BAW M18MI-UAC50B-S04G
    BALLUFF(巴鲁夫)
    BALLUFF - BAW M18MI-UAC50B-S04G - Inductive Proximity Sensor, Cylindrical, BEW Series, M18, 5 mm, An...
BAW M18MI-UAC50B-S04G 数据手册
Analog Sensors BAW M18MI-UAC50B-S04G M 18 Sl = 1...5 mm 0...10V shielded Common Data Mounting in steel shielded Linearity range Sl mm 1...5 Rated operating distance Se mm 4 Repeat accuracy ± 8 µm Limit frequency (-3dB) 500 Hz Measuring velocity ≤40 m/s Response time Temperature coefficient TK 1 ms typ. -2 µm/K in optimized range min. +1 µm/K from +10...+50°C max. -8 µm/K Max. non-linearity % ±3% from Ua max. Adjusting indication ja Ambient temperature range °C -10...+70 Time delay before availability ms
BAW M18MI-UAC50B-S04G 价格&库存
很抱歉,暂时无法提供与“BAW M18MI-UAC50B-S04G”相匹配的价格&库存,您可以联系我们找货
