SMD Wire Wound Ceramic Chip Inductors - CS Series
CS Series
Due to accurate wire winding technology, these chip inductors are
designed for filtering, impedance matching, resonance and choke
circuits for RF designer. Both standard series custom designs are
available.
Features
Applications
RoHS Compliant
RF products for cellular phone
Ceramic body and wire wound construction provide high SRFs
GPS receiver
Exceptional Q values even at high frequencies
Base Station
Highest possible SRFs as well as excellent Q values
Repeater
The non-magnetic coil form assures utmost thermal stability,
Wireless LAN/ mouse/ keyboard/ earphone
Remote control
predictability and batch consistency
CS series is standard for RF designers
Security system and other RF modules
Product Identification
Shape and Dimensions / Recommended Pattern
CS0201
CS0402
Dimensions
CS0201
CS0402
A Max
B Max
C Max
D
E
F
G
H
I
J
inch
0.023
0.018
0.018
0.015
0.004
0.018
0.007
0.009
mm
0.58
0.46
0.45
0.38
0.1
0.46
0.18
0.23
inch
0.047
0.028
0.026
0.010
0.020
0.009
0.022
0.026
0.014
0.018
mm
1.19
0.70
0.66
0.25
0.51
0.23
0.56
0.66
0.36
0.46
CS0603/0805/1008
CS1812
Dimensions
CS0603
CS0805
CS1008
CS1812
A
B
+0.2
1.02±0.1
0.82
A Max
B Max
inch
0.093
mm
2.35
mm
1.6
-0.1
C
D
E
F
G
H
I
J
0.51
0.76
0.33
0.86
1.02
0.64
0.64
C Max
D
E
F
G
H
I
J
0.068
0.06
0.028
0.05
0.02
0.04
0.07
0.04
0.03
1.73
1.52
0.71
1.27
0.51
1.02
1.78
1.02
0.76
+0.2
-0.1
inch
0.115
0.11
0.083
0.046
0.08
0.02
0.06
0.10
0.04
0.05
mm
2.92
2.79
2.1
1.16
2.03
0.51
1.52
2.54
1.02
1.27
inch
0.197
0.154
0.135
0.07
0.1
0.025
0.128
0.12
0.045
0.118
mm
4.95
3.81
3.43
1.78
2.54
0.64
3.25
3.05
1.14
3.00
Electrical Characteristics
Test
Inductance
Tolerance
(nH)
CS0201-0N5□-S
0.5
10
250
CS0201-0N6□-S
0.6
10
CS0201-1N2□-S
1.2
5
CS0201-1N3□-S
1.3
Part Number
Q
SRF
RDC
Irms
Min
(GHz) Typ
(Ω) Max
(mA) Typ
4
23.5
0.02
1250
250
6
24.5
0.03
1000
250
13
17.9
0.042
870
5
250
11
17.6
0.048
820
Frequency
(MHz)
CS0201-1N4□-S
1.4
5
250
14
17
0.08
630
CS0201-1N5□-S
1.5
5
250
11
17
0.09
600
CS0201-2N2□-S
2.2
5
250
15
16.7
0.07
700
CS0201-2N3□-S
2.3
5
250
18
16.5
0.07
670
CS0201-2N4□-S
2.4
5
250
13
13
0.082
620
CS0201-2N5□-S
2.5
5
250
16
12.5
0.165
440
CS0201-3N3□-S
3.3
5
250
14
12.8
0.08
630
CS0201-3N4□-S
3.4
5
250
11
12.7
0.08
630
CS0201-3N5□-S
3.5
5
250
16
12.4
0.08
630
CS0201-3N6□-S
3.6
5
250
18
12.5
0.105
550
CS0201-3N7□-S
3.7
5
250
15
10.6
0.105
550
CS0201-3N8□-S
3.8
5
250
16
10.2
0.18
420
CS0201-3N9□-S
3.9
5
250
12
11.2
0.24
360
CS0201-4N8□-S
4.8
5
250
17
11
0.096
570
CS0201-4N9□-S
4.9
5
250
18
11.7
0.13
510
CS0201-5N0□-S
5.0
5
250
18
11.5
0.13
510
CS0201-5N1□-S
5.1
5
250
18
11.1
0.13
510
CS0201-5N2□-S
5.2
5
250
18
10
0.17
430
CS0201-5N3□-S
5.3
5
250
18
10.6
0.13
510
CS0201-5N4□-S
5.4
5
250
18
10.2
0.13
510
CS0201-5N5□-S
5.5
5
250
16
9.5
0.285
330
CS0201-6N7□-S
6.7
5
250
18
6.8
0.15
460
CS0201-6N8□-S
6.8
5
250
18
9.5
0.15
460
CS0201-6N9□-S
6.9
5
250
18
9.3
0.15
460
CS0201-7N0□-S
7.0
5
250
18
6.7
0.21
390
CS0201-7N1□-S
7.1
5
250
18
9.5
0.25
390
CS0201-7N2□-S
7.2
5
250
18
9.4
0.25
390
CS0201-7N3□-S
7.3
5
250
18
9.3
0.25
390
CS0201-7N4□-S
7.4
5
250
18
9.1
0.25
390
CS0201-7N5□-S
7.5
5
250
15
6.8
0.34
300
CS0201-7N6□-S
7.6
5
250
17
9.3
0.3
340
CS0201-7N7□-S
7.7
5
250
17
9.2
0.3
340
CS0201-7N8□-S
7.8
5
250
17
9.2
0.3
340
CS0201-7N9□-S
7.9
5
250
17
9.1
0.3
340
CS0201-8N0□-S
8.0
5
250
17
9.2
0.3
340
CS0201-8N1□-S
8.1
5
250
17
9.1
0.3
340
CS0201-8N2□-S
8.2
5
250
17
6.4
0.27
340
Note: When ordering, please specify tolerance code. Tolerance : J=±5% , K=±10%
Operating temperature range-40℃~125℃(Including self - temperature rise)
Irms for a 15℃ temperature rise from 25℃ ambient with current
Measure Equipment:
L & Q:HP4286A/HP4287A/AgilentE4991/Keysight E4982A
SRF:Agilent HP8753D/Agilent HP8722ES
RDC:HP4287A/Keysight E4982A
Irms:HP4284A+HP42841A/HP4285A+HP42841A
Please be sure to request approval specifications that provide further details of the products. Kindly note that the
content of these specifications are subject to change or may be discontinued without advance notice. Please
contact our sales department before ordering.
Inductance
Tolerance
(nH)
CS0201-8N3□-S
8.3
5
CS0201-8N4□-S
8.4
CS0201-8N5□-S
8.5
CS0201-8N7□-S
8.7
Part Number
Test
Q
SRF
RDC
Irms
Min
(GHz) Typ
(Ω) Max
(mA) Typ
250
17
8.9
0.3
340
5
250
15
8.9
0.38
300
5
250
15
8.9
0.38
300
5
250
15
6.3
0.38
300
Frequency
(MHz)
CS0201-9N0□-S
9.0
5
250
15
6.4
0.38
300
CS0201-9N4□-S
9.4
5
250
16
6.4
0.4
280
CS0201-9N6□-S
9.6
5
250
16
6.2
0.4
280
CS0201-11N□-S
11
5
250
16
5.7
0.44
280
CS0201-12N□-S
12
5
250
17
5.6
0.36
300
CS0201-13N□-S
13
5
250
16
6.7
0.5
270
CS0201-14N□-S
14
5
250
16
5.1
0.5
270
J=±5% , K=±10%
Measure Equipment:
Typical L vs. Frequency
Typical Q vs. Frequency
100
14
7N0
90
12N
12
12N
80
8
Q
L(nH)
10
7N0
6
70
2N3
60
3N9
50
0N6
40
3N9
4
30
2N3
2
10
0N6
10
100
FREQUENCY(MHz)
1000
10000
1
10
100
FREQUENCY(MHz)
1000
10000
Inductance
Tolerance
(nH)
CS0402-1N0□-S
1.0
10 / 5 / ±0.1nH
CS0402-1N2□-S
1.2
CS0402-1N3□-S
1.3
CS0402-1N9□-S
1.9
Part Number
Test
Q
SRF
RDC
Irms
Min
(GHz) Min
(Ω) Max
(mA) Max
250
16
12.7
0.045
1360
10 / 5 / ±0.1nH
250
10
10.4
0.140
640
10 / ±0.1nH
250
10
10.4
0.140
640
10 / 5 / ±0.1nH
250
16
11.3
0.070
1040
Frequency
(MHz)
CS0402-2N0□-S
2.0
10 / 5 / ±0.1nH
250
16
11.1
0.070
1040
CS0402-2N2□-S
2.2
10 / 5 / ±0.1nH
250
19
10.8
0.070
960
CS0402-2N4□-S
2.4
10 / 5 / ±0.1nH
250
15
10.5
0.068
790
CS0402-2N5□-S
2.5
10 / 5 / ±0.1nH
250
13
10.4
0.150
640
CS0402-2N7□-S
2.7
10 / 5 / ±0.1nH
250
16
10.4
0.120
640
CS0402-3N3□-S
3.3
10 / 5 / 3
250
19
7.00
0.066
840
CS0402-3N6□-S
3.6
10 / 5 / 3
250
19
6.80
0.066
840
CS0402-3N9□-S
3.9
10 / 5 / 3
250
19
6.00
0.066
840
CS0402-4N3□-S
4.3
10 / 5 / 3
250
18
6.00
0.091
700
CS0402-4N7□-S
4.7
10 / 5 / 3
250
15
4.77
0.130
640
CS0402-5N1□-S
5.1
10 / 5 / 3
250
0.083
800
CS0402-5N6□-S
5.6
10 / 5 / 3
250
0.083
760
CS0402-5N8□-S
5.8
10 / 5 / 3
250
0.083
760
CS0402-6N2□-S
6.2
10 / 5 / 3
250
0.083
760
CS0402-6N8□-S
6.8
10 / 5 / 3
250
0.083
680
CS0402-7N3□-S
7.3
10 / 5 / 3
250
0.12
680
CS0402-7N5□-S
7.5
10 / 5 / 3
250
22
4.80
0.10
680
CS0402-8N2□-S
8.2
10 / 5 / 3
250
22
4.40
0.10
680
CS0402-8N7□-S
8.7
10 / 5 / 3
250
18
4.10
0.20
480
CS0402-9N0□-S
9.0
10 / 5 / 3
250
22
4.16
0.10
680
CS0402-9N1□-S
9.1
10 / 5 / 3
250
22
4.16
0.10
680
CS0402-9N5□-S
9.5
10 / 5 / 3
250
18
4.00
0.20
480
CS0402-10N□-S
10
10 / 5 / 3 / 2
250
21
3.90
0.20
480
CS0402-11N□-S
11
10 / 5 / 3 / 2
250
24
3.68
0.12
640
CS0402-12N□-S
12
10 / 5 / 3 / 2
250
24
3.60
0.12
640
CS0402-13N□-S
13
10 / 5 / 3 / 2
250
24
3.45
0.21
440
CS0402-15N□-S
15
10 / 5 / 3 / 2
250
24
3.28
0.17
560
CS0402-16N□-S
16
10 / 5 / 3 / 2
250
24
3.10
0.22
560
CS0402-18N□-S
18
10 / 5 / 3 / 2
250
25
3.10
0.23
420
CS0402-19N□-S
19
10 / 5 / 3 / 2
250
24
3.04
0.20
480
CS0402-20N□-S
250
25
3.00
0.25
420
CS0402-22N□-S
22
10 / 5 / 3 / 2
250
25
2.80
0.30
400
CS0402-23N□-S
23
10 / 5 / 3 / 2
250
22
2.72
0.30
400
CS0402-24N□-S
24
10 / 5 / 3 / 2
250
25
2.70
0.30
400
CS0402-27N□-S
27
10 / 5 / 3 / 2
250
24
2.48
0.30
400
CS0402-30N□-S
30
10 / 5 / 3 / 2
250
25
2.35
0.35
400
Note: When ordering, please specify tolerance code. Tolerance : B=±0.1nH , G=±2% , H=±3% , J=±5% , K=±10%
Measure Equipment:
L & Q:Agilent E4991A+Agilent HP16197A
RDC:HP4287A
Test
Inductance
Tolerance
(nH)
CS0402-33N□-S
33
10 / 5 / 3 / 2
CS0402-36N□-S
36
CS0402-39N□-S
39
CS0402-40N□-S
40
10 / 5 / 3 / 2
CS0402-43N□-S
43
10 / 5 / 3 / 2
250
25
2.03
0.81
100
CS0402-47N□-S
47
10 / 5 / 3 / 2
250
0.83
150
Part Number
Q
SRF
RDC
Irms
Min
(GHz) Min
(Ω) Max
(mA) Max
250
24
2.35
0.40
400
10 / 5 / 3 / 2
250
24
2.32
0.44
320
10 / 5 / 3 / 2
250
25
2.10
0.55
200
250
24
2.24
0.65
320
Frequency
(MHz)
CS0402-51N□-S
51
10 / 5 / 3 / 2
250
25
1.75
0.82
100
CS0402-56N□-S
56
10 / 5 / 3 / 2
250
22
1.76
0.97
100
100
CS0402-68N□-S
68
10 / 5 / 3 / 2
250
22
1.62
1.12
CS0402-82N□-S
82
10 / 5 / 3 / 2
250
1.55
50
CS0402-R10□-S
100
10 / 5 / 3 / 2
250
2.00
30
CS0402-R18□-S
180
10 / 5 / 3 / 2
100
8
0.70
2.70
50
CS0402-R22□-S
220
10 / 5 / 3 / 2
100
8
0.70
4.00
50
Measure Equipment:
RDC:HP4287A
1000
100
R10
3N3
90
47N
80
70
100
L(nH)
60
Q
15N
50
15N
40
10
47N
30
R10
3N3
1
10
100
FREQUENCY(MHz)
1000
10000
1
10
100
FREQUENCY(MHz)
1000
10000
SMD Wire Wound Ceramic Chip Inductors – CS Series
Part Number
Inductance
Tolerance
(nH)
Test
Frequency
(MHz)
Q
SRF
RDC
Irms
Min
(MHz) Min
(Ω) Max
(mA) Max
Color
CS0603-1N6-S
1.6
10 / 5 / ±0.1nH
250
24
12500
0.030
700
Red
CS0603-1N8-S
1.8
10 / 5 / ±0.1nH
250
16
12500
0.045
700
Black
CS0603-2N2-S
2.2
10 / 5 / ±0.1nH
250
13
12500
0.250
700
Yellow
CS0603-3N3-S
3.3
10 / 5 / 3
250
35
5900
0.045
700
Blue
CS0603-3N6-S
3.6
10 / 5 / 3 / 2
250
22
5900
0.063
700
Red
CS0603-3N9-S
3.9
10 / 5 / 3 / 2
250
22
6900
0.080
700
Brown
CS0603-4N3-S
4.3
10 / 5 / 3 / 2
250
22
5900
0.063
700
Orange
CS0603-4N7-S
4.7
10 / 5 / 3 / 2
250
0.116
700
Violet
CS0603-5N1-S
5.1
10 / 5 / 3 / 2
250
0.140
700
Green
CS0603-5N6-S
5.6
10 / 5 / 3 / 2
250
0.170
700
Yellow
CS0603-6N3-S
6.3
10 / 5 / 3 / 2
250
0.140
700
White
CS0603-6N8-S
6.8
10 / 5 / 3 / 2
250
27
5800
0.110
700
Red
Brown
CS0603-7N5-S
7.5
10 / 5 / 3 / 2
250
28
4800
0.106
700
CS0603-8N2-S
8.2
10 / 5 / 3 / 2
250
28
4700
0.109
700
White
CS0603-8N7-S
8.7
10 / 5 / 3 / 2
250
28
4600
0.109
700
Yellow
CS0603-9N1-S
9.1
10 / 5 / 3 / 2
250
28
4800
0.120
700
Violet
CS0603-9N5-S
9.5
10 / 5 / 3 / 2
250
28
5400
0.135
700
Blue
CS0603-10N-S
10
10 / 5 / 3 / 2
250
31
4800
0.130
700
Orange
CS0603-11N-S
11
10 / 5 / 3 / 2
250
33
4000
0.086
700
Gray
CS0603-12N-S
12
10 / 5 / 3 / 2
250
35
4000
0.130
700
Yellow
CS0603-13N-S
13
10 / 5 / 3 / 2
250
30
4000
0.160
700
Black
CS0603-15N-S
15
10 / 5 / 3 / 2
250
35
4000
0.170
700
Green
CS0603-16N-S
16
10 / 5 / 3 / 2
250
34
3300
0.104
700
White
CS0603-18N-S
18
10 / 5 / 3 / 2
250
35
3100
0.170
700
Blue
CS0603-20N-S
250
38
3000
0.190
700
Red
CS0603-22N-S
22
10 / 5 / 3 / 2
250
38
3000
0.190
700
Violet
CS0603-23N-S
23
10 / 5 / 3 / 2
250
38
2850
0.190
700
Orange
CS0603-24N-S
24
10 / 5 / 3 / 2
250
37
2650
0.135
700
Black
CS0603-27N-S
27
10 / 5 / 3 / 2
250
40
2800
0.220
600
Gray
CS0603-30N-S
30
10 / 5 / 3 / 2
250
37
2250
0.144
600
Brown
CS0603-33N-S
33
10 / 5 / 3 / 2
250
40
2300
0.220
600
White
CS0603-36N-S
36
10 / 5 / 3 / 2
250
38
2080
0.250
600
Red
CS0603-39N-S
39
10 / 5 / 3 / 2
250
40
2200
0.250
600
Black
CS0603-43N-S
43
10 / 5 / 3 / 2
250
39
2000
0.280
600
Orange
CS0603-47N-S
47
10 / 5 / 3 / 2
200
38
2000
0.280
600
Brown
CS0603-51N-S
51
10 / 5 / 3 / 2
200
38
1900
0.310
600
Brown
CS0603-56N-S
56
10 / 5 / 3 / 2
200
38
1900
0.310
600
Red
CS0603-68N-S
68
10 / 5 / 3 / 2
200
37
1700
0.340
600
Orange
CS0603-72N-S
72
10 / 5 / 3 / 2
150
34
1700
0.490
400
Yellow
CS0603-82N-S
82
10 / 5 / 3 / 2
150
34
1700
0.540
400
Green
CS0603-91N-S
91
10 / 5 / 3 / 2
150
34
1400
0.580
400
Black
Measure Equipment:
SRF:Agilent HP8753D/Agilent E4991A
RDC:Chroma 16502
Inductance
Tolerance
(nH)
CS0603-R10-S
100
10 / 5 / 3 / 2
CS0603-R11-S
110
10 / 5 / 3 / 2
Part Number
Test
Q
SRF
RDC
Irms
Min
(MHz) Min
(Ω) Max
(mA) Max
150
34
1400
0.580
400
Blue
150
32
1350
0.610
300
Violet
Frequency
(MHz)
CS0603-R12-S
120
10 / 5 / 3 / 2
150
32
1300
0.750
300
Gray
CS0603-R15-S
150
10 / 5 / 3 / 2
150
28
990
0.920
280
White
CS0603-R16-S
160
10 / 5 / 3 / 2
100
25
990
1.250
240
Yellow
CS0603-R18-S
180
10 / 5 / 3 / 2
100
25
990
1.250
240
Black
CS0603-R20-S
200
10 / 5 / 3 / 2
100
25
900
2.100
200
Red
CS0603-R21-S
210
10 / 5 / 3 / 2
100
27
895
2.060
200
Gray
CS0603-R22-S
220
10 / 5 / 3 / 2
100
25
900
2.100
200
Brown
CS0603-R24-S
240
10 / 5 / 3 / 2
100
25
900
2.200
200
Green
CS0603-R25-S
250
10 / 5 / 3 / 2
100
25
822
3.550
120
Violet
CS0603-R27-S
270
10 / 5 / 3 / 2
100
24
900
2.800
170
Red
CS0603-R33-S
330
10 / 5 / 3 / 2
100
25
900
3.890
100
Orange
CS0603-R39-S
390
10 / 5 / 3 / 2
100
25
900
4.350
100
Yellow
CS0603-R47-S
470
10 / 5 / 3 / 2
100
25
500
4.500
100
Brown
CS0603-R56-S
560
10 / 5 / 3 / 2
100
23
460
4.700
90
Blue
Color
Measure Equipment:
RDC:Chroma 16502
Part Number
Inductance
Tolerance
(nH)
Test
Frequency
(MHz)
Q
Min
Test
Frequency
(MHz)
SRF
RDC
Irms
(MHz) Min
(Ω) Max
(mA) Max
CS0805-2N7-S
2.7
10 / 5 / 2
250
50
1500
7900
0.06
800
CS0805-2N8-S
2.8
10 / 5 / 2
250
80
1500
7900
0.06
800
Gray
CS0805-3N0-S
3.0
10 / 5 / 2
250
65
1500
7900
0.06
800
White
Yellow
CS0805-3N3-S
3.3
10 / 5 / 2
250
50
1500
7900
0.08
600
Black
CS0805-5N6-S
5.6
10 / 5 / 2
250
65
1000
5500
0.08
600
Orange
CS0805-6N8-S
6.8
10 / 5 / 2
250
50
1000
5500
0.11
600
Brown
Green
CS0805-7N5-S
7.5
10 / 5 / 2
250
50
1000
4500
0.14
600
CS0805-8N2-S
8.2
10 / 5 / 2
250
50
1000
4700
0.12
600
Red
CS0805-10N-S
10
10 / 5 / 2
250
60
500
4200
0.10
600
Blue
CS0805-12N-S
12
10 / 5 / 2
250
50
500
4000
0.15
600
Orange
CS0805-15N-S
15
10 / 5 / 2
250
50
500
3400
0.17
600
Yellow
CS0805-18N-S
18
10 / 5 / 2
250
50
500
3300
0.20
600
Green
CS0805-22N-S
22
10 / 5 / 2
250
55
500
2600
0.22
500
Blue
CS0805-24N-S
24
10 / 5 / 2
250
50
500
2000
0.22
500
Gray
CS0805-27N-S
27
10 / 5 / 2
250
55
500
2500
0.25
500
Violet
CS0805-33N-S
33
10 / 5 / 2
250
60
500
2050
0.27
500
Gray
Orange
CS0805-36N-S
36
10 / 5 / 2
250
55
500
1700
0.27
500
CS0805-39N-S
39
10 / 5 / 2
250
60
500
2000
0.29
500
White
CS0805-43N-S
43
10 / 5 / 2
200
60
500
1650
0.34
500
Yellow
CS0805-47N-S
47
10 / 5 / 2
200
60
500
1650
0.31
500
Black
CS0805-56N-S
56
10 / 5 / 2
200
60
500
1550
0.34
500
Brown
CS0805-68N-S
68
10 / 5 / 2
200
60
500
1450
0.38
500
Red
Orange
CS0805-82N-S
82
10 / 5 / 2
150
65
500
1300
0.42
400
CS0805-91N-S
91
10 / 5 / 2
150
65
500
1200
0.48
400
Black
CS0805-R10-S
100
10 / 5 / 2
150
65
500
1200
0.46
400
Yellow
CS0805-R11-S
110
10 / 5 / 2
150
50
250
1000
0.48
400
Brown
CS0805-R12-S
120
10 / 5 / 2
150
50
250
1100
0.51
400
Green
CS0805-R15-S
150
10 / 5 / 2
100
50
250
920
0.56
400
Blue
Violet
CS0805-R18-S
180
10 / 5 / 2
100
50
250
870
0.64
400
CS0805-R20-S
200
10 / 5 / 2
100
50
250
860
0.68
400
Red
CS0805-R22-S
220
10 / 5 / 2
100
50
250
850
0.70
400
Gray
CS0805-R24-S
240
10 / 5 / 2
100
44
250
690
1.00
350
Red
Yellow
CS0805-R25-S
250
10 / 5 / 2
100
45
250
660
1.20
350
CS0805-R27-S
270
10 / 5 / 2
100
48
250
650
1.00
350
White
CS0805-R30-S
300
10 / 5 / 2
100
25
250
450
1.40
310
Orange
CS0805-R33-S
330
10 / 5 / 2
100
48
250
600
1.40
310
Black
CS0805-R39-S
390
10 / 5 / 2
100
48
250
450
1.50
290
Brown
CS0805-R47-S
470
10 / 5 / 2
50
33
100
375
1.76
250
Violet
CS0805-R51-S
510
10 / 5 / 2
25
23
50
340
1.90
230
Gray
CS0805-R56-S
560
10 / 5 / 2
25
23
50
340
1.90
230
Orange
CS0805-R62-S
620
10 / 5 / 2
25
23
50
220
2.20
210
Yellow
CS0805-R68-S
680
10 / 5 / 2
25
23
50
188
2.20
190
Green
Note: When ordering, please specify tolerance code. Tolerance : G=±2% , J=±5% , K=±10%
Color
Measure Equipment:
RDC:Chroma 16502
Part Number
Inductance
Tolerance
(nH)
Test
Frequency
(MHz)
Q
Min
Test
Frequency
(MHz)
SRF
RDC
Irms
(MHz) Min
(Ω) Max
(mA) Max
Color
CS0805-R82-S
820
10 / 5 / 2
25
23
50
215
2.35
180
Blue
CS0805-1R0-S
1000
10 / 5 / 2
25
100
2.50
170
Gray
CS0805-1R2-S
1200
10 / 5
7.9
18
25
100
2.50
170
White
CS0805-1R8-S
1800
10 / 5 / 2
7.9
16
7.9
80
2.50
170
Orange
CS0805-3R3-S
3300
10 / 5 / 2
7.9
15
7.9
40
4.40
90
Red
CS0805-4R7-S
4700
10 / 5 / 2
7.9
15
7.9
40
6.40
90
Yellow
Measure Equipment:
RDC:Chroma 16502
Part Number
Inductance Tolerance
(nH)
Test
Frequency
(MHz)
Q
Min
Test
Frequency
(MHz)
SRF
RDC
Irms
(MHz) Min
(Ω) Max
(mA) Max
Color Coding
1ST
2ND
3RD
CS1008-10N-S
10
10 / 5 / 2
50
50
500
4100
0.08
1000
Brown
Black
Black
CS1008-12N-S
12
10 / 5 / 2
50
50
500
3300
0.09
1000
Brown
Red
Black
CS1008-15N-S
15
10 / 5 / 2
50
50
500
2500
0.10
1000
Brown
Green
Black
CS1008-18N-S
18
10 / 5 / 2
50
50
350
2500
0.11
1000
Brown
Gray
Black
CS1008-22N-S
22
10 / 5 / 2
50
55
350
2400
0.12
1000
Red
Red
Black
CS1008-27N-S
27
10 / 5 / 2
50
55
350
1600
0.13
1000
Red
Violet
Black
CS1008-33N-S
33
10 / 5 / 2
50
60
350
1600
0.14
1000
Orange Orange
Black
CS1008-39N-S
39
10 / 5 / 2
50
60
350
1500
0.15
1000
Orange White
Black
CS1008-47N-S
47
10 / 5 / 2
50
65
350
1500
0.16
1000
Yellow
Violet
Black
CS1008-56N-S
56
10 / 5 / 2
50
65
350
1300
0.18
1000
Green
Blue
Black
Black
CS1008-68N-S
68
10 / 5 / 2
50
65
350
1300
0.20
1000
Blue
Gray
CS1008-82N-S
82
10 / 5 / 2
50
60
350
1000
0.22
1000
Gray
Red
Black
CS1008-R10-S
100
10 / 5 / 2
25
60
350
1000
0.56
650
Brown
Black
Brown
CS1008-R12-S
120
10 / 5 / 2
25
60
350
950
0.63
650
Brown
Red
Brown
CS1008-R15-S
150
10 / 5 / 2
25
45
100
850
0.70
580
Brown
Green
Brown
CS1008-R18-S
180
10 / 5 / 2
25
45
100
750
0.77
620
Brown
Gray
Brown
CS1008-R20-S
200
10 / 5 / 2
25
45
100
700
0.84
500
Red
Black
Brown
CS1008-R22-S
220
10 / 5 / 2
25
45
100
700
0.84
500
Red
Red
Brown
CS1008-R27-S
270
10 / 5 / 2
25
45
100
600
0.91
500
Red
Violet
Brown
CS1008-R33-S
330
10 / 5 / 2
25
45
100
570
1.05
450
Orange Orange Brown
CS1008-R39-S
390
10 / 5 / 2
25
45
100
500
1.12
470
Orange White
Brown
CS1008-R47-S
470
10 / 5 / 2
25
45
100
450
1.19
470
Yellow
Violet
Brown
CS1008-R56-S
560
10 / 5 / 2
25
45
100
415
1.33
400
Green
Blue
Brown
CS1008-R62-S
620
10 / 5 / 2
25
45
100
375
1.40
300
Blue
Red
Brown
CS1008-R68-S
680
10 / 5 / 2
25
45
100
375
1.47
400
Blue
Gray
Brown
CS1008-R75-S
750
10 / 5 / 2
25
45
100
360
1.54
360
Violet
Green
Brown
CS1008-R82-S
820
10 / 5 / 2
25
45
100
350
1.61
400
Gray
Red
Brown
CS1008-R91-S
910
10 / 5 / 2
25
35
50
320
1.68
380
White
Brown
Brown
CS1008-1R0-S
1000
10 / 5 / 2
25
35
50
290
1.75
370
Brown
Black
Red
CS1008-1R2-S
1200
10 / 5 / 2
7.9
35
50
250
2.0
310
Brown
Red
Red
CS1008-1R5-S
1500
10 / 5 / 2
7.9
28
50
200
2.3
330
Brown
Green
Red
CS1008-1R8-S
1800
10 / 5 / 2
7.9
28
50
160
2.6
300
Brown
Gray
Red
CS1008-2R2-S
2200
10 / 5 / 2
7.9
28
50
160
2.8
280
Red
Red
Red
CS1008-2R7-S
2700
10 / 5 / 2
7.9
22
25
140
3.2
290
Red
Violet
Red
CS1008-3R3-S
3300
10 / 5 / 2
7.9
22
25
110
3.4
290
Orange Orange
CS1008-3R9-S
3900
10 / 5 / 2
7.9
100
3.6
260
Orange White
Red
CS1008-4R7-S
4700
10 / 5 / 2
7.9
90
4.0
260
Yellow
Violet
Red
CS1008-5R6-S
5600
10 / 5 / 2
7.9
18
7.9
45
4.0
240
Green
Blue
Red
Red
Red
CS1008-6R8-S
6800
10 / 5 / 2
7.9
18
7.9
40
4.9
200
Blue
Gray
CS1008-8R2-S
8200
10 / 5 / 2
7.9
18
7.9
25
6.0
170
Gray
Red
Red
CS1008-100-S
10000
10 / 5 / 2
2.52
18
7.9
25
8.0
150
Brown
Black
Orange
CS1008-150-S
15000
10 / 5 / 2
2.52
15
7.9
100
Brown
Green Orange
Measure Equipment:
1st Code
3rd Code
RDC:Chroma 16502
2nd Code
COLOR CODING
Test
Inductance
Tolerance
(uH)
Q
CS1812-1R0□-N
1.0
J
7.9
60
CS1812-1R2□-N
1.2
J
7.9
62
CS1812-1R5□-N
1.5
J
7.9
CS1812-1R8□-N
1.8
J
CS1812-2R2□-N
2.2
J
CS1812-2R7□-N
2.7
CS1812-3R3□-N
CS1812-3R9□-N
Test
SRF
RDC
Irms
(MHz) Min
(Ω) Max
(mA) Typ
50
310
1.2
480
50
230
1.2
480
65
50
210
1.6
430
7.9
68
50
190
2.0
380
7.9
63
50
170
2.2
340
J
7.9
60
50
160
3.2
300
3.3
J
7.9
60
50
145
3.8
270
3.9
J
7.9
61
50
130
5.0
240
CS1812-4R7□-N
4.7
J
7.9
60
50
115
5.4
230
CS1812-5R6□-N
5.6
J
7.9
42
50
100
5.7
220
CS1812-6R8□-N
6.8
J
7.9
32
50
90
6.6
210
CS1812-8R2□-N
8.2
J
7.9
35
50
80
7.0
200
CS1812-100□-N
10
J
7.9
27
50
70
7.7
190
CS1812-120□-N
12
J
2.5
34
10
58
8.7
180
CS1812-150□-N
15
J
2.5
32
10
48
9.6
170
CS1812-180□-N
18
J
2.5
28
10
36
10.5
160
CS1812-220□-N
22
J
2.5
28
10
34
11.5
155
CS1812-270□-N
27
J
2.5
28
10
30
12.5
150
CS1812-330□-N
33
J
2.5
145
Part Number
Frequency
Min
(MHz)
Frequency
(MHz)
Measure Equipment:
RDC:Chroma 16502
80
40
35
70
270
60
25
50
Q
L(nH)
1R5
30
3R3
40
100
100
30
15
5R6
10
5R6
270
3R3
10
5
1R5
10
FREQUENCY(MHz)
100
1000
1
10
100
FREQUENCY(MHz)
1000
Packaging Specifications
Tape Dimensions
Tape Material
Figure 1
Figure 2
Figure 3
Reel Dimensions
Dimensions in mm
TYPE
Tape Dimensions
Fig.
Reel Dimensions
Quantity
A
B
T
W
P
F
K
A
B
C
D
PCS / Reel
CS0201
1
0.47
0.57
0.65
8
2
3.5
0.45
178
60
12
1.5
4000
CS0402
1
0.67
1.20
0.75
8
2
3.5
0.59
178
60
12
1.5
4000
CS0603
2
1.20
1.80
1.05
8
4
3.5
178
60
12
1.5
4000
CS0805
3
1.85
2.45
0.23
8
4
3.5
1.50
178
60
12
1.5
2000
CS1008
3
2.80
2.95
0.23
8
4
3.5
2.20
178
60
12
1.5
2000
CS1812
3
3.90
4.90
0.30
12
8
5.5
3.20
178
60
16
1.4
600
很抱歉,暂时无法提供与“CS0805-R47J-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39842
- 100+0.32584
- 300+0.28955
- 2000+0.23836
- 4000+0.21665
- 10000+0.20574
- 国内价格
- 1+0.43670
- 50+0.25740
- 2000+0.23100
