BC848B
BC848B
    DOESHARE(德芯)
    SOT-23
    BC848B
BC848B 数据手册
BC846/BC847/BC848 BC846/BC847/BC848 SOT-23 Plastic-Encapsulate Transistors(NPN) General description SOT-23 Plastic-Encapsulate Transistors(NPN) FEATURES • • • • • • • Complementary to BC856/BC857/BC858 Power Dissipation of 200mW Ideally suited for automatic insertion For switching and AF amplifier applications SOT-23 Small Outline Plastic Package Epoxy UL: 94V-0 Mounting Position: Any DEVICE MARKING CODE: BC846A=1A BC846B=1B BC847A=1E BC847B=1F BC847C=1G BC848A=1J BC848B=1K BC848C=1L Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) Parameters Collector-Base Voltage Unit VEBO Value 80 50 30 65 45 30 6 Collector Current-Continuous IC 100 mA Collector Power Dissipation PC 200 mW Junction Temperature Tj 150 ℃ Storage Temperature Tstg -55-+150 ℃ Thermal resistance From junction to ambient RθJA 625 ℃/W Collector-Emitter Voltage Emitter -Base Voltage www.doeshare.net Symbol VCBO VCEO BC846 BC847 BC848 BC846 BC847 BC848 V V V BC846/BC847/BC848 Electrical Characteristics (Ratings at 25℃ Parameter Collector-base breakdown voltage ambient temperature unless otherwise specified). Symbols V(BR)CBO IC=10uA, IE=0 Collector-emitter breakdown voltage V(BR)CEO Limits Test Condition IC=10mA, IB=0 Min Max Unit BC846 BC847 BC848 80 50 30 V BC846 BC847 BC848 65 45 30 V 6 V Emitter-base breakdown voltage V(BR)EBO IE=10uA, IC=0 Collector cut-off current ICBO VCB=70V, IE=0 VCB=50V, IE=0 VCB=30V, IE=0 BC846 BC847 BC848 100 nA Collector cut-off current ICEO VCE=60V, IB=0 VCE=45V, IB=0 VCE=30V, IB=0 BC846 BC847 BC848 100 nA 100 nA Emitter cut-off current IEBO VEB=5V, IC=0 hFE VCE=5V, IC=2mA BC846A;BC847A;BC848A DC current gain BC846B;BC847B;BC848B BC847C;BC848C 110 200 420 220 450 800 Collector-emitter saturation voltage VCE(sat) IC=100mA, IB=5mA 0.50 V Base -emitter saturation voltage VBE(sat) IC=100mA, IB=5mA 1.10 V Transition frequency Collector output capacitance www.doeshare.net fT Cob VCE=5V, IC=10mA,f=100MHz VCB=10V, f=1MHz 100 MHz 4.5 pF BC846/BC847/BC848 RATING AND CHARACTERISTIC CURVES www.doeshare.net BC846/BC847/BC848 SOT-23 PACKAGE OUTLINE Plastic surface mounted package Precautions: PCB Design Recommended land dimensions for SOT-23 diode. Electrode patterns for PCBs www.doeshare.net BC846/BC847/BC848 Important Notice and Disclaimer DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. www.doeshare.net
BC848B 价格&库存
很抱歉,暂时无法提供与“BC848B”相匹配的价格&库存,您可以联系我们找货
