BESM18MI-PSC80B-BV03
    BALLUFF(巴鲁夫)
    BALLUFF - BESM18MI-PSC80B-BV03 - Inductive Proximity Sensor, Cylindrical, BES Series, M18, 8 mm, PNP...
BESM18MI-PSC80B-BV03 数据手册
BES M18MI-PSC80B-BV03 Order code: BES008F Inductive sensor GLOBALPROX M18x1 x 56.0 mm DC, direct current PNP / Normally open (NO) Sn = 8.00 mm Flush (shielded) ■■ Load capacitance max. (at Ue) 1.000 µF Sensing data Eff. operating distance Sr Tolerance Sr Assured operating distance Sa Hysteresis H max. (in % of Sr) Repeat accur. R max. (% of Sr) Ambient temperature Ta min. Ambient temperature Ta max. Temp. drift max. (% of Sr) Switching freq. f max. (at Ue) Ready delay tv max. Utilization category Function indicator Power indicator 8.00 mm ±10 % 6.40 mm 15.0 % 5.0 % -25 °C 70 °C 10% 150 Hz 30 ms DC 13 Yes No 000000111880/127016/20100804 Electrical data Eff. operating voltage Ue DC Operating voltage UB min. DC Operating voltage UB max. DC Ripple max. (% of Ue) Voltage drop static max. Rated insulation voltage Ui Eff. operating current Ie Minimum operating current Im No-load current Io damped No-load current Io undamped Off-state current Ir max. Short circuit protected Protected against miswiring Polarity reversal protected Rated short circuit current Output resistance Ra Internet Balluff Germany Balluff USA Balluff China 24.0 V 12.0 V 30.0 V 15 % 2.5 V 250 AC 200 mA 0 mA 15.0 mA 8.0 mA 20 µA Yes Yes Yes 100 A 33.0k + D : www.balluff.com : +49 (0) 7158 173-0, 173-370 : 1-800-543-8390 : +86 (0) 21-50 644131 Mechanical data Housing material Surface protection Tightening torque Sensing face material Mounting length Connection type Cable jacket material Cable diameter D max. Cable short description Cable length Number of conductors Conductor cross-section Enclosure Type per IEC 60529 Protection Class Shock rating Vibration rating Degree of contamination CuZn Nickel-plated 25 Nm / 35 Nm PA 12 50.0 mm Cable PVC 4.6 mm LiY-Y-O 3.00 m 3 0.34 mm² IP68 according to BWN Pr 20 II Shock, half-sinus, 30 gn, 11ms 55 Hz, 1 mm ampl., 3x30 min 3 Approval Approvals CE cULus Remarks The sensor is functional again after the overload has been eliminated. Embeddable: See installation notes for inductive sensors with extended switching distance 825357. Basic standard IEC 60947-5-2 1 (2) Print Date: 02.11.2010 Selection date: 02.11.2010 BES M18MI-PSC80B-BV03 Order code: BES008F Inductive sensor GLOBALPROX M18x1 x 56.0 mm DC, direct current PNP / Normally open (NO) Sn = 8.00 mm Flush (shielded) ■■ Definitions see general catalog 000000111880/127016/20100804 Subject to change without notice. Internet Balluff Germany Balluff USA Balluff China : www.balluff.com : +49 (0) 7158 173-0, 173-370 : 1-800-543-8390 : +86 (0) 21-50 644131 2 (2) Print Date: 02.11.2010 Selection date: 02.11.2010
BESM18MI-PSC80B-BV03 价格&库存
很抱歉,暂时无法提供与“BESM18MI-PSC80B-BV03”相匹配的价格&库存,您可以联系我们找货
