BLE-2537S
BLE-2537S
    SPECTRONICS
BLE-2537S 数据手册
Ultraviolet Lamps Medium wave, MW (UV-B, 312nm) • Unfiltered tube • With LONGLIFE™ filter assembly (FA) Model EB-160C EB-180C EB-280C UV Tube(s) Filter Assembly Dimensions (W x L x H) One 6-watt MW, BLE-6T312 One 8-watt MW, BLE-8T312 Two 8-watt MW, BLE-8T312 2F006 2F018 2F018 3.25" x 10.25" x 2.5", 8.3 x 26.0 x 6.4cm 3.25" x 13.25" x 2.5", 8.3 x 33.7 x 6.4cm 3.25" x 13.25" x 2.5", 8.3 x 33.7 x 6.4cm Net Weight 2.5 lbs, 1.1kg 2.75 lbs, 1.2kg 2.75 lbs, 1.2kg Short wave, SW (UV-C, 254nm) • Unfiltered tube • With LONGLIFE™ filter assembly (FA) Model UV Tube(s) EF-140C EF-160C EF-180C EF-260C EF-280C One 4-watt SW, BLE-2537S One 6-watt SW, BLE-6254S One 8-watt SW, BLE-8T254 Two 6-watt SW, BLE-6254S Two 8-watt SW, BLE-8T254 Filter Assembly 2F001 2F006 2F018 2F006 2F018 Dimensions (W x L x H) 3.25" 3.25" 3.25" 3.25" 3.25" x x x x x 8" x 2.5", 8.3 x 20.3 x 6.4cm 10.25" x 2.5", 8.3 x 26.0 x 6.4cm 13.25" x 2.5", 8.3 x 33.7 x 6.4cm 10.25" x 2.5", 8.3 x 26.0 x 6.4cm 13.25" x 2.5", 8.3 x 33.7 x 6.4cm Net Weight 2.0 2.5 2.75 2.75 2.75 lbs, lbs, lbs, lbs, lbs, 0.9kg 1.1kg 1.2kg 1.2kg 1.2kg Dual Wavelength, E-Series • Unfiltered long, medium and short wave tubes • With LONGLIFE™ filter assembly (FA) Long wave (UV-A, 365nm) / Short wave (UV-C, 254nm) Model ENF-240C ENF-260C ENF-280C UV Tube(s) Filter Assembly Dimensions (W x L x H) Net Weight One 4-watt BL, BLE-270W One 4-watt SW, BLE-2537S One 6-watt BL, BLE-6T365 One 6-watt SW, BLE-6254S One 8-watt BL, BLE-8T365 One 8-watt SW, BLE-8T254 2F001 3.25" x 8" x 2.5", 8.3 x 20.3 x 6.4cm 2.0 lbs, 0.9kg 2F006 3.25" x 10.25" x 2.5", 8.3 x 26.0 x 6.4cm 2.5 lbs, 1.1kg 2F018 3.25" x 13.25" x 2.5", 8.3 x 33.7 x 6.4cm 2.75 lbs, 1.2kg Long wave (UV-A, 365nm) / Medium wave (UV-B, 312nm) Model ENB-260C ENB-280C UV Tube(s) Filter Assembly Dimensions (W x L x H) One 6-watt BL, BLE-6T365 One 6-watt MW, BLE-6T312 One 8-watt BL, BLE-8T365 One 8-watt MW, BLE-8T312 2F006 3.25" x 10.25" x 2.5", 8.3 x 26.0 x 6.4cm Net Weight 2.5 lbs, 1.1kg 2F018 3.25" x 13.25" x 2.5", 8.3 x 33.7 x 6.4cm 2.75 lbs, 1.2kg Medium wave (UV-B, 312nm) / Short wave (UV-C, 254nm) Model EBF-260C EBF-280C UV Tube(s) Filter Assembly Dimensions (W x L x H) Net Weight One 6-watt MW, BLE-6T312 One 6-watt SW, BLE-6254S One 8-watt MW, BLE-8T312 One 8-watt SW, BLE-8T254 2F006 3.25" x 10.25" x 2.5", 8.3 x 26.0 x 6.4cm 2.5 lbs, 1.1kg 2F018 3.25" x 13.25" x 2.5", 8.3 x 33.7 x 6.4cm 2.75 lbs, 1.2kg Germicidal, E-Series • Unfiltered short wave (UV-C) tubes without filter assembly Model UV Tube Filter Assembly Dimensions (W x L x H) EF-140 EF-160 EF-180 One 4-watt SW, BLE-2537S One 6-watt SW, BLE-6254S One 8-watt SW, BLE-8T254 ---- 3.25" x 7" x 2.5", 8.3 x 17.8 x 6.4cm 3.25" x 10.25" x 2.5", 8.3 x 26.0 x 6.4cm 3.25" x 13.25" x 2.5", 8.3 x 33.7 x 6.4cm Accessories for E-Series Lamps SE-140 CH-180 18 Lamp Stand Carrying Handle Net Weight 1.75 lbs, 0.8kg 2.0 lbs, 0.9kg 2.25 lbs, 1.0kg
BLE-2537S 价格&库存
很抱歉,暂时无法提供与“BLE-2537S”相匹配的价格&库存,您可以联系我们找货
