ES1J
ES1J
    DOESHARE(德芯)
    SMA(DO-214AC)
    ES1J
ES1J 数据手册
ES1D THUR ES1J ES1D THUR ES1J Super-Fast Surface Mount Rectifiers General description SMA/DO-214AC Super Fast Surface Mount Rectifiers Reverse Voltage : 50 to 600V Forward Current:1.0A SMA/DO214AC package FEATURES • Low profile package • Built-in strain relief • Easy pick and place • Superfast recovery times for high efficiency. • Plastic package has Underwriters Laboratory • Flammability Classification 94V-O • Glass passivated junction • In compliance with EU RoHS 2002/95/EC directives Unit: inch (mm) MECHANICAL DATA • Case: JEDEC DO-214AC molded plastic • Terminals: Solder plated, solderable per MIL-STD-750 ,Method 2026 • Polarity: Indicated by cathode band. • Standard packaging: 12mm tape (EIA-481) • Weight: 0.002 ounce, 0.064 gram Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) Parameter SYMBOLS ES1A ES1B ES1C ES1D ES1E ES1G ES1J UNITS Maximum repetitive peak reverse voltage VRRM 50 100 150 200 300 400 600 VOLTS Maximum RMS voltage VRMS 35 70 105 140 210 280 420 VOLTS Maximum DC blocking voltage VDC 50 100 150 200 300 400 600 VOLTS Maximum average forward rectified current at TL=55℃ I(AV) 1.0 Amp Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) IFSM 30.0 Amps Maximum instantaneous forward voltage at 1.0A VF Maximum DC reverse current TA=25℃ at rated DC blocking voltage TA=100℃ Maximum reverse recovery time (NOTE 1) Typical junction capacitance (NOTE 2) Typical thermal resistance (NOTE 3) Operating junction and storage temperature range 0.95 1.3 Volts IR 5.0 50.0 uA trr 35 ns CJ 15.0 pF RqJA 60.0 ℃/W TJ,TSTG -55 to +150 ℃ Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas www.doeshare.net 1.7 ES1D THUR ES1J www.doeshare.net ES1D THUR ES1J Suggested Soldering Temperature Profile Package Information A0 B0 K0 D0 E F 2.80 5.30 2.36 1.55 1.75 P0 P1 P2 T W Tolerance 4.0 4.0 2.0 0.25 12 0.1 5.50 Package Specifications Reel DIA. (mm) Q'TY/Reel (Kpcs) Box Size (mm) QTY/Box (Kpcs) Carton Size (mm) Q'TY/Carton (Kpcs) 7' 178 2 180*180*73 8 380*200*200 80 11' 280 5 288*288*38 10 355*310*310 80 Package Reel Size SMA www.doeshare.net ES1D THUR ES1J Important Notice and Disclaimer DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. www.doeshare.net
很抱歉,暂时无法提供与“ES1J”相匹配的价格&库存,您可以联系我们找货
