BDFN2C361V35
ESD Protection Diode
»Features
450Watts peak pulse power (tp = 8/20μs)
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
Protection one data/power line
IEC 61000-4-2 ±8kV contact ±15kV air
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 4A (8/20μs)
»Applications
»Mechanical Data
Power lines
DFN1006 package
Personal Digital Assistants
Molding compound flammability rating: UL 94V-0
Notebooks, Desktops, and Servers
Packaging: Tape and Reel
RoHS/WEEE Compliant
»Schematic & PIN Configuration
DFN1006
Revision 2018
www.born-tw.com
1/4
BDFN2C361V35
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
450
Watts
Peak Pulse Current ( tp =8/20μs )(note1)
Ipp
4
A
VESD
15
8
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
Storage Temperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Min
Typical
VRWM
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=36V,T=25℃
Peak Pulse Current
IPP
tp =8/20μs
Clamping Voltage
VC
IPP=4A,tp=8/20μs
70
Junction Capacitance
Cj
VR = 0V, f = 1MHz
13
Max
Units
36
V
40
V
0.1
0.5
μA
4
A
V
pF
»Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IT
I
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RWM
VC V BR VRWM
Breakdown Voltage @ IT
IT
IR
IR
IT
V RWM V BR VC
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
BDFN2C361V35
»Typical Characteristic
Fig.1 Peak Pulse Power RatingCurve
Fig.2 Pulse Derating Curve
110
100
% of Rated Power (PPP) or IPP
Peak Pulse Power –P PP(KW)
10
280W
1
0.1
0.01
0.1
1
10
100
Pulse Duration tp (μs)
1000
Fig.3 PulseWaveform-8/20μs
120
40
50
75
100
125
Ambient Temperature—TA(℃)
100%IPP , 8μS
150
100%
90%
30ns
80
50%IPP, 20μS
e-t
60
Percent of IPP
Percent of IPP
60
Fig.4 PulseWaveform-ESD(IEC61000-4-2)
100
40
60ns
10%
10
15
30
60
Fig.5 IEC61000-4-2 +8kV ContactDischarge
Fig.6 IEC61000-4-2 -8kV ContactDischarge
Trigger and Clamping Voltage(V)
Time (ns)
Time (μs)
tr 0.7 to 1ns
Time (ns)
Revision 2018
Time (ns)
www.born-tw.com
3/4
BDFN2C361V35
»Outline Drawing – DFN1006
»Marking
DB
»Ordering information
Order code
BDFN2C361V35
Revision 2018
Package
DFN1006
Base qty
10k
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“BDFN2C361V35”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.29947
- 500+0.19929
- 5000+0.17315
- 10000+0.15791
- 国内价格
- 10+0.30403
- 100+0.24700
- 2000+0.19711
- 国内价格
- 10+0.33167
- 100+0.26946
- 300+0.23836
- 1000+0.21503
- 5000+0.17788
- 10000+0.16848
