BCT3661CELT-TR
BCT3661CELT-TR
    BROADCHIP(广芯)
    WDFN-6-EP(2x2)
    具备数字脉冲亮度控制功能的白光LED驱动器
BCT3661CELT-TR 数据手册
Ver 1.4 BCT3661C White LED driver with digital pulse brightness control Features Description   BCT3661C is a boost converter that drives up to 14 LEDs in 7 series 2 parallels. It runs at 600kHz fixed switching frequency to reduce output ripple and EMI, improve conversion efficiency, and allow for the use of small external components. During the operation, the LED current can be controlled by using the 1-wire digital interface through the CTRL pin. BCT3661C does not burst LED current, therefore, it does not generate audible noise on the output capacitor. The device integrated open LED protection, that disables the BCT3661C to prevent the output from exceeding the absolute to prevent the output from exceeding the absolute maximum ratings during open LED conditions. The BCT3661C is available in a space saving 2mm x 2mm 6-pin DFN package and is specified over the -40℃ to 85℃ extended temperature range.         3.0V to 5.5V Input Voltage Range 28V Open LED Protection for up to 7 LEDs in series Max current 50mA Current accuracy,
BCT3661CELT-TR 价格&库存
很抱歉,暂时无法提供与“BCT3661CELT-TR”相匹配的价格&库存,您可以联系我们找货
