BV-SMBT-15CA
BV-SMBT-15CA
    BENCENT(槟城)
    SMB-T
    瞬态电压抑制器
BV-SMBT-15CA 数据手册
B BV-SMB BT-15C CA Order C Code: BV-SMBT-15C CA Version: A0 2015-04--13 Tra ansient Vo oltage Sup ppressor Feaatures Ex xterior Small size:SM MB-T Surge rating 1KA@8/20u us Bi-directionaal Agency A Appprovals Appplication innformation D DC12V Icon ` Descriptiion Compliance with 2011/65/EU Compliance withIEC61249-2-21:200 03 130 09 Partt Number annd Electricaal Parameterr VBR①@IR IDRM M@VDRM μA Part Numberr V MAX X 1 BV V-SMBT-15CA A V Vc@Ipp② mA MIN 15 16.7 V CO○4 A PF MIN MAX 1000 3000 A MAX 1 Ipp③ 18.5 1   A Absolute max ximum ratinggs measured at a T= 25ºC RH R = 45%-75% % (unless oth herwise noted d).   ① VBR is meaasured at IR=1 1mA(PIN1orr 3 to 2) ②Surge Wavveform: 10/10 000μS(PIN1 1and 3 to 2) ③Surge Wavveform: 8/20μS(PIN1and d 3 to 2) ○ 4 Off-state caapacitance is measured in VDC=0V,VRM Hz(PIN1and 3 to 2) MS=1V,f=1MH Parrt Numberinng System Mark M B BV SMBT T 15 C A ( (1) (2) ( 3) (4 4) (5) (1)) Bencent TV VS (2)) Package: SM MB-T 2 B1 15CT 1 1503 3 (3))VDRM=15V V (4)) Bidirectionaal polar B15CT: Paart Number (5)) Suffix ‘A’ denotes 5% tollerance devicces 1503 : Marrch,2015 1/4 www.benncent.com.cn S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications B BV-SMB BT-15C CA Order C Code: BV-SMBT-15C CA Version: A0 2015-04--13 Tra ansient Vo oltage Sup ppressor V-I Curve Parameterrs Definitiion VC Clamping voltage v Ipp Surgge waveform 10/1000μs VDRM Stand-off Voltage V VBR Breakdown Voltage V IDRM Reeverse Leakagge Current IR Test currrent Ppp Peak k Pulse Powerr Dissipation IPP VC VBR VDRM D IR IDRM IDRM IR VBR VC VDRM D V IPP Thermal Coonsiderationns s symbol Parameter Value Unit TJ Operating Ju unction Temp perature Rangge -5 55 to +150 ℃ TS Storage Temperaturre Range -5 55 to +150 ℃ E Environmen ntal Charactteristics T Testing Itemss Techn nical Standard ds Hiigh Temperatture Reverse Bias B Test Temperaature: 150±3℃ ℃, Bias=80% %VDRM Time:16 68H Hiigh Temperatture Life Testt Temperaature: 150℃ Time:16 68H Hiigh-low Temp perature Cyclle Test Temperaature: From -40℃ to125℃ ℃ Dwell tiime: 30min, 10-100 1 cycles Hiigh Temperatture &High Humidity H Testt Temperaature: 85℃Hu umidity:85% Test tim me:168H Prressure Cookeer Test Temperaature: 121℃, 2atm. Humidity:100% Test tim me: 24H to 168 8H Reesistance of Soldering S Heaat Temperaature: 260±5℃ ℃ Time off dip solderingg: 10s, 3timess Noote: The abovve testing item ms can be speecified by cusstomers by co ontacting Benncent service 2/4 www.benncent.com.cn S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications B BV-SMB BT-15C CA Order C Code: BV-SMBT-15C CA Version: A0 2015-04--13 Tra ansient Vo oltage Sup ppressor Prroduct Dimeensions Bottom view H I REF mm inch A 5.4±0.3 3 0.213±0.012 0 B 3.3±0.3 3 0.130±0.012 0 C 0.7±0.0 03 0.028±0.001 0 D 2.0±0.2 2 0.079±0.008 0 E 0.9±0.2 2 0.035±0.008 0 F 1.32±0.3 0.052±0.012 0 G 1.13±0.3 0.045±0.012 0 H 2±0.3 0.079±0.012 0 I 0.25±0.0 05 0.010±0.002 0 Side view Reecommended Solderingg Pad Bottom view w 3/4 www.benncent.com.cn REF mm inch A 2.8 0.134 B 2.5 0.098 C 1.6 0.059 D 1.8 0.059 E 0.9 0.035 F 0.8 0.032 S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications B BV-SMB BT-15C CA Order C Code: BV-SMBT-15C CA Version: A0 2015-04--13 Tra ansient Vo oltage Sup ppressor Refflow Profilee Reflow Condition perature Min. Temp +150 0°C Temp perature Max. +200 0°C Timee(Min to Max) 60 – 180 secs. Aveerage ramp up rate(Liquidus Tem mp(TL) to peak k) TS(m max) to TL - Ra amp-up Rate - Temperature T (T TL) Refflow (L Liquidus) - Temperature T (T TL) Peaak Temp (TP) 3°C/ /sec. Max. (TP) 7°C +217 60 – 150 secs. TL TS(max) Ramp-dow wn Preheat TS(min) TS TL 8 – 15 secs. Ram mp-down Ratee 6°C/ /sec. Max. Tim me 25°C to peaak Temp (TP) 8 min n. Max. Do not exceed +260 0°C 4/4 TL 3°C/ /sec. Max. Critical Zone TL to TP Ram mp-up +(26 60+0/-5 )°C Tim me within 5°C of actual Peak k Temp Pacckage Reeel TP TP Temperature Pre Heat Pb-F Free Assembly y 25 2 Time tim me to peak temperatu ure Informaation REF mm m inch A 3.65+/ /-0.3 0.144+/-0.01 12 B 5.69+/ /-0.3 0.244+/0-.01 12 d 1.5+/ /-0.1 0.059+/-0.00 04 D 330.0 13.0 D1 100+ +/-3 3.937+/-0.11 18 D2 13+/--0.3 0.512+/-0.01 12 E 1.5+/ /-0.2 0.059+/-0.00 08 F 5.65+/ /-0.2 0.222+/-0.00 08 P 8.0+/ /-0.2 0.315+/-0.00 08 P0 4.0+/ /-0.2 0.157+/-0.00 08 P1 2.0+/ /-0.2 0.079+/-0.00 08 W 12.0+/ /-0.2 0.472+/-0.00 08 W1 16.8+/ /-2.0 0.661+/-0.07 79 OUTLINE RE EEL (P PCS) PER CARTO ON (PCS) REEL DIAMETERS (mm) L W H TAPING 3,0 000 24,000 330 360 0 360 0 38 80 www.benncent.com.cn CARTON SIZE(mm) S S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications
BV-SMBT-15CA 价格&库存
很抱歉,暂时无法提供与“BV-SMBT-15CA”相匹配的价格&库存,您可以联系我们找货
