BESM12MI-PSC40B-S04G
    BALLUFF(巴鲁夫)
    BALLUFF - BESM12MI-PSC40B-S04G - Inductive Proximity Sensor, Cylindrical, BES Series, M12, Flush, 4 ...
BESM12MI-PSC40B-S04G 数据手册
Inductive Sensors BES M12MI-PSC40B-S04G Order Code: BES0068 Basic features Electrical data Approval/Conformity CE Load capacitance max. at Ue 1 µF cULus Min. operating current Im 0 mA EAC No-load current Io max., damped 5 mA No-load current Io max., undamped 2 mA Operating voltage Ub 10...30 VDC Output resistance Ra 33.0 kOhm + D Protection class II Rated insulation voltage Ui 250 V AC WEEE Basic standard IEC 60947-5-2 Trademark Global Display/Operation Function indicator yes Rated operating current Ie 200 mA Power indicator no Rated operating voltage Ue DC 24 V Rated short circuit current 100 A Ready delay tv max. 21 ms Residual current Ir max. 10 µA Electrical connection Connection M12x1-Male, 3-pin, A-coded Ripple max. (% of Ue) 15 % Polarity reversal protected yes Switching frequency 2500 Hz Protection against device mix-ups yes Utilization category DC -13 Short-circuit protection yes Voltage drop static max. 1.5 V Environmental conditions Ambient temperature -25...70 °C Contamination scale 3 EN 60068-2-27, Shock Half-sinus, 30 gn, 11 ms EN 60068-2-6, Vibration 55 Hz, amplitude 1 mm, 3x30 min IP rating IP68 Functional safety MTTF (40 °C) Internet www.balluff.com 640 a eCl@ss 9.1: 27-27-01-01 Subject to change without notice: 265936 ETIM 6.0: EC002714 BES0068_0.4_2020-06-03 1/2 Inductive Sensors BES M12MI-PSC40B-S04G Order Code: BES0068 Material Output/Interface Housing material Brass, Nickel-free coated Material sensing surface PBT Switching output PNP normally open (NO) Range/Distance Mechanical data Assured operating distance Sa 3.2 mm Dimension Ø 12 x 65 mm Hysteresis H max. (% of Sr) 15.0 % Installation for flush mounting Rated operating distance Sn 4 mm Size M12x1 Real switching distance sr 4 mm Tightening torque 10 Nm Repeat accuracy max. (% of Sr) 5.0 % Switching distance marking ■■ Temperature drift max. (% of Sr) 10 % Tolerance Sr ±10 % Remarks The sensor is functional again after the overload has been eliminated. For more information about MTTF and B10d see MTTF / B10d Certificate Indication of the MTTF- / B10d value does not represent a binding composition and/or life expectancy assurance; these are simply experiential values with no warranty implications. These declared values also do not extend the expiration period for defect claims or affect it in any way. Connector Drawings Wiring Diagrams Internet www.balluff.com eCl@ss 9.1: 27-27-01-01 Subject to change without notice: 265936 ETIM 6.0: EC002714 BES0068_0.4_2020-06-03 2/2
BESM12MI-PSC40B-S04G 价格&库存
很抱歉,暂时无法提供与“BESM12MI-PSC40B-S04G”相匹配的价格&库存,您可以联系我们找货
