DL5234B
DL5234B
    YONGYUTAI(永裕泰)
    LL-34
    DL5234B
DL5234B 数据手册
DL5221B THRU DL5263B FEATURE Low zener impedance Low regulation factor Glass passivated junction High temperature soldering guaranteed: 260 C/10S at terminals LL-34 0.063(1.6) 0.055(1.4) 0.020(0.5) 0.012(0.3) MECHANICAL DATA 0.020(0.5) 0.012(0.3) 0.146(3.7) 0.130(3.3) Case: MINI MELF molded glass body Terminals: Plated leads, solderable per MIL-STD 750, method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight: 0.002 ounce,0.05 grams MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Catalog Number Symbols Value Units Zener Current see Table Characteristics Ptot 500 mW Tj 200 C Storage Temperature Range TSTG -65 to + 200 C Thermal resistance junction ambient(Note 1) RθJA 0.3 K/mW VF 1.1 V Power Dissipation at Tamb=25 C(Note 1) Junction Temperature Forward voltage at IF=200mA Note 1: Valid provided that leads at a distance of 10mm from case are kept at ambient temperature www.yongyutai.com PAGE 1 ELECTRICAL CHARACTERISTICS (at TA=25 C unless otherwise noted) Device Type Nominal Zener Voltage Vz@IZT (Volts) Test Current IZT (mA) DL5221B 2.4 DL5222B 2.5 DL5223B 2.7 DL5224B 2.8 DL5225B 3.0 DL5226B 3.3 DL5227B 3.6 DL5228B 3.9 DL5229B 4.3 DL5230B 4.7 DL5231B 5.1 DL5232B 5.6 DL5233B 6.0 DL5234B 6.2 DL5235B 6.8 DL5236B 7.5 DL5237B 8.2 DL5238B 8.7 DL5239B 9.1 DL5240B 10 DL5241B 11 DL5242B 12 DL5243B 13 DL5244B 14 DL5245B 15 DL5246B 16 DL5247B 17 DL5248B 18 DL5249B 19 DL5250B 20 DL5251B 22 DL5252B 24 DL5253B 25 DL5254B 27 DL5255B 28 DL5256B 30 DL5257B 33 DL5258B 36 DL5259B 39 DL5260B 43 DL5261B 47 DL5262B 51 DL5263B 56 Note 1: Suffix “B” indicate +5% tolerance www.yongyutai.com 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 9.5 9.0 8.5 7.8 7.4 7.0 6.6 6.2 5.6 5.2 5.0 4.6 4.5 4.2 3.8 3.4 3.2 3.0 2.7 2.5 2.2 Maximum Maximum Reverse Typical Leakage Current Temperature Regulator Current Coefficient @VR ZZK@IZK=0.25mA IR IZM µA mA Ohms (%/ C) Volts Maximum Zener Impedance ZZT@IZT Ohms 30 30 30 30 29 28 24 23 22 19 17 11 7 7 5 6 8 8 10 17 22 30 13 15 16 17 19 21 23 25 29 33 35 41 44 49 58 70 80 93 150 125 150 1200 1250 1300 1400 1600 1600 1700 1900 2000 1900 1600 1600 1600 1000 750 500 500 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 700 700 800 900 1000 1100 1300 100 100 75 75 50 25 15 10 5.0 5.0 5.0 5.0 5.0 5.0 3.0 3.0 3.0 3.0 3.0 3.0 2.0 1.0 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 2.0 2.0 3.0 3.5 4.0 5.0 6.0 6.5 6.5 7.0 8.0 8.4 9.1 9.9 10 11 12 13 14 14 15 17 18 19 21 21 23 25 27 30 33 36 39 43 -0.085 -0.085 -0.080 -0.080 -0.075 -0.070 -0.065 -0.060 +0.055 +0.030 +0.030 +0.038 +0.038 +0.045 +0.050 +0.058 +0.062 +0.065 +0.068 +0.075 +0.076 +0.077 +0.079 +0.082 +0.082 +0.083 +0.084 +0.085 +0.085 +0.086 +0.087 +0.088 +0.089 +0.090 +0.091 +0.091 +0.092 +0.093 +0.094 +0.095 +0.095 +0.096 +0.096 191 182 168 162 151 138 126 115 106 97 89 81 76 73 67 61 55 52 50 45 41 38 35 32 30 28 27 25 24 23 21.2 19.1 18.2 16.8 16.2 15.1 13.8 12.6 11.5 10.6 9.7 8.9 8.1 PAGE 2 RATINGS AND CHARACTERISTIC CURVES DL/ZMM52 SERIES Breakdown characteristics 5 mA 10 15 20 25 Iz,TEST CURRENT,MILLIAMPERS 50 30 V 40 30 Test Current Iz=20mA 20 10 DL5252B DL5250B DL5245B DL5242B DL5241B DL5239B DL5235B DL5234B DL5232B DL5231B DL5230B DL5229B DL5228B DL5224B 0 Vz,ZENER VOLTAGE,volts Ptot,POWER DISSIPATION,MILLIWATTS Admissible power dissipation versus ambient temperature Valid provided that leads are kept at ambient temperature at a distance of 10mm from case 500 400 300 200 100 0 0 50 100 150 200 250 AMBIENT TEMPERATURE, C The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)! www.yongyutai.com PAGE 3
DL5234B 价格&库存
很抱歉,暂时无法提供与“DL5234B”相匹配的价格&库存,您可以联系我们找货
DL5234B
    • 2500+0.05832
    • 2500+0.05589
