BF801M
Order Code:
C
BF8801M
Verrsion: A1 2015-08-22
Gass Dischargee Tube
Feaatures
Ex
xterior
Sm
mall Size Dessign 4.2×5.0×
×5.0mm Currrent
H
Handling
Capaability 3,000A
A @ 8/20μs
Low Capacitan
nce and Inserrtion Loss
Faast Responsee and Long Seervice Life
M
Moisture
sensiitivity level:Level 1
SM
MD
Application innformation
Paackage (Topp View)
A Power
AC
` xDSL
1
Ageency Approovals
2
Scchematic Syymbol
Icon
Description
n
Compliaance with 2011/65/EU
2
1
Compliancee with IEC61
1249-2-21:200
03
Mean lead frree
UL Certificated
C
E
E232249
Electrical Paraameter
D Breakdow
DC
wn Voltage 1)2)
1
Impulse Sparrk-over Voltaage
100V/s
640-960
V
At 1kV/μ
μs
fo
or 99 % of meeasured valuees ≤ 1600
V
At 1kV/μ
μs
Typical
T
valuess of distribution ≤ 1500
V
8/20μs,±5tiimes
3,000
A
10/1
1000 μs ,±1
150 times
100
A
AC Disch
harge Currentt
5A,1S
10
Tim
mes
Arc Voltage
V
At 1A
~15
V
Insulation
n Resistance
DC=100V
V
≥1
GΩ
Ω
Capacitan
nce at 1MHz
VDC=0.5V
V
≤1.0
pF
F
~0.5
g
-40-90
I
Impulse
Disch
harge Curren
nt 3)
W
Weight
Operating And
A Storagee
Temp
perature
Maarking
Without
1) At delivery AQ
QL 0.65 level II GB/T 2828.11-2003
2) In ionized modde
TU-T Rec. K. 122; IEC 61643-21
3) Terms and wavveforms in accoordance with IT
1/3
www.beencent.com
m.cn
S
Specifications
aare subject to ch
hange without notice.
n
Customers should verify actuaal device perforrmance in their specific applications
BF801M
Order Code:
C
BF8801M
Parrt Numberinng System
BF
801
M
(1)
(2)
(3)
Prroduct Charracteristics
Bencent Gas Discharge
D
Tu
ube
(1)B
(2) Series:
S
DC Brreakdown Vo
oltage,
e.gg.:801=80×101=800V
(3) Tolerance
T
of DC Breakdow
wn Voltage, M=+-20%,
M
Lead Material
Copp
per
Body Materrial
Ceram
mics
Terminal Finnish
100% Matte--Tin Plated
N=+
+-30%,the Sp
pecific toleran
nce is decided
d by the tablee
of“Electrical Paarameter”
Envvironmentall Reliabilityy Characteriistics
T
Testing
items
Technnical standardds
Temperaature: 90℃
Time:2H
H
Temperaature: -40℃
Time:2H
H
Frequenccy:10-500H
Hz
Amplitudde:0.15mm
m
Time:445min
Temperaature: 260±5℃
Time of dip soldering
g:10s,1tim
me
Hiigh Temperatuure Storage Test
T
Loow Temperatuure Storage Test
T
Vibbration
Reesistance of sooldering heatt
Notte: Up-screenn program cann be specifiedd by customerr’s request viia contacting Bencent servvice
Sollderability Test
T
Soldderability
S
Solder
Pot Tem
mperature:
2455℃±5℃
Solder Dweell Time:
4-66 seconds
Prooduct Dimennsions
D
A
C
REF
mm
inch
A
0.5±0.1
1
0.020±0.004
B
4.2±0.3
3
0.165±0.012
C
5.0±0.2
2
0.197±0.008
D
5.0±0.2
2
0.197±0.008
REF
mm
inch
A
4.95
0.195
B
3.0
0.118
C
5.5
0.217
B
Reccommendedd Soldering Pad
A
B
C
2/3
www.beencent.com
m.cn
S
Specifications
aare subject to ch
n
BF801M
Order Code:
C
BF8801M
Refflow Profilee
Reflow
w Condition
Heaat
Temperrature Min
150°C
C
Temperrature Max
200°C
C
Time (min to max)
60 – 180 secs
Aveerage ramp up rate(Liquids)
r
Tamp
(T
TL) to peal
TS(max)
to TL - Raamp-up Rate
3°C/ssecond max
(Liquids)
- Teemperature (TL)
Peaak Temperature (TP)
C
217°C
60 – 150 seconds
tS
25
Ram
mp-down Rate
6°C/ssecond max
Tim
me 25°C to peakk Temperature (T
( P)
8 minnutes Max.
Do not exceed
260°C
C
3/3
Ramp-down
Preheat
TS(min)
~10 seconds
s
Tem
mperature (tp)
Pacckage Reeel
TL
TS(max)
260+
+0/-5 °C
Tim
me within 5°C of
o actual peak
Criticaal Zone
TL to TP
Raamp-up
TL
3°C/ssecond max
- Teemperature (TL)
Refflow
tP
TP
p
Temperature
Pree
Pb--Free assembly
Time
t
time
to peak temper ature
Informaation
REF
F
m
mm
inch
A0
3±0.2
0.331±0.0
008
B0
4.5
5±0.2
0.216±0.0
008
P0
4.0
0±0.2
0.157±0.00
08
P1
12.0
0±0.2
0.472±0.00
08
P2
2.0
0±0.2
0.079±0.00
08
E
1.75
5±0.2
0.069±0.00
08
F
7.5
5±0.2
0.295±0.00
08
W
16.0
0±0.3
0.630± 0.0
012
K0
2±0.2
0.209±0.00
08
T
0.5
5±0.2
0.020±0.00
08
G
2
0.079
D0
Φ1..5±0.2
Φ0.059±0.0
008
D
Φ3
330.0
Φ13.0
D1
Φ50Min
Φ1.97Min
n
D2
Φ13
3±0.15
0.512±0.00
06
W1
1
16.8
8±2.0
0.661±0.07
79
Outline
Reel
(PCS)
Per Carrton
(PCS
S)
Reel Diameter (mm)
TAPING
G
1,000
16,00
00
330
www.beencent.com
m.cn
Carton Size(mm)
S
L
W
H
36
60
36
60
38
85
S
Specifications
aare subject to ch
n
很抱歉,暂时无法提供与“BF801M”相匹配的价格&库存,您可以联系我们找货
