BST563A055V
BST563A055V
    BORN(伯恩半导体)
    SOT-563
    ESD 5V截止 峰值浪涌电流:7.5A@8/20US
BST563A055V 数据手册
BST563A055V ESD Protection Diode Array »Features ■ 90Watts peak pulse power (tp = 8/20μs) ■ Tiny SOT563 package ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ Protection five data/power line ■ IEC 61000-4-2 ±8kV contact ±15kV air ■ IEC 61000-4-4 (EFT) 40A (5/50ns) ■ IEC 61000-4-5 (Lightning) 7.5A (8/20μs) »Applications ■ ■ ■ ■ ■ »Mechanical Data Cellular Handsets & Accessories Personal Digital Assistants (PDAs) Notebooks & Handhelds Portable Instrumentation Digital Cameras ■ SOT563 package ■ Molding compound flammability rating: UL 94V-0 ■ Packaging: Tape and Reel ■ RoHS/WEEE Compliant »Schematic & PIN Configuration 1 3 4 5 6 2 Revision 2018 1 6 2 5 3 4 SOT-563 (Top View) www.born-tw.com 1/4 BST563A055V »Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs) PPP 90 Watts Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 7.5 A VESD 15 8 kV Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 125 ℃ Storage Temperature Tstg -55 to + 125 ℃ ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) »Electrical Characteristics Parameter Symbol Reverse Stand-Off Voltage Conditions Min VRWM VBR IT=1mA Reverse Leakage Current IR VRWM=5V,T=25℃ Clamping Voltage VC IPP=7.5A,tp=8/20μs Reverse Breakdown Voltage Junction Capacitance Typical Cj Max Units 5.0 V V 6.0 50 VR = 0V, f = 1MHz IO to IO 20 VR = 0V, f = 1MHz IO to GND 40 500 nA 12 V pF »Electrical Parameters (TA = 25°C unless otherwise noted) Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT I IF Working Peak Reverse Voltage Maximum Reverse Leakage Current @ V RWM VC V BR VRWM Breakdown Voltage @ IT IR V F IT V Test Current IPP Note:. 8/20μs pulsewaveform. Revision 2018 www.born-tw.com 2/4 BST563A055V »Typical Characteristics Figure 2: Power Derating Curve 10 110 Percent of Rated Power for Ipp P pp – Peak Pulse Power - Ppp(KW) Figure 1: Peak Pulse Power vs. Pulse Time 90W@8/20µs Waveform 1 0.1 0.01 0.1 1 10 100 100 90 80 70 60 50 40 30 20 10 0 1,000 0 25 td – Pulse Duration -µs Figure3: Pulse Waveform 110 Percent Ipp 80 e-1 50 40 td=Ipp/2 20 14 12 10 Test Waveform Paramters tr=8µs td=20µs 8 6 4 0 5 10 15 150 16 10 0 125 18 Clamping Voltage–V C (V) 90 30 100 20 Waveform Paramters tr=8µs td=20µs 60 75 Figure 4: Clamping Voltage vs.Ipp 100 70 50 Ambient Temperature - TA (℃) Time (µs) 20 25 2 30 0 1 2 3 4 5 6 Peak Pulse Current–IPP (A) Figure 6: Normalized Junction Capacitance vs. Reverse Voltage Figure 5: Insertion Loss CH S21 LOG 6 dB / REF 0 dB 1.1 1.0 F=1MHz Cj(V R )/C j(V R =0) 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 START.030 MHz STOP 3000.000000MHz 00 1 2 3 Reverse Voltage Revision 2018 www.born-tw.com 4 5 V-R(V) 3/4 BST563A055V »Outline Drawing – SOT563 PACKAGE OUTLINE E1 L A1 DIMENSIONS INCHES SYMBOL MIN MAX MIN MAX A 0.021 0.024 0.525 0.600 A1 0.000 0.002 0.000 0.050 e b D A E c θ MILLIMETER e 0.018 0.022 0.450 0.550 c 0.004 0.006 0.090 0.160 D 0.059 0.067 1.500 1.700 b 0.007 0.011 0.170 0.270 E1 0.043 0.051 1.100 1.300 E 0.059 0.067 1.500 1.700 L 0.004 0.012 0.100 0.300 θ 7°REF 7°REF θ X DIMENSIONS DIM G Y Z INCHES MILLIMETERS Z 0.0752 1.91 G 0.0350 0.89 P 0.020TYP 0.51 TYP X 0.0118 0.3 Y 0.0201 0.51 P »Marking E5C »Ordering information Order code BST563A055V Revision 2018 Package Base qty Delivery mode SOT563 3k Tape and reel www.born-tw.com 4/4
BST563A055V 价格&库存
很抱歉,暂时无法提供与“BST563A055V”相匹配的价格&库存,您可以联系我们找货
