SMD Multilayer Ferrite Chip Beads
Chilisin offers a wide range of multi-layered ferrite chip beads with various
sizes, frequency characteristics, and impedance values for EMI solutions.
These ferrite formulas are used to compose seven types of EMI
suppression chip beads: BBSY, BBBK, BBSJ, BBGK, BBPY, BBUP,
BBNQ, BBFY, BBFJ and BBHV series.
Product Identification
Shape and Dimensions
Recommended Pattern
Dimensions in mm
Dimensions in mm
TYPE
A
B
C
D
TYPE
A
B
C
060303
0.60.03
0.300.03
0.30.03
0.150.05
060303
0.2 ~ 0.3
0.75 ~ 1.05
0.3
100505
1.00.10
0.500.10
0.50.10
0.250.10
100505
0.4
1.2 ~ 1.4
0.5
160805
1.60.15
0.800.15
0.50.15
0.30.2
160805
0.7 ~ 0.8
1.8 ~ 2.0
0.6 ~ 0.8
160808
1.60.15
0.800.15
0.80.15
0.30.2
160808
0.7 ~ 0.8
1.8 ~ 2.0
0.6 ~ 0.8
201209
2.00.20
1.250.20
0.90.20
0.50.3
201209
1.0 ~ 1.2
2.6 ~ 4.0
1.0 ~ 1.4
321611
3.20.20
1.600.20
1.10.20
0.50.3
321611
2.0
4.2 ~ 5.2
1.3 ~ 1.9
453215
4.50.25
3.200.20
1.50.20
0.50.3
453215
3.0
5.5 ~ 6.5
2.4
:BBSY / BBSJ / BBNQ / BBPY
* Don’t apply narrower pattern than listed above to BBPY and BBUP
:BBSY / BBSJ / BBNQ / BBPY / BBUP / BBFY / BBFJ
Narrow pattern might cause excessive heat or open circuit.
:BBUP :BBBK / BBSJ / BBGK / BBPY / BBNQ / BBUP / BBHV
:BBBK / BBGK / BBPY / BBUP :BBSY / BBBK / BBPY / BBUP
:BBPY / BBUP
Dimension Conversion
Code
Dimension in mm
(AxBxC)
EIA
060303
0.6X0.3X0.3
0201
100505
1.0X0.5X0.5
0402
160805
1.6x0.8x0.5
0603
160808
1.6x0.8x0.8
0603
201209
2.0x1.2x0.9
0805
321611
3.2x1.6x.1.1
1206
453215
4.5x3.2x1.5
1812
SMD Multilayer Ferrite Chip Beads – BBPY Series
Electrical Characteristics
Impedance
Test Frequency
RDC
Rated current
(Ω±25%)
(MHz)
(Ω) Max
(mA) Max
BBPY00060303100Y00
10
100
0.050
1000
BBPY00060303220Y00
22
100
0.065
1000
BBPY00060303330Y00
33
100
0.090
750
BBPY00060303470Y00
47
100
0.120
500
BBPY00060303800Y00
80
100
0.180
500
BBPY00060303121Y00
120
100
0.230
450
BBPY00060303241Y00
240
100
0.400
350
BBPY00060303331Y00
330
100
0.500
300
Part Number
Note: When ordering, please specify tolerance code. Tolerance : Y=±25%
Operating temperature range-55℃~125℃(Including self - temperature rise)
Rate Current:Applied the current to coils, the temperature rise shall not be more than 30℃
Measure Equipment:
Z:HP4291A
RDC:HP4338B or CHEN HWA 502
Test Instruments:Agilent E4991A Impedance / Material Analyzer
BBPY00060303220Y00
16
35
14
Z
12
10
8
X
6
4
30
Z
25
X
10
R
2
BBPY00060303330Y00
100
IMPECANCE(Ω)
40
IMPEDANCE(Ω)
IMPEDANCE(Ω)
BBPY00060303100Y00
18
5
1
10
100
Z
40
X
R
1000
60
R
FREQUENCY (MHz)
RDC
很抱歉,暂时无法提供与“BBPY00201209102Y00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.13479
- 500+0.10790
- 1500+0.09299
- 4000+0.07506
- 24000+0.06740
- 48000+0.06318
- 国内价格
- 1+0.05860
- 100+0.05630
- 500+0.05320
- 1000+0.05140
