GBK160808T-700Y-N
GBK160808T-700Y-N
    CHILISIN(奇力新)
    单路 0603磁珠 阻抗70Ω@100MHZ
GBK160808T-700Y-N 数据手册
Cautions and Warnings Please be noted that this spec is only for reference if you have projects designed with the product number listed in. If you are looking for new project design-in, please find BBGK Series specification/datasheet on Chilisin website. Or you may find our sales contact for more information on old part number at your convenience. Appreciated your attention and understanding. Note: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Multilayer Ferrite Chip Beads Multilayer Ferrite Chip Beads Chilisin offers a wide range of multi-layered ferrite chip beads with various sizes, frequency characteristics, and impedance values for EMI solutions. These ferrite formulas are used to compose seven types of EMI suppression chip beads: SB, GB, PB, UPB, NB, HF, and VPB series. Product Identification  Product symbol: SB, GB, PB, UPB, NB, HF, VPB  Packaging: T:Tape and Reel;B:Bulk  Tolerance: Y = ± 25%; M = ± 20%; T:±30%  Note: RoHS Compliant Shape and Dimensions Recommended Pattern Dimensions in mm Dimensions in mm TYPE A B C D TYPE A B C 060303 0.60.03 0.300.03 0.30.03 0.150.05 060303 0.2 ~ 0.3 0.75 ~ 1.05 0.3 100505 1.00.10 0.500.10 0.50.10 0.250.10 100505 0.4 1.2 ~ 1.4 0.5 160805 1.60.15 0.800.15 0.50.15 0.30.2 160805 0.7 ~ 0.8 1.8 ~ 2.0 0.6 ~ 0.8 160808 1.60.15 0.800.15 0.80.15 0.30.2 160808 0.7 ~ 0.8 1.8 ~ 2.0 0.6 ~ 0.8 201209 2.00.20 1.250.20 0.90.20 0.50.3 201209 1.0 ~ 1.2 2.6 ~ 4.0 1.0 ~ 1.2 321611 3.20.20 1.600.20 1.10.20 0.50.3 321611 2.0 4.2 ~ 5.2 1.2 :SBY / SBJ / NB / PB :UPB :SBY / SBJ / NB / PB / UPB / HF :SBK / SBJ / GB / PB / NB / UPB / VPB :SBK / GB / PB / UPB :SBY / SBK / PBY / UPB Dimension Conversion Code Dimension in mm (AxBxC) EIA 060303 0.6X0.3X0.3 0201 100505 1.0X0.5X0.5 0402 160805 1.6x0.8x0.5 0603 160808 1.6x0.8x0.8 0603 201209 2.0x1.2x0.9 0805 321611 3.2x1.6x.1.1 1206 * Don’t apply narrower pattern than listed above to PBY and UPB. Narrow pattern might cause excessive heat or open circuit. SMD Multilayer Ferrite Chip Beads – GBK Series Electrical Characteristics Impedance Test Frequency RDC Rated current (Ω±25%) (MHz) (Ω) Max (mA) Max 30 100 0.06 800 GBK160808T-600Y-N 60 100 0.06 700 GBK160808T-101Y-N 100 100 0.15 600 GBK160808T-121Y-N 120 100 0.15 600 GBK160808T-221Y-N 220 100 0.18 550 GBK160808T-301Y-N 300 100 0.25 500 GBK160808T-601Y-N 600 100 0.30 400 GBK160808T-102Y-N 1000 100 0.45 300 GBK160808T-152Y-N 1500 100 0.70 150 Part Number GBK160808T-300Y-N Note: When ordering, please specify tolerance code. Tolerance : Y=±25%  Operating temperature range-55℃~125℃(Including self - temperature rise)  Rate Current:Applied the current to coils, the temperature rise shall not be more than 30℃  Measure Equipment: Z:HP4291A RDC:HP4338B or CHEN HWA 502 Test Instruments:Agilent E4991A Impedance / Material Analyzer 45 40 80 160 35 30 Z 25 20 15 X 10 5 10 70 Z 60 50 40 30 X 20 10 R 1 R 120 Z 100 80 60 X 40 R 0 1 1000 140 20 0 100 10 100 1000 1 FREQUENCY (MHz) RDC< 0.06 Ω Rated Current :700 mA FREQUENCY (MHz) RDC< 0.06 Ω Rated Current :800 mA GBK160808T-121Y-N 180 160 300 400 350 Z 80 60 X 40 20 Z 200 150 100 X 10 100 1 1000 10 600 Z 400 300 X R 10 1 100 1000 10 100 1000 FREQUENCY (MHz) RDC< 0.25 Ω Rated Current :500 mA GBK160808T-152Y-N 1600 1000 800 Z 600 400 X 1 10 1400 Z 1200 1000 800 600 400 R 200 R 0 FREQUENCY (MHz) RDC< 0.3 Ω Rated Current :400 mA R 1800 200 0 1 X 100 1000 IMPEDANCE(Ω) IMPEDANCE(Ω) 700 100 150 0 100 1200 200 200 GBK160808T-102Y-N GBK160808T-601Y-N 800 500 250 FREQUENCY (MHz) RDC< 0.18 Ω Rated Current :550 mA FREQUENCY (MHz) RDC< 0.15 Ω Rated Current :600 mA 1000 Z 300 50 R 0 0 1 250 50 R IMPEDANCE(Ω) 450 120 100 100 GBK160808T-301Y-N GBK160808T-221Y-N 350 140 10 FREQUENCY (MHz) RDC< 0.15 Ω Rated Current :600 mA 200 IMPEDANCE(Ω) IMPEDANCE(Ω) IMPEDANCE(Ω) 180 0 IMPEDANCE(Ω) GBK160808T-101Y-N GBK160808T-600Y-N 90 IMPEDANCE(Ω) IMPEDANCE( Ω) GBK160808T-300Y-N 50 X 0 100 1000 FREQUENCY (MHz) RDC< 0.45 Ω Rated Current :300 mA Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1 10 100 FREQUENCY (MHz) RDC< 0.7 Ω Rated Current :150 mA 1000 SMD Multilayer Ferrite Chip Beads – GBK Series Electrical Characteristics Impedance Test Frequency RDC Rated current (Ω±25%) (MHz) (Ω) Max (mA) Max GBK201209T-600Y-N 60 100 0.10 900 GBK201209T-121Y-N 120 100 0.15 800 GBK201209T-221Y-N 220 100 0.18 750 GBK201209T-301Y-N 300 100 0.18 700 GBK201209T-601Y-N 600 100 0.25 500 GBK201209T-102Y-N 1000 100 0.30 400 GBK201209T-152Y-N 1500 100 0.40 400 GBK201209T-202Y-N 2000 100 0.55 400 Part Number Note: When ordering, please specify tolerance code. Tolerance : Y=±25%  Operating temperature range-55℃~125℃(Including self - temperature rise)  Rate Current:Applied the current to coils, the temperature rise shall not be more than 30℃  Measure Equipment: Z:HP4291A RDC:HP4338B or CHEN HWA 502 Test Instruments:Agilent E4991A Impedance / Material Analyzer GBK201209T-600Y-N GBK201209T-121Y-N 90 Z 60 50 40 X 30 20 140 Z 120 100 80 60 40 R X 100 1000 1 FREQUENCY (MHz) RDC
GBK160808T-700Y-N 价格&库存
很抱歉,暂时无法提供与“GBK160808T-700Y-N”相匹配的价格&库存,您可以联系我们找货
