BD150N04FZ
BD150N04FZ
    BYD(比亚迪)
BD150N04FZ 数据手册
BD150N04FZ FRD Module BYD Microelectronics Co., Ltd. VRRM=400V General Description Features BYD FRD Module BD150N04FZ is a fast recovery dual diode module designed for high power switching rectifier circuit. BD150N04FZ can be used in high frequency application requiring low loss and high speed control. z z z z IF=150A Two elements in a package Dual FRD common cathode construction Fast & Soft reverse recovery characteristics Low switching losses Applications z z z Inversion welder Switching power supply Telecommunication power supply Characteristic values Parameter Symbol Conditions Temperature Value Unit Absolute Maximum Ratings(Per Leg) Repetitive peak reverse voltage VRRM — — 400 V Reverse DC Voltage VR — — 320 V Average forward current IF(AV) — — 150 A IFSM 1/2 cycle,60Hz,sine — 3000 A I2t 60Hz,sine,t=8.3ms — 38000 A2s IFSM 1/2 cycle,50Hz,sine — 2850 A I2t for fusing I2t 50Hz,sine,t=10ms — 35000 A2s Junction temperature Tvj — — - 40~150 ℃ Storage temperature range Tstg — — - 40~125 ℃ No repetitive surge forward current I2t for fusing No repetitive surge forward current Datasheet TS-PDM-PD-0038 Rev.A/0 Page 1 of 5 BYD Microelectronics Co., Ltd. Parameter Symbol BD150N04FZ Conditions Temperature Value Unit Characteristics Min. Typ. Max. Reverse leakage current IR VR=400V Tvj=25℃ — 5.44 20 uA Forward voltage VF IF=150A Tvj =25℃ — 1.10 1.25 V Reverse recovery time trr — 102 — ns — 15 — A — 150 — ns — 18 — A Max. reverse recovery current IRRM Reverse recovery time trr Max. reverse recovery current IRRM Parameter Tvj =25℃ VR =200V, IF =150A di/dt=100A/us, Symbol Tvj =125℃ Conditions Min. Typ. Max. Unit — — 0.13 ℃/W Thermal-Mechanical Specifications Diode thermal resistance junction to case Rth(j-c) DC current Torque — Mounting torque 4.0 N·m Torque — Terminal torque 4.0 N·m LxWxH Typical , see outline drawing 92 x 27 x 17 Term to term — Dimensions Mass m mm — — — 35 — — 100 — g Thermal and mechanical properties according to IEC 60747 – 15 Datasheet TS-PDM-PD-0038 Rev.A/0 Page 2 of 5 BYD Microelectronics Co., Ltd. BD150N04FZ Characterization curves 1000 115 125℃ 105 100 IF[A] trr [ns] 25℃ 95 10 85 75 100 1 0 0.5 1 1.5 VF[V] 2 2.5 Fig.1 Typical Forward Voltage Drop vs. Instantaneous Forward Current 1000 di/dt [A/μs] Fig.2 Typical Reverse Recovery Time vs. di/dt 1 160 140 120 0.1 I F(AVG) [A] Z thjc [℃/W] 100 0.01 80 60 40 20 0.001 1.E-05 1.E-04 1.E-03 1.E-02 1.E-01 1.E+00 Rectangular Pulse Duration [sec] 0 60 Fig.3 Transient Themal Impedance (Zthjc) Datasheet 80 100 120 Case Temperature [℃] 140 Fig.4 Forward Current Derating Curve Characteristics TS-PDM-PD-0038 Rev.A/0 Page 3 of 5 160 BYD Microelectronics Co., Ltd. BD150N04FZ Circuit Diagram 1 2 H Package Outlines Dimensions in mm Attached (recommended torque): Mounting torque (M6): 4.0 N • M Datasheet Terminal torque (M6):4.0N • M TS-PDM-PD-0038 Rev.A/0 Page 4 of 5 BYD Microelectronics Co., Ltd. BD150N04FZ Attention 1. In order to reduce the contact resistance; we suggest add thermal grease between base and heat-sink, which thickness is about 0.1mm. 2. When installing the module, please wear an electrostatic bracelet to prevent the gate breakdown and the imbalance power may damage the internal chip, even to damage the module. 3. This is an electrostatic sensitive device; please observe the international standard IEC 60747-1, chap. IX. RESTRICTIONS ON PRODUCT USE „ The information contained herein is subject to change without notice. „ BYD Microelectronics Co., Ltd. (short for BME) exerts the greatest possible effort to ensure high quality and reliability. Nevertheless, semiconductor devices in general can malfunction or fail due to their inherent electrical sensitivity and vulnerability to physical stress. It is the responsibility of the buyer, when utilizing BME products, to comply with the standards of safety in making a safe design for the entire system, including redundancy, fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community damage that may ensue. In developing your designs, please ensure that BME products are used within specified operating ranges as set forth in the most recent BME products specifications. „ The BME products listed in this document are intended for usage in general electronics applications (personal equipment, measuring equipment, industrial robotics, domestic appliances, etc.). These BME products are neither intended nor warranted for usage in equipment that requires extraordinarily high quality and/or reliability or a malfunction or failure of which may cause loss of human life or bodily injury (“Unintended Usage”). Unintended Usage include atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, medical instruments, all types of safety devices, etc.. Unintended Usage of BME products listed in this document shall be made at the customer’s own risk. Datasheet TS-PDM-PD-0038 Rev.A/0 Page 5 of 5
BD150N04FZ 价格&库存
很抱歉,暂时无法提供与“BD150N04FZ”相匹配的价格&库存,您可以联系我们找货
