BV-SLVU2.8-4
Order Code: BV-SLVU2.8-4
Version: A1 2018-01-26
Transient Voltage Suppressor
Features
Exterior
Low reverse current
Low Junction capacitance
IEC 61000-4-2(ESD)±30KV(air), ±30KV(contact)
450 Watts peak pulse power (tp=8/20μ S)
Moisture sensitivity level: Level 1
Agency Approvals
Application Information
rmation
Ethernet Secondary Side
Icon
Description
Compliance with 2011/65/EU
Compliance withIEC61249-2-21:2003
Mean lead free
Part Number and Electrical Parameter
IDRM@VDRM
μA
Part Number
V
MAX
V
Vc@Ipp②
mA
MIN
0.1
BV-SLVU2.8-4
VBR①@IR
2.8
3.5
V
A
MAX
1
5.8
C O③
Vc@Ipp②
V
A
MAX
1
18
pF
MAX
24
3
Absolute maximum ratings measured at T= 25ºC RH = 45%-75% (unless otherwise noted).
① VBR is measured at IR=1mA, Pin1to2, Pin3to4, Pin5to6, Pin7to8;
② Surge Waveform: 8/20μ S, Pin1to2, Pin3to4, Pin5to6, Pin7to8;
③ Off-state capacitance is measured in VDC=0V, VRMS=1V, f=1MHz, Pin1to2, Pin3to4, Pin5to6, Pin7to8;
Part Numbering System
BV-SLVU
2.8
-4
(1)
(2)
(3)
Mark
B42LC
(1) Bencent TVS SLVU series
(2) VDRM=2.8V
(3) 4 lines protect
1/4
www.bencent.com.cn
Part Number
Specifications are subject to change without notice.
Customers should verify actual device performance in their specific applications
BV-SLVU2.8-4
V-I Curve
Parameters
Definition
VC
Clamping voltage
Ipp
Surge waveform 8/20μ s
VDRM
Stand-off Voltage
VBR
Breakdown Voltage
IDRM
Reverse Leakage Current
IR
Test current for VBR
Ppp
Peak Pulse Power Dissipation
Pin 1&8 to 2&7; Pin 3&6 to 4&5
Typical Characteristics
Thermal Considerations
symbol
Parameter
Value
Unit
TJ
Operating Junction Temperature Range
-55 to +150
TS
Storage Temperature Range
-55 to +150
2/4
www.bencent.com.cn
BV-SLVU2.8-4
Environmental Characteristics
Technical standards
Testing items
High temperature Reverse Bias Test
High Temperature Life Test
High-low Temperature Cycle test
High Temperature &High Humidity Test
Pressure cooker Test
Resistance of soldering heat
Temperature: 150±3℃ Bias=80%VDRM
Time: 168H
Temperature: 150℃
Time: 168H
Temperature: From -40℃ to125℃
Dwell time: 30min, 10~100cycles
Temperature: 85℃ Humidity: 85%
Time: 168H
Temperature: 121℃, 2atm. Humidity: 100%
Time: 24H
Temperature: 260±5℃
Time of dip soldering: 10s, 3times
Note: The above testing items can be specified by customer’s special request
Product Dimensions
DIM
MILLIMETERS
INCHES
MIN
MAX
MIN
MAX
A
4.90
5.20
0.193
0.205
B
3.80
4.00
0.150
0.157
C
1.35
1.75
0.053
0.069
D
0.33
0.51
0.013
0.020
G
1.27BSC
0.05BSC
H
0.10
0.25
0.004
0.010
J
0.19
0.25
0.007
0.010
K
0.40
1.27
0.015
0.050
M
0°
8°
0°
8°
N
0.25
0.50
0.010
0.020
S
5.80
6.20
0.228
0.244
Recommended Soldering Pad
3/4
www.bencent.com.cn
BV-SLVU2.8-4
Reflow Profile
Pb-Free assembly
Temperature Min
150°C
Temperature Max
200°C
Time (min to max)
60 – 180 sec
Average ramp up rate (Liquid) Tamp (TL)
to peak
3°C/s max
TS(max) to TL - Ramp-up Rate
3°C/s max
Pre Heat
Reflow
TP
TP
- Temperature (TL) (Liquid)
217°C
- Temperature (TL)
60 – 150 sec
Peak Temperature (TP)
260+0/-5 °C
Time within 5°C of actual peak Temperature
(TP)
25secs
Ramp-down Rate
6°C/s max
Time 25°C to peak Temperature (TP)
8 min Max.
Do not exceed
260°C
Critical Zone
TL to TP
Ramp-up
TL
Temperature
Reflow Condition
TL
TS(max)
Ramp-down
Preheat
TS(min)
TS
25
Time
time to peak temperature
Package Reel Information
4/4
REF
mm
inch
A
6.70±0.25
0.2638±0.0098
B
5.20±0.25
0.2047±0.0098
d
1.55±0.10
0.0610±0.0039
D
330.00 TYP
13.00TYP
D1
55±3
2.165±0.118
D2
13±0.5
0.512±0.020
E
1.75±0.10
0.0689±0.0039
F
5.50±0.20
0.2165±0.0079
P
8±0.1
0.315±0.004
P0
4.0±0.1
0.158±0.008
P1
2.0±0.1
0.079±0.004
W
12.00±0.20
0.4724±0.0079
W1
14.4±0.5
0.567±0.020
OUTLINE
REEL
(PCS)
PER CARTON
(PCS)
REEL
DIAMETERS
(mm)
L
W
H
TAPING
2500
20000
330
360
370
220
www.bencent.com.cn
CARTON SIZE(mm)
很抱歉,暂时无法提供与“BV_SLVU2.8-4”相匹配的价格&库存,您可以联系我们找货
