HFY100505T-601Y-N
HFY100505T-601Y-N
    CHILISIN(奇力新)
HFY100505T-601Y-N 数据手册
Cautions and Warnings Please be noted that this spec is only for reference if you have projects designed with the product number listed in. If you are looking for new project design-in, please find BBFY Series specification/datasheet on Chilisin website. Or you may find our sales contact for more information on old part number at your convenience. Appreciated your attention and understanding. Note: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Multilayer Ferrite Chip Beads Multilayer Ferrite Chip Beads Chilisin offers a wide range of multi-layered ferrite chip beads with various sizes, frequency characteristics, and impedance values for EMI solutions. These ferrite formulas are used to compose seven types of EMI suppression chip beads: SB, GB, PB, UPB, NB, HF, and VPB series. Product Identification  Product symbol: SB, GB, PB, UPB, NB, HF, VPB  Packaging: T:Tape and Reel;B:Bulk  Tolerance: Y = ± 25%; M = ± 20%; T:±30%  Note: RoHS Compliant Shape and Dimensions Recommended Pattern Dimensions in mm Dimensions in mm TYPE A B C D TYPE A B C 060303 0.60.03 0.300.03 0.30.03 0.150.05 060303 0.2 ~ 0.3 0.75 ~ 1.05 0.3 100505 1.00.10 0.500.10 0.50.10 0.250.10 100505 0.4 1.2 ~ 1.4 0.5 160805 1.60.15 0.800.15 0.50.15 0.30.2 160805 0.7 ~ 0.8 1.8 ~ 2.0 0.6 ~ 0.8 160808 1.60.15 0.800.15 0.80.15 0.30.2 160808 0.7 ~ 0.8 1.8 ~ 2.0 0.6 ~ 0.8 201209 2.00.20 1.250.20 0.90.20 0.50.3 201209 1.0 ~ 1.2 2.6 ~ 4.0 1.0 ~ 1.2 321611 3.20.20 1.600.20 1.10.20 0.50.3 321611 2.0 4.2 ~ 5.2 1.2 :SBY / SBJ / NB / PB :UPB :SBY / SBJ / NB / PB / UPB / HF :SBK / SBJ / GB / PB / NB / UPB / VPB :SBK / GB / PB / UPB :SBY / SBK / PBY / UPB Dimension Conversion Code Dimension in mm (AxBxC) EIA 060303 0.6X0.3X0.3 0201 100505 1.0X0.5X0.5 0402 160805 1.6x0.8x0.5 0603 160808 1.6x0.8x0.8 0603 201209 2.0x1.2x0.9 0805 321611 3.2x1.6x.1.1 1206 * Don’t apply narrower pattern than listed above to PBY and UPB. Narrow pattern might cause excessive heat or open circuit. SMD Multilayer Ferrite Chip Beads – HFY Series Electrical Characteristics Part Number Impedance Test Frequency Impedance Test Frequency RDC Rated current (Ω±25%) (MHz) (Ω±40%) (MHz) (Ω) Max (mA) Max HFY100505T-221Y-N 220 100 270 1000 0.55 450 HFY100505T-301Y-N 300 100 450 1000 0.55 350 HFY100505T-471Y-N 470 100 650 1000 0.60 300 HFY100505T-601Y-N 600 100 1000 1000 0.7 300 HFY100505T-102Y-N 1000 100 1400 1000 1.1 250 Note: When ordering, please specify tolerance code. Tolerance : Y=±25%  Operating temperature range-55℃~125℃(Including self - temperature rise)  Rate Current:Applied the current to coils, the temperature rise shall not be more than 30℃  Measure Equipment: Z:HP4291A RDC:HP4338B or CHEN HWA 502 Test Instruments:Agilent E4991A Impedance / Material Analyzer HFY100505T-471Y-N 300 700 250 Z 200 150 100 X 50 600 500 Z 400 300 200 X 100 R 0 10 100 1000 10000 FREQUENCY(MHz) RDC
HFY100505T-601Y-N 价格&库存
很抱歉,暂时无法提供与“HFY100505T-601Y-N”相匹配的价格&库存,您可以联系我们找货
