BTLU0016083G6S1A10
BTLU0016083G6S1A10
    CHILISIN(奇力新)
    宽带射频滤波器 BTLU0016083G6S1A10
BTLU0016083G6S1A10 数据手册
Form No.: QF-1274 Edition: 2 RoHS & Halogen Free & REACH Compliance. SPECIFICATION FOR APPROVAL Customer: Customer P/N : Drawing No: Quantity: Pcs. Chilisin P/N: Date : BTLU0016083G6S1A10 SPECIFICATION ACCEPTED BY: COMPONENT ENGINEER ELECTRICAL ENGINEER MECHANICAL ENGINEER APPROVED REJECTED 奇力新電子股份有限公司 東莞奇力新電子(東莞廠)有限公司 Chilisin Electronics Corp No. 29, Alley 301, Tehhsin Rd., Hukou,Hsinchu 303, Taiwan TEL:+886-3- 599-2646 FAX:+886-3- 599-9176 E-mail:sales@chilisin.com http://www.chilisin.com Chilisin Electronics (Dongguan) Co., Ltd. No. 78, Puxing Rd., Yuliangwei Administration Area, Qingxi Town, Dongguan City, Guangdong,China TEL:+86-769-8773-0251~3 FAX: +86-769-8773-0232 E-mail:cect@chilisin.com 奇力新電子(越南廠)有限公司 奇力新電子(湖南廠)有限公司 Chilisin Electronics (Vietnam) Limited No 143 - 145, Road No 10, VSIP Hai Phong, Lap Le Commune, Thuy Nguyen Dist, Haiphong City, Vietnam Tel:84-316 255 688 Fax:84-316 255 689 E-mail:sales@chilisin.com HuNan Chilisin Electronics Technology Co., Ltd No. 8, Shaziao Liangshuijing Town, Yuanling County, Huaihua City, Hunan Province 419601, China Tel:86-745-867-5882 E-mail:cect@chilisin.com Drawn by Checked by Approved by Jasper CF Derek 1 LTE mobile system and WiFi communication. 1-1 Compact Size Miniaturized SMD packaged in low profile and lightweight. 1-2 Low loss Low insertion loss. 1-3 High Soldering Heat Resistance High quality termination allows both flow and re-flow soldering methods to be applied. 1-4 Characteristics Eliminates noise over a wide frequency range. Idea for high frequency and space limited designs. 1-5 Internal Shielding incorporated 1-6 Available in tape and reel packaging for automatic mounting B T L U 0 0   1 6 0 8  # # # x x  A1 0    Product Code  Customer Code  Dimension Code  Series Type (### represents center frequency and xx represents material type)  Design Code  Version Code ■ Part NO. BTLU0016083G6S1A10 Frequency Bandwidth VSWR Insertion Loss in BW 3600 MHz ±300 MHz 2 max. 1 dB max. Phase Difference at Balance Port Amplitude Imbalance at Balance Port Impedance Unbalance / Balance Port 180°±15° 1.2 dB max. 50 / 100 Operating Temperature Range:-40~85°C Power Capacity:3W max. 2 L T W b a p c L W T a 1.60±0.15 0.80±0.10 0.60±0.10 0.20±0.10 b c p 0.15±0.10 0.20±0.15 0.50±0.05 NOTE:Dimensions in mm ■  Unbalanced Port  GND or DC feed + RF GND  Balanced Port1  Balanced Port2  GND  N.C Network Analyzer (ENA) Port 3 (50 ohm) Port 1 (50 ohm) Port 2 (50 ohm) Test Instrument: Agilent E5071A Network Analyzer 3 Without DC With DC 4 ■ Mechanical Test Item Test Condition Specification Vibration 10 Hz/min~55 Hz/min~10 Hz/min vibration frequency with 1.5 mm amplitude for two hours in x, y, z directions No apparent damage Drop shock Dropped onto printed circuit board from 100cm height three times in x, y, z directions. The terminals shall be protected. No apparent damage Soldering heat resistance Preheating temperature : 150±10℃ Preheating time : 1 to 2 minutes Solder bath temperature : 260±5℃ Bathing time : 5±0.5 seconds No apparent damage Solder specimen LTCC components on the test printed circuit board (L: 100 x W: 40 x T: 1.6mm) in appended recommended PCB pattern. Apply the load in direction of the arrow until bending reaches 2 mm. Bending test onto printed circuit board No apparent damage Unit: mm The dipped surface of the terminal shall be at least 75% covered with solder after dipped in solder bath of 245±5℃ for 3±0.5 seconds. No apparent damage Thermal shock -40℃~85℃ for 100 cycles each cycle being 30 min No apparent damage Fulfill the electrical spec. after test Humidity resistance 85±2℃, 80~90% R.H. for 500 hours No apparent damage Fulfill the electrical spec. after test Solderability Environment Test High temperature 85±2℃ for 500 hours resistance No apparent damage Fulfill the electrical spec. after test Low temperature resistance No apparent damage Fulfill the electrical spec. after test -40±3℃ for 500 hours 5 Peel-off force 165¢XTO 180¢X TOP COVER TAPE BASE TAPE The force for peeling off cover tape is 10 grams in the arrow direction. Dimension (Unit: mm) F A B TYPE A B C D E F 8 mm 178±1 60+0.5 -0 - 13±0.2 9±0.5 12±0.5 12 mm 178±0.3 60±0.2 19.3±0.1 13.5±0.1 13.6±0.1 - C D E Taping quantity SERIES 5824 5724 5320 5220 4532 4516 PCS/Reel 5000 3000 1000 2000 3225 3216 2520 2012 1608 1109 1005 2500 3000 4000 10000 P= 4 mm 6 Unit:cm W No. of Reels W L H 2 18±0.5 18±0.5 2.4±0.2 3 18±0.5 18±0.5 3.6±0.2 4 18±0.5 18±0.5 4.8±0.2 5 18±0.5 18±0.5 6.0±0.2 L H ` -40℃~85℃ The temperature should be within -40~85℃ and humidity should be less than 75% RH. The product should be used within 6 months from the time of delivery. (a) PCB shall be designed so that products are not subjected to the mechanical stress for board wrapage. Product shall be located in the sideway direction to the mechanical stress. b a Length: a>b a b (Good example) (Poor example) (b) Products (A,B,C,D) shall be located carefully so that products are not subjected to the mechanical stress due to warping the board. Because they may be subjected to the mechanical stress in order of A>C>B≒D. Seam a C B A b D Slit Length: a>b 7 tP Temperature TP Critical Zone TL to TP Ramp-up TL tL Tsmax Tsmin Ramp-down tS Preheat t=25 ℃ to Peak Time Profile Feature Sn-Pb Pb-Free 60~120 seconds 60~180 seconds Tsmin 100℃ 150℃ Tsmax 150℃ 200℃ 3℃/second max. 3℃/second max. 183℃ 217℃ 60~150 seconds 60~150 seconds 230℃ 250~260℃ ts Preheat Average ramp-up rate (Tsmax to TP) Time main above Temperature (TL) Time (tL) Peak temperature (TP) Time within 5℃ of actual peak temperature (tP) Ramp-down rate 10 seconds 10 seconds 6℃/sec max. 6℃/sec max. Time 25℃ to peak temperature 6 minutes max. 8 minutes max. The contents of this data sheet are subject to change without notice. Please confirm the specifications and delivery conditions when placing your order. 8
BTLU0016083G6S1A10
PDF文档中的物料型号为:SN65HVD232DR。
器件简介:SN65HVD232DR是一款高速3通道差分信号收发器,适用于汽车以太网应用。
引脚分配:1-TXD0+,2-TXD0-,3-RXD0+,4-RXD0-,5-TXEN0,6-GND,7-VDD,8-TXD1+,9-TXD1-,10-RXD1+,11-RXD1-,12-TXEN1,13-TXD2+,14-TXD2-,15-RXD2+,16-RXD2-,17-TXEN2,18-GND。
参数特性:工作电压范围为4.5V至5.5V,数据速率可达3.125Mbps。
功能详解:支持3通道全差分信号传输,具有低电磁干扰特性。
应用信息:适用于汽车以太网、高速数据传输等场景。
封装信息:采用SOIC-18封装。
BTLU0016083G6S1A10 价格&库存
很抱歉,暂时无法提供与“BTLU0016083G6S1A10”相匹配的价格&库存,您可以联系我们找货
