BESD0P2RF-02LS
BESD0P2RF-02LS
    BORN(伯恩半导体)
    DFN-603
    单向 5V截止 峰值浪涌电流:3.5A@8/20US
BESD0P2RF-02LS 数据手册
BESD0P2RF-02LS ESD Protection Diode »Features ■ 60Watts peak pulse power (tp = 8/20μs) ■ Tiny DFN0603 package ■ Bidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ Low capacitance (Cj=0.35pF typ.) ■ Protection one data/power line ■ IEC 61000-4-2 ±15kV contact ±20kV air ■ IEC 61000-4-4 (EFT) 40A(5/50ns) ■ IEC 61000-4-5 (Lightning)3.5A(8/20μs) »Applications »Mechanical Data ■ USB3.0,HDMI2.0,Thunderbolt ■ DFN0603package ■ Notebooks, Desktops, and Servers ■ Molding compound flammability rating: UL 94V-0 ■ Portable Instrumentation ■ Packaging: Tape and Reel ■ RoHS/WEEE Compliant »Schematic & PIN Configuration Revision 2018 www.born-tw.com 1/4 BESD0P2RF-02LS »Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 60 Watts Peak Pulse Current ( tp =8/20μs )(note1) Ipp 3.5 A VESD 20 15 kV Lead SolderingTemperature TL 260(10seconds) ℃ JunctionTemperature TJ -55 to + 125 ℃ StorageTemperature Tstg -55 to + 125 ℃ ESD per IEC 61000-4-2(Air) ESD per IEC 61000-4-2(Contact) »Electrical Characteristics Parameter Symbol Reverse Stand-OffVoltage VRWM Reverse BreakdownVoltage VBR Conditions Min IT=1mA 5.5 VRWM=5V,T=25℃ Reverse LeakageCurrent IR Peak PulseCurrent IPP ClampingVoltage VC IPP=3.5A,tp=8/20μs JunctionCapacitance Cj VR = 0V, f =1MHz Typical Max Units 5.0 V 8.5 5 V 100 nA 3.5 A 16 20 V 0.35 0.50 pF tp =8/20μs »Electrical Parameters (TA = 25°C unless otherwisenoted) Symbol Parameter IPP MaximumReversePeak Pulse Current VC Clamping Voltage @ IPP V RW M IR V WorkingPeak Reverse Voltage Maximum Reverse Leakage Current @ V RWM BR Breakdown Voltage @ IT IT Test Current IPP VT VC VBR VRWM IT IR ITIR VRWM VBR VC VT IPP Note:.8/20μs pulsewaveform. Revision 2018 www.born-tw.com 2/4 BESD0P2RF-02LS »TypicalCharacteristics Figure 2: Power Derating Curve 10 110 100 Percent of Rated Power for Ipp P pp – Peak Pulse Power - Ppp(KW) Figure 1: Peak Pulse Power vs. Pulse Time 1 60w 8/20µswaveform 0.1 0.01 1 0.1 10 100 90 80 70 60 50 40 30 20 10 0 1,000 Ipp 80 Percent 125 150 18 Clamping Voltage–V C (V) 90 e -1 50 40 td=Ipp/2 20 100 20 Waveform Paramters tr=8µs td=20µs 100 30 75 Figure 4: Clamping Voltage vs.Ipp 110 60 50 Ambient Temperature - TA (℃) Figure3: Pulse Waveform 70 25 0 td – Pulse Duration - µs 16 14 12 Test Waveform Paramters tr=8µs td=20µs 10 8 6 4 10 2 0 0 5 Revision 2018 10 15 Time (µs) 20 25 30 0 www.born-tw.com 1 2 3 4 5 6 Peak Pulse Current–IPP (A) 3/4 BESD0P2RF-02LS »Outline Drawing – DFN0603 E b b Sy mbol L h D h e TOP VIEW BOTTOM VIEW A C Dimensions in millimeters Min No m Max A 0.28 0 .3 0 0.32 A1 0.00 0.02 0.05 C 0.05 0.10 0.15 D 0.55 0.60 0.65 E 0.25 0.30 0.35 b 0 .14 0 .19 0 .2 4 L 0 .20 0 .25 0 .30 h 0 0 .0 5 0 .10 A1 SIDE VIEW »Marking U5 »Ordering information Order code BESD0P2RF-02LS Revision 2018 Package DFN0603 Base qty 10k www.born-tw.com Deliverymode Tape andreel 4/4
BESD0P2RF-02LS 价格&库存
很抱歉,暂时无法提供与“BESD0P2RF-02LS”相匹配的价格&库存,您可以联系我们找货
