Powder Molding Type
BCIHP04SC-Series
● Photograph picture
BCIHP04SC
● Dimensions
XXX
ITEM
A(mm)
B(mm)
BCIHP0412SC-Series 4.2±0.25 4.4±0.4
BCIHP0420SC-Series 4.2±0.25 4.4±0.4
C(mm)
1.2MAX
2.0MAX
D(mm)
1.5±0.5
1.5±0.5
E(mm) a(mm) b(mm) c(mm)
1.0±0.5 2.2
5.2
2.5
1.0±0.5 2.2
5.2
2.5
● Part Numbering
BCIHP
0420SC – 4R7
M
S
A
B
C
D
A:Series(系列代號)
B:Dimension( 尺 寸 )
B×C
C:Inductance( 電 感 值 )
4R7=4.7uH
D:Inductance Tolerance(電感值公差) M=±20% N=±30%
● Features
1.
2.
3.
4.
5.
Compliance with RoHs.
Lowest DCR.
Frequency range up to 3.0MHz.
Handles high transient current spikes without saturation
Ultra low buzz noise, due to composite construction.
● Applications
1. DC/DC converter for CPU in Notebook PC.
2. Battery powered devices.
3. Cellular phones LCD displays, HDDs, DVCs, DSCs,
PDA etc.
4. Thin type on-board power supply module.
TEL:+86-756-3383909
TAX:+86-756-3380704
● 特點
1.
2.
3.
4.
5.
符合 RoHs.
低電阻.
頻率可達到 3.0 MHz.
可處理在未飽和時的高瞬間電流.
設計緊湊/超低噪音
● 應用
1. 用於筆記本電腦處理器的DC/DC 轉換設備.
2. 電源,電池設備.
3. 適用於手機液晶屏顯示,HDD, DVC, DSC,
PDA 等.
4. 薄型車載電源模組.
Bao Cheng Electronics Corp Ltd
www.baocheng.biz
20 JUN 2016
TAPE BCIHP0730SC-Series P: 1 / 9
Powder Molding Type
BCIHP04SC-Series
● Specification
ITEM
BCIHP0412SC-R15M
BCIHP0412SC-R22M
BCIHP0412SC-R33M
BCIHP0412SC-R47M
BCIHP0412SC-R68M
BCIHP0412SC-1R0M
BCIHP0412SC-1R5M
BCIHP0412SC-2R2M
BCIHP0412SC-4R7M
BCIHP0420SC-R10M
BCIHP0420SC-R22M
BCIHP0420SC-R33M
BCIHP0420SC-R47M
BCIHP0420SC-R56M
BCIHP0420SC-R68M
BCIHP0420SC-1R0M
BCIHP0420SC-1R2M
BCIHP0420SC-1R5M
BCIHP0420SC-2R2M
BCIHP0420SC-3R3M
BCIHP0420SC-4R7M
BCIHP0420SC-6R8M
BCIHP0420SC-100M
BCIHP0420SC-220M
TEL:+86-756-3383909
TAX:+86-756-3380704
INDUCTANCE uH DCR mΩ
@100KHZ,1.0V,0A(1)
25℃ MAX.
0.15
0.22
0.33
0.47
0.68
1.0
1.5
2.2
4.7
0.1
0.22
0.33
0.47
0.56
0.68
1.0
1.2
1.5
2.2
3.3
4.7
6.8
10.0
22.0
9.0
11.0
19.0
21.0
36.0
47.0
75.0
83.5
195.0
4.0
6.6
11.0
14.0
16.0
21.0
27.0
27.0
46.0
58.0
87.0
126.0
175.0
282.0
363.0
HEAT RATING
SATURATION
CURRENT DC AMPS CURRENT DC AMPS
(5)
(6)
TYPICAL(Irms)
TYPICAL(Isat)
7.5
15.0
7.0
11.0
6.0
8.4
6.0
6.8
4.7
6.0
4.5
5.5
3.25
4.0
2.75
3.0
1.8
2.2
12.0
22.0
9.0
12.5
8.0
12.0
7.0
9.5
6.5
9.3
5.2
8.0
4.5
7.0
4.5
6.5
4.0
5.5
3.0
5.0
2.5
4.0
2.2
3.0
1.6
2.5
1.3
2.0
1.2
1.4
www.baocheng.biz
20 JUN 2016
TAPE BCIHP0730SC-Series P: 2 / 9
Powder Molding Type
BCIHP04SC-Series
Note:
(1)
(2)
(3)
(4)
(5)
(6)
(7)
Tolerance of Inductance: N=±30% ,M=±20%.
All test data is referenced to 25℃ ambient.
Inductance is measured at 100KHz. 25℃ ambient.
Operating Temperature Range-50℃ to +125℃.
DC current (Irms) (A) that will cause an approximate △T of 40℃.
DC current (Isat) (A) that will cause Lo to drop approximately 30%.
The part Temperature (ambient + temp rise) should not exceed 125℃ under worst case operating
conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other
cooling provisions all affect the part temperature Part temperature should be verified in the end
application.
(1) 電感的公差:N=±30 ,M=±20 .
(2) 所有的測試資料應該是在 25℃的環境溫度下測試.
(3) 感值測試頻率 100KHz.
(4) 操作溫度範圍-50℃到+125℃.
(5) 加 DC(Irms)電流值(A)會導致△T 40℃左右的變化.
(6) 加 DC(Isat)電流值(A)會導致初始值下降 30 左右.
(7) 產品的溫度不能超過 125℃,即使在最壞的操作情況下,基板設計,元件放置,PWB 尺寸和厚度,
氣流和一些冷卻設備都會影響產品溫度,產品溫度要在最終應用時才被驗證.
TEL:+86-756-3383909
TAX:+86-756-3380704
www.baocheng.biz
20 JUN 2016
TAPE BCIHP0730SC-Series P: 3 / 9
Powder Molding Type
BCIHP04SC-Series
● Material List
NO
1
2
3
ITEM
Core
Wire
External Electode
Electroplating
Materials
Magnetic Metal Powder FeSiCr or equivalen
Polyester Wire or equivalen
Copper
Sn
● Packaging Information
(1) Reel Dimension & Tape Dimension / Packaging Quantity
ITEN
DIMENSIONS (m/m)
Q’TY (PCS)
BCIHP0412SC
BCIHP0420SC
W1±0.3 W2±0.5 W±0.3 A0±0.1 B0±0.1 K0±0.1 P±0.1 F±0.1 T±0.05
4000
12.80
17.00
12.00
4.40
4.80
1.50
8.00
5.50
0.30
3000
12.80
17.00
12.00
4.40
4.80
2.20
8.00
5.50
0.30
(2) Tearing Off Force
The force tearing off cover 10 to 130 grams
(0.1N to 1.3N) in the arrow direction under the
following conditions.
● Storage conditions/Note things
(1) Storage temperature and humidity conditions :
1. Product packing with Carrier tape: +5℃~+40℃ and less than 60% RH.
2. Product alone: -20℃~+60℃ and less than 60% RH.
(2) Products should be used within 6 months.
(3) The packaging material should be kept where no chlorine or sulfur exists in the air.
(4) Do not touch the electrodes (soldering terminals) with fingers as this may lead to deterioration of
solder ability.
(5) The use of tweezers or vacuum pick-ups is strongly recommended for individual components.
(6) Bulk handling should ensure that abrasion and mechanical shock are minimized.
TEL:+86-756-3383909
TAX:+86-756-3380704
www.baocheng.biz
20 JUN 2016
TAPE BCIHP0730SC-Series P: 4 / 9
SMD Power Inductors
BCIHP04SC-Series
ITEM
Packing method & Dimensions
Box Size
W=345mm
D=345mm
H=185mm
ITEM
BCIHP0412SC
BCIHP0420SC
TEL:+86-756-3383909
TAX:+86-756-3380704
Packing Quantity
Reel Quantity
Total Quantity
4000 Pcs/Reel
3000 Pcs/Reel
8 Reel/Box
8 Reel/Box
32000Pcs/Box
24000Pcs/Box
www.baocheng.biz
20 JUN 2016
TAPE BCIHP0730SC-Series P: 5 / 9
很抱歉,暂时无法提供与“BCIHP0420SC-4R7M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.43608
- 50+1.13670
- 150+1.00840
- 500+0.84834
