BD122-2
BD122-2
    BENCENT(槟城)
    SMD
    BD122-2
BD122-2 数据手册
BD122-2 Order Code: BD122-2 Version: A1 2017-04-12 Gas Discharge Tube Features Exterior High Current Handling Capability20,000A @ 8/20μ s Low Capacitance and Insertion Loss Fast Response and Long Service Life Moisture sensitivity level:Level 1 Note: The product body and the chip are sticked with glue. Application Information rmation Package (Top View) Wireless Base Station DC-48V Power Port 6 1 ` 2 Agency Approvals 3 4 5 Schematic Symbol Icon Description 1 Compliance with 2011/65/EU Compliance withIEC61249-2-21:2003 6 2 3 4 5 Mean lead free Compliance with UL1449, Certificated E337906 Electrical Parameter DC Breakdown Voltage1 (pin1-6) )2) 100V/s 700-1200(Before test) 500-1300(After test) V DC Breakdown Voltage 1 2 (pin1-2,pin2-3,pin3-4,pin4-5,pin5-6) 100V/s 140-250 V Impulse Spark-Over Voltage (pin1-6)3) 1.2/50μs -8/20μs: 6KV/3KA 10/350μs,±5times ≤900(Before test) ≤1500(After test) 2.5 KA 8/20μs,±5times 20 KA DC100V ≥1 60 ≥60 ≤1.5 -40-125 ~5.35 Without GΩ V V pF ℃ g ) ) Impulse Discharge Current4) Insulation Resistance Maximum DC Working Voltage Arc Voltage Capacitance at 1 MHz Operating and storage Temperature Weight Marking At 50 A VDC=0.5V V 1) At delivery AQL 0.65 level II ISO 2859 2) In ionized mode 3) With 100PF capacitor trigger 4) Terms and current waveforms in accordance with ITU-T Rec. K. 12; IEC 61643-21 1 /3 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BD122-2 Order Code: Version: A1 2017-04-12 Gas Discharge Tube Part Numbering System BD 122 (1) (2) BD122-2 - Product Characteristics Characteristics 2 (3) (1) Bencent Multi-pole Arrester Stack (2) Max DC Breakdown Voltage, e.g., 122=12×102=1200V (3) “-2” is stand for special customer requirements Lead Material Copper Body Material Ceramics Terminal Finish 100% Matte-Tin Plated Environmental Reliability Characteristics Testing items Technical standards Temperature: 125℃ High Temperature Storage Test Time:2H Temperature: -40℃ Low Temperature Storage Test Time:2H Frequency:10-500Hz Vibration Amplitude:0.15mm Time:45mins Temperature: 260±5℃ Resistance of soldering heat Time of dip soldering:10s,1time Note: Up-screen program can be specified by customer’s request via contacting Bencent service Solderability Test Solderability Solder Pot Temperature: 245℃±5℃ Solder Dwell Time: 4-6 seconds Product Dimensions REF mm inch A 8±0.2 0.315±0.008 B 8.3±0.2 0.327±0.008 C 8.3±0.2 0.327±0.008 D 9.5±0.2 0.374±0.008 E 3.2±0.2 0.126±0.008 F 16.5±0.5 0.65±0.02 G 0.5±0.05 0.02±0.002 REF mm inch A 23 0.906 B 4.1 0.161 C 8.5 0.335 Recommended Soldering Pad 2 /3 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BD122-2 Order Code: Version: A1 2017-04-12 Gas Discharge Tube Reflow Profile Reflow Condition Pb-Free assembly Temperature Min 150°C Temperature Max 200°C Time (min to max) 60 – 180 secs Average ramp up rate(Liquids)Tamp (TL) to peal 3°C/second max - Temperature (TL) 217°C (Liquids) 60 – 150 seconds - Temperature (TL) TS(max) Ramp-down Preheat TS(min) tS 260+0/-5 °C Peak Temperature (Tp) Critical Zone TL to TP Ramp-up TL 3°C/second max TS(max) to TL - Ramp-up Rate Reflow tP TP Temperature Pre Heat BD122-2 TL Time within 5°C of actual peak 20 – 40 seconds Temperature (tp) Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (Tp) 8 minutes Max. Do not exceed 260°C 25 Time time to peak temper ature Package Reel Information d OUTLINE TAPING 3 /3 BOX/REEL (PCS) 300 www.bencent.com.cn INSIDE CARTON (PCS) 300 REF mm inch W 32±0.3 1.260±0.012 A 8.6±0.1 0.339±0.004 B 17.3±0.1 0.661±0.004 P 16±0.1 0.63±0.004 P0 4±0.1 0.157±0.004 P2 2±0.1 0.079±0.004 +0.1 Φ0.059+0.004 -0 d Φ1.5 E 1.75±0.1 0.069±0.004 F 20.25±0.1 0.797±0.004 W1 36±2.0 1.89±0.079 D Φ330.2 Φ13 D1 Φ100±1 Φ3.94±0.039 D2 Φ13±0.15 0.512±0.006 -0 CARTON SIZE(mm) PER CARTON (PCS) L W H 1200 360 360 220 Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications
BD122-2 价格&库存
很抱歉,暂时无法提供与“BD122-2”相匹配的价格&库存,您可以联系我们找货
