BBUP00100505121Y00
BBUP00100505121Y00
    CHILISIN(奇力新)
    贴片磁珠 阻抗120Ω@100MHZ
BBUP00100505121Y00 数据手册
SMD Multilayer Ferrite Chip Beads Multilayer Ferrite Chip Beads Chilisin offers a wide range of multi-layered ferrite chip beads with various sizes, frequency characteristics, and impedance values for EMI solutions. These ferrite formulas are used to compose seven types of EMI suppression chip beads: BBSY, BBBK, BBSJ, BBGK, BBPY, BBUP, BBNQ, BBFY, BBFJ and BBHV series. Product Identification Shape and Dimensions Recommended Pattern Dimensions in mm Dimensions in mm TYPE A B C D TYPE A B C 060303 0.60.03 0.300.03 0.30.03 0.150.05 060303 0.2 ~ 0.3 0.75 ~ 1.05 0.3 100505 1.00.10 0.500.10 0.50.10 0.250.10 100505 0.4 1.2 ~ 1.4 0.5 160805 1.60.15 0.800.15 0.50.15 0.30.2 160805 0.7 ~ 0.8 1.8 ~ 2.0 0.6 ~ 0.8 160808 1.60.15 0.800.15 0.80.15 0.30.2 160808 0.7 ~ 0.8 1.8 ~ 2.0 0.6 ~ 0.8 201209 2.00.20 1.250.20 0.90.20 0.50.3 201209 1.0 ~ 1.2 2.6 ~ 4.0 1.0 ~ 1.4 321611 3.20.20 1.600.20 1.10.20 0.50.3 321611 2.0 ~ 2.4 4.2 ~ 5.2 1.3 ~ 1.9 453215 4.50.25 3.200.20 1.50.20 0.50.3 453215 3.0 5.5 ~ 6.5 2.4 :BBSY / BBSJ / BBNQ / BBPY * Don’t apply narrower pattern than listed above to BBPY and BBUP :BBSY / BBSJ / BBNQ / BBPY / BBUP / BBFY / BBFJ Narrow pattern might cause excessive heat or open circuit. :BBUP :BBBK / BBSJ / BBGK / BBPY / BBNQ / BBUP / BBHV :BBBK / BBGK / BBPY / BBUP :BBSY / BBBK / BBPY / BBUP :BBPY / BBUP Dimension Conversion Code Dimension in mm (AxBxC) EIA 060303 0.6X0.3X0.3 0201 100505 1.0X0.5X0.5 0402 160805 1.6x0.8x0.5 0603 160808 1.6x0.8x0.8 0603 201209 2.0x1.2x0.9 0805 321611 3.2x1.6x.1.1 1206 453215 4.5x3.2x1.5 1812 SMD Multilayer Ferrite Chip Beads – BBUP Series Electrical Characteristics Impedance Test Frequency RDC Rated current (Ω±25%) (MHz) (Ω) Max (mA) Max BBUP00100505300Y00 30 100 0.022 3000 BBUP00100505330Y00 33 100 0.022 3000 BBUP00100505600Y00 60 100 0.032 2500 BBUP00100505800Y00 80 100 0.038 2300 BBUP00100505121Y00 120 100 0.055 2000 BBUP00100505181Y00 180 100 0.090 1500 BBUP00100505221Y00 220 100 0.100 1400 BBUP00100505331Y00 330 100 0.150 1200 BBUP00100505471Y00 470 100 0.200 1000 Part Number Note: When ordering, please specify tolerance code. Tolerance : Y=±25%  Operating temperature range-55℃~125℃(Including self - temperature rise)  Rate Current:Applied the current to coils, the temperature rise shall not be more than 30℃  Measure Equipment: Z:HP4291A RDC:HP4338B or CHEN HWA 502 Test Instruments:Agilent E4991A Impedance / Material Analyzer BBUP00100505330Y00 BBUP00100505600Y00 120 50 100 IMPEDANCE(Ω) IMPEDANCE(Ω) 60 Z 40 30 20 10 X R 0 Z 80 60 40 X 20 R 0 1 10 100 1000 10000 1 FREQUENCY (MHz) RDC
BBUP00100505121Y00 价格&库存
很抱歉,暂时无法提供与“BBUP00100505121Y00”相匹配的价格&库存,您可以联系我们找货
BBUP00100505121Y00
  • 1+0.939331+0.12191
  • 10+0.4611310+0.05985
  • 25+0.3987925+0.05176
  • 50+0.3573850+0.04638
  • 100+0.32162100+0.04174
  • 250+0.27728250+0.03599
  • 500+0.24718500+0.03208
  • 1000+0.219331000+0.02847
  • 5000+0.162415000+0.02108
库存:1829
BBUP00100505121Y00
  • 50+0.04776
  • 500+0.04299
  • 5000+0.03980
  • 10000+0.03821
  • 30000+0.03662
  • 50000+0.03566
