FFC2A32-40-T
FFC2A32-40-T
    GCT
    SMD,P=0.5mm(交错脚)
    FPC/FFC连接器 间距:0.50mm 40Pin 抽屉式 立贴
FFC2A32-40-T 数据手册
PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX B Rev 0.5mm Pitch ZIF FPC 0.5mm FFC Spec Prepared PN Checked SA Date 16/06/10 Page 1 Approved Top Entry Side Entry Side Entry (Slide Actuator) (Flip Type Actuator) www.gct.co   LH PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX B Rev 0.5mm Pitch ZIF FPC 0.5mm FFC Spec Prepared PN Checked SA Date 16/06/10 Page 2 Approved LH 1.0 SCOPE.   This specification covers performance, tests and quality requirements for 0.5mm Pitch ZIF FPC Connector     2.0 APPLICABLE DOCUMENTS. EIA-364 Electronics Industries Association     3.0 REQUIREMENTS. 3.1 Design and Construction Product shall be of design, construction and physical dimensions specified on applicable product drawing.     3.2 Materials and Finish 3.2.1 Housing: High-Temp Plastic LCP (UL94V-0), White 3.2.2 Actuator: LCP (UL94V-0), Black 3.2.3 Contact: High performance copper alloy (phosphor bronze) Finish: (a) Finish: see ordering information (b) Under-plate: Nickel-plated all over 3.2.4 Fitting Nail: Brass, Tin-plated overall 3.3 Ratings 3.3.1 Voltage rating: 50V AC 3.3.2 Current rating: 0.4A 3.3.3 Operating Temperature Range: -25°C to +85°C     www.gct.co   PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX B Rev 0.5mm Pitch ZIF FPC 0.5mm FFC Spec Prepared PN Checked SA Date 16/06/10 Page 3 Approved LH 4.0 PERFORMANCE. Item Test Condition Requirement Examination of Product Visual, dimensional and functional per applicable quality inspection plan. Product shall meet requirements of applicable product drawing and specification. Item Test Condition Requirement Low-signal Level Contact Resistance Mate connectors, measure by dry circuit, 20mV Max., 100mA Max, in accordance with EIA-364-23. 20 m Ω Max.(initial)per contact 40 m Ω Max. Change allowed. Insulation Resistance Unmated connectors, apply 500 V DC between adjacent terminals, in accordance with EIA-364-21. 50 M Ω Min. Dielectric Withstanding Voltage Test between adjacent contacts of unmated connectors, in accordance with EIA-364-20. 250 VAC Min. at sea level for 1 minute. No discharge, flashover or breakdown. Current leakage: 0.5 mA max. Temperature Rise Mate connector: measure the temperature rise at rated current after: 0.5 A/Power contact. The temperature rise above ambient shall not exceed 30°C The ambient condition is still air at 25°C In accordance with EIA-364-70, METHOD 2. 30°C Max. Change allowed 4.1 Electrical Performance. 4.2 Mechanical Performance. Item Test Condition Requirement Durability The sample should be mounted in the tester and fully mated and unmated the number of cycles specified at the rate of 10±3mm/min. In accordance with EIA-364-09. 20 cycles FPC Retention Force Insert the actuator, pull the FPC at the speed rate of 10±3 mm/min. Refer to FPC withdrawal force Refer to GROUP 8 www.gct.co   PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX B Rev 0.5mm Pitch ZIF FPC 0.5mm FFC Spec Prepared PN Checked SA Date 16/06/10 Page 4 Approved Item Test Condition Requirement Repeated Actuator Insertion/Withdrawal Insert and withdraw actuator up to 20 cycles at the speed rate of less than 10 cycles/minute. 60 mΩ Max. Terminal/Housing Retention Force Apply axial pull out force at the speed rate of 10±3 mm/minute. On the terminal assembled in the housing. 0.15kgf MIN. Fitting Nail/Housing Retention Force Vibration Shock (Mechanical) Apply axial pull out force at the speed rate of 10± 3 mm/minute. On the fitting nail assembled in the housing. The electrical load condition shall be 100 mA maximum for all contacts. Subject to a simple harmonic motion having amplitude of 0.76mm (1.52mm maximum total excursion) in frequency between the limits of 10 and 55 Hz. The entire frequency range, from 10 to 55 Hz and return to 10 Hz, shall be traversed in approximately 1 minute. This motion shall be applied for 2 hours in each of three mutually perpendicular directions. In accordance with EIA-364-28, Condition I. Subject mated connectors to 50 G’s (peak value) half-sine shock pulses of 11 milliseconds duration. Three shocks in each direction shall be applied along the three mutually perpendicular axes of the test specimen (18 shocks). The electrical load condition shall be 100mA maximum for all contacts. In accordance with EIA-364-27, test condition A. www.gct.co   0.01kgf MIN. No Damage 60mΩ MAX 1 u sec Max. No Damage 60mΩ MAX 1 u sec Max. LH PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX B Rev 0.5mm Pitch ZIF FPC 0.5mm FFC Spec Prepared PN Checked Date 16/06/10 Page 5 SA Approved LH 4.3 Environmental Performance. Item Test Condition Requirement Resistance to Reflow Soldering Heat Pre Heat: 150°C ~180°C, 60~90sec. Heat: 230°C Min., 40sec Min. Peak Temp.: 260°C Max, 10sec Max. See Product Qualification and Test Sequence Group 9 Resistance to Hand Soldering Heat Soldering iron:350±10°C Duration:3~4 sec. Excessive pressure shall not be applied to the terminals. See Product Qualification and Test Sequence Group 10 Thermal Shock Humidity Temperature Life SO2 Gas Salt Spray Solderability Mate module and subject to follow condition for 5 cycles. 1 cycles: -40 +0/-3 °C, 30 minutes +85 +3/-0 °C, 30 minutes In accordance with EIA-364-32, test condition A. Mated Connector 40°C, 90~95% RH, Refer to Method II. In accordance with EIA-364-31, test condition A. Subject mated connectors to temperature life at 85°C for 96 hours. Measure Signal. In accordance with EIA-364-17, test condition A. Mate applicable FPC and expose them to the following SO2 gas atmosphere. Temperature: 40±2°C Gas Density: 50±5 ppm Duration: 24 hours Subject mated/unmated connectors to 5% salt-solution concentration, 35°C for 48 hours. In accordance with EIA-364-26, test condition B. Subject the test area of contacts into the flux for 5-10 sec. And then into solder bath, Temperature at 245 ±5°C, for 4-5 sec. In accordance with EIA-364-52. Test report available on request Note. Flowing Mixed Gas shell be conduct by customer request. www.gct.co   No Damage 60mΩ MAX 1 u sec Max No Damage 60mΩ MAX 20MΩ Min. No Damage 60mΩ MAX No Damage 60mΩ MAX No Damage 60mΩ MAX Solder able area shall have minimum of 95% solder coverage. - PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX B Rev 0.5mm Pitch ZIF FPC 0.5mm FFC Spec Prepared PN Checked 5.0 INFRA RED REFLOW CONDITION. 5.1 Lead-Free Process: Duration = 2 times 6.0 PRODUCT QUALIFICATION AND TEST SEQUENCE. www.gct.co   SA Date 16/06/10 Page 6 Approved LH PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX B Rev 0.5mm Pitch ZIF FPC 0.5mm FFC Spec PN Prepared SA Checked Date 16/06/10 Page 7 Approved LH Test Group Test or Examination 1 2 3 4 5 6 7 8 9 10 Test Sequence Examination of Product 1,7 1,6 1,4 1 2,10 2,9 2,5 3 Insulation Resistance 3,9 3,8 Dielectric Withstanding Voltage 4,8 4,7 Low-signal Level Contact Resistance Temperature Rise 1,5 1,4 1 Mating / Unmating Forces 2,4 Durability 3 Vibration 2 Shock (Mechanical) 3 Thermal Shock 5 Humidity 6 Temperature Life 5 Salt Spray 3 Solderability 1 Repeated Actuator Insertion/Withdrawal 1 FPC Retention Force 2 Terminal / Housing Retention Force 3 Fitting Nail / Housing Retention Force 4 Resistance to Soldering Heat 2 Resistance to Hand Soldering Heat Sample Size 1 2 4 4 4 7.0 FPC WITHDRAWAL FORCE. www.gct.co   4 4 2 4 4 4 PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX B Rev 0.5mm Pitch ZIF FPC 0.5mm FFC Spec No. Of Ckt. 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 Prepared Withdrawal Force (Min) 0.3Kgf 0.5Kgf 1.0Kgf PN Checked No. Of Ckt. 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 SA Date 16/06/10 Page 8 Approved Withdrawal Force (Min) 1.0Kgf 1.5Kgf Revision Details: Revision Information Page www.gct.co   Release Date LH PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX B Rev 0.5mm Pitch ZIF FPC 0.5mm FFC Spec Prepared PN Checked SA Date 16/06/10 Page 9 Approved A Specification Released - 16/06/2010 B Leaded temperature profile removed 6 26/11/2015   www.gct.co   LH
FFC2A32-40-T 价格&库存
很抱歉,暂时无法提供与“FFC2A32-40-T”相匹配的价格&库存,您可以联系我们找货
FFC2A32-40-T
  • 1+7.542901+0.97632
  • 10+6.3294010+0.81925
  • 25+5.9365425+0.76840
  • 50+5.6746350+0.73450
  • 100+5.42146100+0.70173
  • 250+5.08971250+0.65879
  • 500+4.86272500+0.62941
  • 1200+4.670661200+0.60455
库存:72
FFC2A32-40-T
    FFC2A32-40-T
    • 1+8.208221+1.06244
    • 10+6.9817910+0.90370
    • 25+6.5460825+0.84730
    • 50+6.2318550+0.80663
    • 100+5.93340100+0.76800
    • 250+5.56199250+0.71992
    • 500+5.29613500+0.68551
    库存:1363
    FFC2A32-40-T
      FFC2A32-40-T
      • 1200+4.978721200+0.64443
      • 2400+4.741132400+0.61368
      • 3600+4.607433600+0.59637
      • 6000+4.444426000+0.57527
      • 8400+4.340248400+0.56179
      • 12000+4.2324712000+0.54784
      库存:1363
