BESM08MI-PSC40B-S49G
    BALLUFF(巴鲁夫)
    BALLUFF - BESM08MI-PSC40B-S49G - Inductive Proximity Sensor, Cylindrical, BES Series, M8, 4 mm, PNP,...
BESM08MI-PSC40B-S49G 数据手册
BES M08MI-PSC40B-S49G Ordering code: BES01ZW Inductive sensor M08x59 mm Long range Characteristic data Eff. switching distance Sr Tolerance Sr Assured operating distance Sa Hysteresis H max. (in % of Sr) Repeat accur. R max. (% of Sr) Ambient temperature Temp. drift max. (% of Sr) Switching freq. f max. Ready delay tv max. Utilisation category Function indicator Power-on indicator Short-circuit protected Degree of protection as per IEC 60529 Protected against polarity reversal Protected against reverse connection 4 mm ±10 % 2,9 mm 15 % 5% 0...60 °C 20% 800 Hz 10 ms DC 13 Yes No Yes IP67 Yes Yes DC, direct current PNP/Normally open (NO) Sn = 4 mm Quasi embeddable Minimum operating current Im Rated short circuit current Output resistance Ra Load capacitance max. (at Ue) Principle of operation 0 mA 100 A 33.0k + 2D 1 µF Inductive Mechanical data Housing material Surface protection Sensing surface material Tightening torque max. Mounting length Connection type Connector type Shock rating Vibration rating Degree of contamination CuZn Nickel-plated PBT 3 Nm / 6 Nm 50 mm Connector M08x1-S49 Shock, half-sinus, 30 gn, 11ms 55 Hz, 1 mm ampl., 3x30 min 3 Basic data Electrical data Operating voltage Rated operating voltage Ue DC Ripple max. (% of Ue) Voltage drop static max. Rated insulation voltage Ui Effective operating current Ie No-load current Io damped No-load current Io undamped Off-state current Ir max. Basic standard 24 V 15 % 2,8 V 75 DC V 200 mA 10 mA 8 mA 10 µA IEC 60947-5-2 Remarks The sensor is functional again after the overload has been eliminated. Quasi-shielded: See installation instructions for inductive sensors with extended switching distance 825356. EMC: EMC protection circuit needed, see 825345. Burst: 1.2 IVW: 2.2 With connector, e.g. BKS-S 49-… total length = switch length +12 mm. Definitions see main catalog subject to change Internet Balluff Germany Balluff USA Balluff China : www.balluff.com : +49 (0) 7158 173-0, 173-370 : 1-800-543-8390 : +86 (0) 21-50 644131 1 (2) Print date: 02.06.2012 Selection date: 02.06.2012 BES M08MI-PSC40B-S49G Ordering code: BES01ZW Inductive sensor M08x59 mm Long range Internet Balluff Germany Balluff USA Balluff China : www.balluff.com : +49 (0) 7158 173-0, 173-370 : 1-800-543-8390 : +86 (0) 21-50 644131 DC, direct current PNP/Normally open (NO) Sn = 4 mm Quasi embeddable 2 (2) Print date: 02.06.2012 Selection date: 02.06.2012
BESM08MI-PSC40B-S49G 价格&库存
很抱歉,暂时无法提供与“BESM08MI-PSC40B-S49G”相匹配的价格&库存,您可以联系我们找货
  • 1+1307.65352
  • 5+1266.24467
  • 10+1240.92476
库存:4
