AT8N-24-240
AT8N-24-240
    AUTONICS(奥托尼克斯)
    AUTONICS - AT8N-24-240 - Analogue Timer, ATN, Multifunction, 16 Ranges, 0.05 s, 100 h, 2 Changeover ...
AT8N-24-240 数据手册
ATN Series Multi Function Timer DIN W48×H48mm, Universal voltage multi-function timer (A) Photo electric sensor Features ● Realization of wide range of power supply :100-240VAC 50/60Hz / 24-240VDC universal, 24VAC 50/60Hz / 24VDC universal, 12VDC ● Various output operation(6 kinds modes) ● Multi time range(16 kinds of time range) ● Wide control time(0.05sec. to 100hour) ● Easy setting of time, time range, output operation mode ● Easy to check output status by LED display (B) Fiber optic sensor (C) Door/Area sensor (D) Proximity sensor (E) Pressure sensor Please read “Caution for your safety” in operation manual before using. Ordering information AT 8 N No mark 100-240VAC/24-240VDC 1 12VDC Power 24VAC/DC supply 2 Time operation Number of plug pins Item Specifications Model Function Control time setting range Power supply Allowable voltage range Power consumption Reset time Min. START input INHIBIT signal RESET width START INHIBIT Input RESET Timing operation (F) Rotary encoder N Time limit contact 2c or time limit contact 1c with instantaneous contact 1c by selecting output operation mode 8 8-pin plug type AT 11 DN AT Analog Timer ※Sockets (PG-08, PS-08) are sold separately. Power supply Time operation Number of plug pins Item (G) Connector/ Socket No mark 100-240VAC/24-240VDC 1 12VDC 2 24VAC/DC DN EN Time limit 2c Time limit 1c, Instantaneous contact 1c 11 11-pin plug type AT Analog Timer (H) Temp. controller (I) SSR/ Power controller (J) Counter ※Sockets (PG-11, PS-11) are sold separately. (K) Timer AT8NAT11ENAT11DNMulti function timer 0.05 sec. to 100 hour • 100-240VAC 50/60Hz, 24-240VDC universal • 24VAC 50/60Hz, 24VDC universal • 12VDC 90 to 110% of rated voltage • 100-240VAC : 4.3VA, 24-240VDC : 2W • 100-240VAC:3.5VA, 24-240VDC:1.5W • 24VAC : 4.5VA, 24VDC : 2W • 12VDC : 1.5W • 24VAC:4VA, 24VDC:1.5 • 12VDC:1W Max. 100ms - Min. 50ms - No-voltage input - Short-circuit impedance : Max. 1kΩ Residual voltage : Max. 0.5V Open-circuit impedance : Min. 100kΩ Power ON start type Signal ON Start type Time limit DPDT(2c), Time limit SPDT(1c), Time limit DPDT(1c)+ Control Contact type Instantaneous DPDT(1c) by Instantaneous SPDT(1c) output selecting output operation mode Contact capacity 250VAC 5A resistive load Mechanical Min. 10,000,000 operations Relay life cycle Electrical Min. 100,000 operations(250VAC 5A resistive load) Repeat error Max. ±0.2% ±10ms SET error Max. ±5% ±50ms Voltage error Max. ±0.5% Temperature error Max. ±2% Insulation resistance Min. 100MΩ(at 500VDC megger) Dielectric strength 2000VAC 50/60Hz for 1 minute Environ Ambient temperature -10 to 55℃, storage: -25 to 65℃ -ment Ambient humidity 35 to 85%RH (L) Panel meter (M) Tacho/ Speed/ Pulse meter (N) Display unit (O) Sensor controller (P) Switching mode power supply (Q) Stepper motor& Driver&Controller Time limit DPDT(2c) (R) Graphic/ Logic panel (S) Field network device (T) Software (U) Other Approval Accessory Bracket Unit weight Approx. 90g ※Environment resistance is rated at no freezing or condensation. K-59 ATN Series Connections AT8N ● [A], [F] mode ● [A1], [B], [F1], [I] mode 4 4 5 3 6 2 7 (Time limit 1c) 1 8 CONTACT: 250VAC 5A RESISTIVE LOAD (Time limit 1c) START START 6 8 3 9 2 1 11 10 7 4 CONTACT : 250VAC 5A RESISTIVE LOAD 8 3 9 2 1 11 10 (Time limit 1c) (Time limit 1c) (Time limit 1c) + 6 5 INHIBIT 7 4 8 CONTACT: 250VAC 5A RESISTIVE LOAD SOURCE: • 100-240VAC 50/60㎐, 24-240VDC • 24VAC 50/60㎐, 24VDC • 12VDC AT11DEN RESET 5 7 1 - RESET INHIBIT 2 (Instantaneous 1c) SOURCE: • 100-240VAC 50/60㎐, 24-240VDC • 24VAC 50/60㎐, 24VDC • 12VDC AT11DN 6 + - 5 3 CONTACT : 250VAC 5A RESISTIVE LOAD (Time limit 1c) (Instantaneous 1c) - + - + SOURCE: • 100-240VAC 50/60㎐, 24-240VDC • 24VAC 50/60㎐, 24VDC • 12VDC SOURCE: • 100-240VAC 50/60㎐, 24-240VDC • 24VAC 50/60㎐, 24VDC • 12VDC (unit: mm) Dimensions ● Panel cut-out ● Bracket 15 Min. 65 50 Min. 65 56 44.8 45 +0.6 0 □48 64.5 45 +0.6 0 41 72 Panel K-60 8-pin socket : PG-08 (Sold separately) 11-pin socket : PG-11 (Sold separately) ※Refer to the G-15 page. Multi Function Timer Parts description (A) Photo electric sensor Operation/Power LED (Timer operation: Flashing Timer stop:LED ON) Output LED [Time limit output operation(ON) : Light on] (C) Door/Area sensor Operation mode display AT8 (A, A1, B, F, F1, I mode) Time range display Time range selector (Changing the time unit per 4 revolutions) (D) Proximity sensor AT11DN/AT11EN (A, F, F1, C, D, I mode) Time unit (sec, min, hour, 10h) (E) Pressure sensor Operation mode selector (F) Rotary encoder ※Please rotate the time range switch and operation mode switch to CW(Clockwise) direction. (G) Connector/ Socket Time specifications Time range (H) Temp. controller Time unit Time setting range 0.5 (I) SSR/ Power controller 0.05 to 0.5 sec. 1.0 0.1 to 1.0 sec. sec 5 0.5 to 5 sec. 10 1 to 10 sec. 0.5 0.05 to 0.5 min. 1.0 0.1 to 1.0 min. min 5 1 to 10 min. 0.5 0.05 to 0.5 hour 1 to 10 hour 0.5 0.5 to 5 hour (M) Tacho/ Speed/ Pulse meter (N) Display unit (O) Sensor controller 1 to 10 hour 10h 5 (L) Panel meter 0.5 to 5 hour 10 1.0 (K) Timer 0.1 to 1.0 hour hour 5 (J) Counter 0.5 to 5 min. 10 1.0 5 to 50 hour 10 (P) Switching mode power supply 10 to 100 hour (Q) Stepper motor& Driver&Controller Output operation mode of each model ● AT8N (B) Fiber optic sensor (R) Graphic/ Logic panel ● AT11DN/AT11EN Display Output operation mode Display Output operation mode A Power ON Delay A Signal ON Delay A1 Power ON Delay 1 F Flicker (OFF Start) B Power ON Delay 2 F1 Flicker 1 (ON Start) F Flicker (OFF Start) C Signal OFF Delay F1 Flicker 1 (ON Start) D Signal ON/OFF Delay I Interval I Interval (S) Field network device (T) Software (U) Other K-61 ATN Series AT8N Output operation mode Mode A [t:Setting time, t > t-a, Rt:Return time, Rt1>Rt] Time chart t Rt1 t Rt1 t-a t Rt1 t Rt1 t-a Power 2-7 Time limit contact N.C. 1-4(8-5) Power ON Delay Time limit contact N.O. 1-3(8-6) Time limit output operation LED Operation/Power LED A1 Power 2-7 Time limit contact N.C. 8-5 0.5 sec. Time limit contact N.O. 8-6 Power ON Delay 1 (One-shot output) 0.5 sec. Instant limit contact N.C. 1-4 Instant limit contact N.O. 1-3 Time limit output operation LED Operation/Power LED ※One- shot output is 0.5sec fixed. B t Rt1 t Rt1 t-a Power 2-7 Time limit contact N.C. 8-5 Time limit contact N.O. 8-6 Power ON Delay 2 Instant limit contact N.C. 1-4 Instant limit contact N.O. 1-3 Time limit output operation LED Operation/Power LED F t t t-a Rt1 t t t t t t-a Rt1 t t t Power 2-7 Time limit contact N.C. 1-4(8-5) Flicker Time limit contact N.O. 1-3(8-6) Time limit output operation LED Operation/Power LED F1 Power 2-7 Time limit contact N.C. 8-5 Time limit contact N.O. 8-6 Flicker 1 Instant limit contact N.C. 1-4 Instant limit contact N.O. 1-3 Time limit output operation LED Operation/Power LED I t Rt1 t Power 2-7 Time limit contact N.C. 8-5 Time limit contact N.O. 8-6 Interval Instant limit contact N.C. 1-4 Instant limit contact N.O. 1-3 Time limit output operation LED Operation/Power LED ※When using F, F1 output operation modes, if the time is set too short, the output may not work properly. Please set the time at least over 100ms. K-62 Rt1 t-a Multi Function Timer AT11DN/AT11EN Output operation mode Mode Time chart A t Signal ON Delay (A) Photo electric sensor [t:Setting time, t=t1+t2, t>t-a] t1 (B) Fiber optic sensor t2 Power 2-10 START 2-6 INHIBIT 2-5 RESET 2-7 Time limit contact N.C. (C) Door/Area sensor Time limit contact N.O. Time limit output operation LED (D) Proximity sensor Operation/Power LED F t t t-a t t1 (E) Pressure sensor t2 Power 2-10 Flicker START 2-6 INHIBIT 2-5 RESET 2-7 Time limit contact N.C. Time limit contact N.O. Time limit output operation LED (F) Rotary encoder (G) Connector/ Socket Operation/Power LED F1 Flicker 1 t t t-a t t1 (H) Temp. controller t2 Power 2-10 START 2-6 INHIBIT 2-5 RESET 2-7 Time limit contact N.C. Time limit contact N.O. Time limit output operation LED (I) SSR/ Power controller (J) Counter Operation/Power LED (K) Timer C t-a t t-a t1 t2 (L) Panel meter Power 2-10 Signal OFF Delay START 2-6 INHIBIT 2-5 RESET 2-7 Time limit contact N.C. (M) Tacho/ Speed/ Pulse meter Time limit contact N.O. Time limit output operation LED (N) Display unit Operation/Power LED D t t-a t t1 t-a t2 t t-a t-a (O) Sensor controller Power 2-10 START 2-6 INHIBIT 2-5 (P) Switching mode power supply RESET 2-7 Signal ON-OFF Delay Time limit contact N.C. Time limit contact N.O. (Q) Stepper motor& Driver&Controller Time limit output operation LED Operation/Power LED I t Interval t t t-a t-a t1 (R) Graphic/ Logic panel t2 Power 2-10 START 2-6 INHIBIT 2-5 (S) Field network device RESET 2-7 (T) Software Time limit contact N.C. Time limit contact N.O. Time limit output operation LED (U) Other Operation/Power LED ※1: If power is removed or the RESET terminal is short-circuited, the timer will be reset. 2: If the INHIBIT terminal is short-circuited during a timing cycle, the time will stop. 3: When using F, F1 output operation modes, if the time is set too short, the output may not work properly. Please set the time at least over 100ms. K-63 ATN Series Proper usage Repeat function(Flicker) ● It enables to use one ATN timer for 3 sub relays and 2 timers (Flicker function). Simple to use flicker function with only one ATN timer. ● Switch A : Start, Switch B : Reset. 2. Input with NPN open collector type Characteristics of transistor should be Vceo = min. 25V, Ic = min. 10mA, Icbo = max. 0.2㎂, residual voltage = max. 0.5V. Reset Start Reset Start Inhibit 5 < Previous > + Inhibit + 6 7 START R1 R1 T1 T1 Load R2 It enables to use voltage output type as input signal source instead of open collector output in solid-state circuit (proximity sensor, photo-electric sensor) which has range of 10-30VDC output voltage. When H signal change to L, timer will start. When transistor(Q) is ON status, please make residual voltage under 0.5V. R3 T2 < ATN Flicker mode > Time limit 10-30VDC + - RL Timer 2 3. NPN universal input T2 R1 - R3 R3 R2 RESET 6 7 5 2 R1 + START RESET A B Q Load START 5 6 0.4㎃ 7 2 Interval mode It enables to make instantaneous ON and time limit OFF (remained circuit) with using Interval mode. T : Timer START Instantaneous T : Timer(AT8) START Time limit Time limit T Load < Previous > T Load < Interval mode > Input signal condition(AT11DN, AT11EN) 1. Relay contact input Please use gold-plated switches with good contact assurance and short bouncing time for contact input. (Open resistance : Over 100kΩ, Short-circuit resistance: Under 1kΩ) ※Please use a contact that can function reliably at 5VDC 0.4mA. K-64 Terminal connection Please wire correctly with wiring instructions Power connection Connect the power line without observing polarity for ATN series AC power type, but please be careful of power connection for DC power type. Power supply 8-pin Type 11-pin Type AC Type Terminal ② - ⑦ Terminal ② - ⑩ DC Type Terminal ② ← ⊖ Terminal ⑦ ← ⊕ Terminal ② ← ⊖ Terminal ⑩ ← ⊕ When turning off the power, be careful of inductive voltage. (If using power line with another high voltage line or energy line near by, it may cause inductive voltage). Power ripple should be under 10% and power supply should be within range of allowable voltage for DC power type. Please supply the power quickly when using a switch or a relay contact. Otherwise, it may cause time error or power reset failure. The load of Control output should be under rated load capacity. Multi Function Timer ATS11DN/AT11EN (Fig. 6) Power Main circuit Power START RESET INHIBIT + - < Sensor > + - Rectification Transformer with insulated circuit When using the terminal ⑩ as a common terminal of input signal as (Fig. 2), it may cause damage to the inner circuit of AT11DN/AT11EN, please use the terminal ② for common terminal as (Fig. 3). (Fig. 3) INHIBIT START RESET Power Leakage current R C T R C T RESET START INHIBIT It might cause malfunction if changing the setting time, time range or operation mode during operating unit. Please change the the setting time, time range or operation mode after cut the power off. Do not use this unit at below places. Place where there are severe vibration or impact. Place where strong alkalis or acids are used. Place where there are direct rays of the sun Place where strong magnetic field or electric noise are generated. Installation environment It shall be used indoor Altitude Max. 2000m Pollution Degree 2 Installation Category II Power (C) Door/Area sensor (D) Proximity sensor (F) Rotary encoder (H) Temp. controller (I) SSR/ Power controller (J) Counter (K) Timer (L) Panel meter (M) Tacho/ Speed/ Pulse meter (N) Display unit (O) Sensor controller (P) Switching mode power supply (Fig. 5) Short current Power (B) Fiber optic sensor (E) Pressure sensor When using more than one timer with one contact or transistor input, the short current is flowed when it is connected as (Fig. 4). Please connect the power phase correctly as (Fig. 5) correctly. (Fig. 4) (A) Photo electric sensor (G) Connector/ Socket < External sensor power supply > (Fig. 2) (Fig. 7) Timer (Fig. 1) Timer Input connection AT11DN/AT11EN Timer is non-transformer type, therefore please check following for connecting relay contact for input signal and transistor. Common For DC power supply type, be sure to check the polarity of terminals. In case of 12VDC, 24VAC/DC model, isolated and limited voltage/current or Class 2 source should be provided for power supply. When supply the power to the timer, connection shown in (Fig. 6) might cause malfunction due to leakage current through R and C. Please connect R and C as shown in (Fig. 7) to prevent malfunction. Power Setting time, time range, operation mode Do not change time range or operation mode while time operating. When changing it, please power off or apply reset signal. (Q) Stepper motor& Driver&Controller (R) Graphic/ Logic panel Power (S) Field network device INHIBIT, START, RESET signal applied by short input terminal ②-⑤, ②-⑥ or ②-⑦. It may cause internal circuit damaged by wrong connection. If using power line with another high voltage line or energy line at the same conduit, it may cause inductive voltage. Therefore please use separated conduit for power line. When input(INHIBIT, START, RESET) wire is long, please use shield wire and it should be short. (T) Software (U) Other K-65
AT8N-24-240 价格&库存
很抱歉,暂时无法提供与“AT8N-24-240”相匹配的价格&库存,您可以联系我们找货
