BS201N
BS201N
    BENCENT(槟城)
    BS201N
BS201N 数据手册
BS201N Order Code: BS201N Version: A1 2019-04-02 Gas Discharge Tube Features Exterior Small Size Design EIA 1206 3.2×1.6×1.6mm Current Handling Capability 500A @ 8/20μ s Low Capacitance and Insertion Loss Fast Response and Long Service Life Reliable to Protect Electrostatic Surge SMD Moisture sensitivity level: Level 1 Application Information rmation Package (Top View) Communication port ` 1 Agency Approvals 2 Schematic Symbol Icon Description Compliance with 2011/65/EU 2 1 Compliance with IEC61249-2-21:2003 Mean lead free UL Certificated E232249 Electrical Parameter DC Breakdown Voltage 1)2) 100V/s Impulse Spark-over Voltage3) At 1kV/μs 140-260 for 99 % of measured values Typical values of distribution ±5 operations Impulse Discharge Current 8/20μs3) ±5 operations 5/320μs3)4) V  850  750 V V 500 A 150 A Arc Voltage At 1A ~10 V Insulation Resistance DC=100V ≥1 GΩ Capacitance at 1MHz VDC=0.5V ≤0.6 pF Weight ~0.04 g Operating And Storage Temperature -40-90 ℃ Marking Without 1) At delivery AQL 0.65 level II GB/T 2828.1-2003 2) In ionized mode 3) Terms and waveforms in accordance with ITU-T Rec. K. 12; IEC 61643-21 4)Test generator 6 kV, 10/700μs, 40Ω 1/3 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BS201N Order Code: BS201N Version: A1 2019-04-02 Gas Discharge Tube Part Numbering System BS 201 N (1) (2) (3) Product Characteristics Characteristics Lead Material Copper Body Material Ceramics Terminal Finish 100% Matte-Tin Plated (1)Bencent Gas Discharge Tube (2) Series: DC Breakdown Voltage, e.g.:201=20×101=200V (3) Tolerance of DC Breakdown Voltage, M=±20%, N=±30%,the Specific tolerance is decided by the table of “Electrical Parameter” Environmental Reliability Characteristics Testing items Technical standards Temperature: 90℃ Time: 2H Temperature: -40℃ Time: 2H Frequency: 10-500Hz Amplitude: 0.15mm Time: 45min Temperature: 260±5℃ Time of dip soldering: 10s, 1time High Temperature Storage Test Low Temperature Storage Test Vibration Resistance of soldering heat Note: Up-screen program can be specified by customer’s request via contacting Bencent service Solderability Test Solderability Solder Pot Temperature: 245℃±5℃ Solder Dwell Time: 4-6 seconds Product Dimensions A C REF mm inch A 3.2±0.3 0.126±0.013 B 0.3±0.2 0.013±0.008 C 1.6±0.2 0.063±0.008 D 1.6±0.2 0.063±0.008 REF mm inch A 4.5 0.177 B 2.0 0.079 C 1.8 0.070 D B Recommended Soldering Pad A B C 2/3 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BS201N Order Code: BS201N Version: A1 2019-04-02 Gas Discharge Tube Reflow Profile Reflow Condition Heat Temperature Min 150°C Temperature Max 200°C Time (min to max) 60 – 180 secs Average ramp up rate (Liquids) Tamp (TL) to peal TS (max) to TL - Ramp-up Rate 3°C/second max (Liquids) - Temperature (TL) Peak Temperature (TP) 217°C 60 – 150 seconds TL TS(max) Ramp-down Preheat TS(min) tS 260+0/-5 °C Time within 5°C of actual peak ~10 seconds Temperature (tp) Critical Zone TL to TP Ramp-up TL 3°C/second max - Temperature (TL) Reflow tP TP Temperature Pre Pb-Free assembly 25 Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (TP) 8 minutes Max. Do not exceed 260°C Time time to peak temper ature Package Reel Information 3/3 REF mm inch A 1.9±0.2 0.074±0.008 B 3.6±0.2 0.141±0.008 d Φ1.5±0.2 Φ0.059±0.008 P0 4.0±0.2 0.157±0.008 P1 2.0±0.2 0.079±0.008 P 4.0±0.2 0.156±0.008 E 1.75±0.2 0.069±0.008 F 5.5±0.2 0.217±0.008 W 12.0±0.2 0.472±0.008 D Φ178±2 Φ7.008±0.079 D1 Φ58Min Φ2.28Min D2 Φ13±0.2 0.512±0.008 W1 12.6±0.2 0.496±0.008 Outline Reel (PCS) Per Carton (PCS) Reel Diameter (mm) TAPING 2,000 60,000 178 www.bencent.com.cn Carton Size(mm) L W H 390 370 220 Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications
BS201N 价格&库存
很抱歉,暂时无法提供与“BS201N”相匹配的价格&库存,您可以联系我们找货
