ES1006FL
SOD-123FL
FEATURES
Glass passivated device
Ideal for surface mouted applications
Low reverse leakage
Metallurgically bonded construction
High temperature soldering guaranteed:
250 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
1.8± 0.1
1.0±0.2
Cathode Band
Top View
1.3± 0.15
0.10-0.30
2.8±0.1
0.6±0.25
MECHANICAL DATA
Case: JEDEC SOD-123FL molded plastic body over passivated chip
Terminals: Plated axial leads, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0007 ounce, 0.02 grams
3.7±0.2
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Catalog
Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Maximum reverse recovery time (NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
ES1006FL
UNITS
VRRM
VRMS
VDC
600
420
600
VOLTS
VOLTS
VOLTS
I(AV)
1.0
Amp
IFSM
25.0
Amps
VF
1.7
Volts
IR
5.0
100.0
µA
trr
35
ns
CJ
10
RθJA
TJ,TSTG
85
-55 to +150
pF
K/W
C
SYMBOLS
Note: 1.Measured with IF=0.5A, IR=1A, Irr=0.25A.
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.PCB mounted on 0.2*0.2" (5.0*5.0mm) coppeer pad area.
www.yongyutai.com
PAGE 1
ES1006FL
RATINGS AND CHARACTERISTIC CURVES
1.0
0.8
0.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.4
0.2
50
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
75
100
125
150
30
10
5.0
1
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
1
0.1
0.01
0.4
0.8
1.2
1.6
1.8
1,000
100
10
TJ=100 C
1
0.1
TJ=25 C
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
www.yongyutai.com
40
60
80
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
REVERSE VOLTAGE,VOLTS
PERCENT OF PEAK REVERSE VOLTAGE,%
TRANSIENT THERMAL IMPEDANCE,
C/W
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
100
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
NUMBER OF CYCLES AT 60 Hz
AMBIENT TEMPERATURE, C
10
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
25
0.1
1
10
100
t,PULSE DURATION,sec.
PAGE 2
很抱歉,暂时无法提供与“ES1006FL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08694
- 500+0.06880
- 3000+0.05444
- 6000+0.04839
- 24000+0.04320
- 51000+0.04040
