ES1J
ES1J
    BORN(伯恩)
    SMA(DO-214AC)
    整流二极管 600V 1A SMA(DO-214AC)
ES1J 数据手册
ES1A-ES1J SERIES RECTIFIERS SMA FAST SURFACE MOUNT RECTIFIERS ROHS SMA FEATURES ● Super fast switching time for high efficiency ●Low forward voltage drop and high current capability .062(1.60) .055(1.40) ●Low reverse leakage current .114(2.90) .098(2.50) ●Plastic material has UL flammability classification 94V-0 .181(4.60) .157(4.00) .012(.305) .006(.152) MECHANICAL DATA .103(2.62) .079(2.00) ●Case: Molded Plastic ●Polarity: lndicated by cathode band ●Weight: 0.002 ounces,0.064 grams .060(1.52) .030(0.76) ●Mounting position: Any .008(.203) .002(.051) .208(5.28) .188(4.80) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating at 25℃ ambient temperature unless otherwise specified. Single phase, half wave ,60Hz, resistive or inductive load. For capacitive load, derate current by 20% CHARACTERISTICS SYMBOL ES1A ES1B ES1D ES1G ES1J UNIT Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 V Maximum RMS Voltage VRMS 35 70 140 280 420 V VDC 50 100 200 400 600 V Maximum DC Blocking Voltage Maximum Average Forward Rectified Current @TA=55 ℃ I(AV) 1.0 A IFSM 30 A Peak Forward Surage Current 8.3ms Single Half Sine-Wave Super Imposed on Rated Load(JEDEC Method) Peak Forward Voltage at 1.0A DC 0.95 VF Maximum DC Reverse Current @TJ=25℃ at Rated DC Blocking Voltage @TJ=100℃ Maximum Reverse Recovery Time(Note 1) Tyical Junction Capacitance (Note2) Tyical Thermal Resistance (Note3) Operating Temperature Range Storage Temperature Range 1.25 1.70 5.0 IR μA 100 35 TRR 30 CJ nS 25 pF RθJA 40 ℃/W TJ -55 to +150 ℃ TSTG -55 to +150 ℃ NOTES: 1.Measured with IF=0.5A, IR=1A, IRR=0.25A 2.Measured at 1.0 MHz and applied reverse voltage of 4.0V DC 3.Thermal resistance junction of ambient. Rev 8: Nov 2014 V www.born-tw.com 112 Page 1 of 2 ES1A-ES1J SERIES RECTIFIERS SMA FAST SURFACE MOUNT RECTIFIERS FIG. 1 – FORWARD CURRENT DERATING CURVE FIG. 2 – MAXIMUM NON-REPETITIVE SURGE CURRENT 40 0.8 0.6 0.4 SINGLE PHASE HALF WAVE 60Hz RESISTIVE OR INDUCTIVE LOAD 0 25 50 75 100 125 150 175 PEAK FORWARD SURGE CURRENT AMPERES AVERAGE FORWARD CURRENT AMPERES 1.0 0.2 30 20 10 PULSE WIDTH 8.3ms SINGLE HALF-SINE-WAVE (JEDEC METHOD) 0 1 2 AMBIENT TEMPERATURE (℃) 5 10 20 50 100 NUMBER OF CYCLES AT 60Hz FIG.3 – TYPICAL JUNCTION CAPACITANCE FIG.4-TYPICAL FORWARD CHARACTERISTICS 100 INSTANTANEOUS FORWARD CURRENT, (A) 100 ES1A - ES1D CAPACITANCE (pF) ROHS ES1G-ES1J 10 T J = 25°C f = 1 MHz ES1A -ES1D 10 T J = 25°C PULSE WIDTH 300us ES1G 1.0 ES1J 0.1 1 1 4 10 0 100 0.4 0.6 0.8 1.0 1.2 1.4 1.6 INSTANTANEOUS FORWARD VOLTAGE ,VOLTS REVERSE VOLTAGE ,VOLTS Rev 8: Nov 2014 0.2 www.born-tw.com 112 Page 2 of 2 1.8
很抱歉,暂时无法提供与“ES1J”相匹配的价格&库存,您可以联系我们找货
ES1J
    • 1+0.07670
    库存:773
    ES1J
    库存:7179
    ES1J
    • 1+0.31460
    • 500+0.10461
    • 2500+0.06974
    • 5000+0.05720
    库存:4495
    ES1J
    • 50+0.10562
    • 1000+0.08326
    • 2000+0.07084
    • 5000+0.06302
    库存:3829
