 4Q 35 means Igt 35mA, 5 means Igt 5mA A=>TO-92, C=>TO-126, D=> DPAK, E=>D2PAK, F=> TO-220F, G=>SOT-223 M=>ITO-3P, P=>TO-3P, T=> TO-220, Y=>TO251 A=> 600V, B=> 800V, C=> 1000V None=>125°C, H=>150°C HA Type Code: Product Code: IT Amp Code: Quadrantal Code: IGT&VCEsat Code: Package Code: RE Ordering information scheme http://www.doeshare.net Page 5 of 10 DT12T Standard Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) DIM Millimeters Min Max 4.3 4.7 9.7 10.3 14.7 15.3 3.8 4.0 2.9 3.1 DO C A B B1 B2 ES HA RE TO-220F Plastic Package http://www.doeshare.net DIM R b b1 a E Millimeters Min Max 3.0 3.4 12.5 13.5 2.9 3.9 0.55 0.75 2.29 2.79 DIM E1 C1 C2 c Millimeters Min Max 2.29 2.79 2.5 2.9 2.5 2.7 0.5 0.7 Page 6 of 10 DT12T Standard Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) DIM Millimeters Min Max 6.50 6.70 0.71 0.81 DO A A1 A2 A3 A4 B B1 C ES HA RE DPAK(TO-252) Plastic Package 2.236 2.336 5.284 5.384 0.75 0.85 6.00 6.20 9.80 10.10 2.20 2.40 http://www.doeshare.net DIM C1 C2 D D1 D2 D3 H R Millimeters Min Max 0.967 1.087 0.498 0.518 0.70 0.90 1.40 1.60 0.81 0.91 0.05TYP 0.00 DIM θ1 θ2 θ3 θ4 θ5 θ6 Millimeters Min Max 0 ゚~ 8 ゚ 8.5 ゚ TYP4 25 ゚ TYP 10 ゚ TYP 10 ゚ TYP 70 ゚ TYP 0.10 0.40TYP Page 7 of 10 DT12T Standard Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) HA RE TO-262 Plastic Package Unit: mm Min 9.95 23.25 8.9 2.5 1.2 0.75 3.3 4.45 1.25 2.5 0.38 ES Item DO A B C D E F G H I J K Type 10 23.35 9 2.54 1.27 0.8 3.5 4.5 1.27 2.6 0.4 http://www.doeshare.net Max 10.2 23.45 9.1 2.6 1.35 0.85 3.6 4.55 1.29 2.7 0.42 Page 8 of 10 DT12T Standard Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) DIM Millimeters Min Max 9.7 6.13 1.2 9.0 12.6 10.4 6.82 1.42 9.4 13.6 DO A B C B1 ES HA RE TO-220C Plastic Package b http://www.doeshare.net DIM a a1 b1 c C1 Millimeters Min Max 1.22 0.7 9.6 0.38 2.2 1.32 0.92 10.6 0.65 2.75 DIM a2 C2 E R L Millimeters Min Max 1.18 4.3 2.34 3.55 15.7 1.45 4.71 2.74 3.78 16.14 Page 9 of 10 DT12T Standard Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) DIM Millimeters Min Max 9.8 10.4 2.65 3.1 2.8 4.2 0.7 0.92 0.35 0.65 DO A B C D M ES HA RE ITO-220 Plastic Package http://www.doeshare.net DIM E F G H N Millimeters Min Max 3.75 3.95 14.8 16.1 13.05 13.6 2.4 2.7 1.18 1.42 DIM I J K L Millimeters Min Max 4.38 4.61 1.15 1.36 5.85 6.82 2.35 2.75 Page 10 of 10 DT12T Standard Series TRIACs CHARACTERISTIC & CURVES (Tj = 25°C, unless otherwise specified.) Important Notice and Disclaimer RE DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. HA Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. DO ES Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. http://www.doeshare.net Page 11 of 10
DT12T10T-B 价格&库存
很抱歉,暂时无法提供与“DT12T10T-B”相匹配的价格&库存,您可以联系我们找货
