5.0SMDJ33CA
5.0SMDJ33CA
    BORN(伯恩)
    SMC(DO-214AB)
    双向TVS 33V截止 峰值脉冲电流:93.9A
5.0SMDJ33CA 数据手册
5.0SMDJ Series Transient Voltage Suppressors 5.0SMDJxxA(CA) ROHS DESCRIPTION: TVS diodes can be used in a wide range of applications which like consumer electronic products, automotive industries, munitions, telecommunications, aerospace industries, and intelligent control systems. SMC FEATURES:         Glass passivated or planar junction Excellent clamping capability Repetition rate (duty cycle): 0.01% Typical IR less than 1μA above 10V. Low profile package and low inductance 5000 W Peak Pulse power capability at 10×1000μs waveform. Fast response time: typically less than 1.0ps from 0V to VBR min. High temperature soldering: 260℃/10s at terminals. Symbol  Plastic package has Underwriters Laboratory Flammability 94V-0.  For surface mounted applications in order to optimize board space ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Storage temperature range Operating junction temperature range Steady state power dissipation at TL=75℃ Peak pulse power dissipation on 10/1000μs waveform Maximum Instantaneous Forward Voltage at 100A for Unidirectional 1/5 Symbol Value Unit Tstg -55 to +150 ℃ Tj -55 to +150 ℃ PM(AV) 10 W PPP 5000 W VF 5.0 V 5.0SMDJ Series Transient Voltage Suppressors 5.0SMDJxxA(CA) ROHS ELECTRICAL CHARACTERISTICS (TA=25℃) IT VC@IPP IPP① max(V) mA max(V) A 12.20 13.50 10 18.2 275.0 800 13.30 14.70 10 19.9 252.0 13 500 14.40 15.90 10 21.5 233.0 5.0SMDJ14CA 14 200 15.60 17.20 10 23.2 216.0 5.0SMDJ15A 5.0SMDJ15CA 15 100 16.70 18.50 1 24.4 205.0 5.0SMDJ16A 5.0SMDJ16CA 16 50 17.80 19.70 1 26.0 193.0 5.0SMDJ17A 5.0SMDJ17CA 17 20 18.90 20.90 1 27.6 181.0 5.0SMDJ18A 5.0SMDJ18CA 18 10 20.00 22.10 1 29.2 172.0 5.0SMDJ20A 5.0SMDJ20CA 20 5 22.20 24.50 1 32.4 155.0 5.0SMDJ22A 5.0SMDJ22CA 22 1 24.40 26.90 1 35.5 141.0 5.0SMDJ24A 5.0SMDJ24CA 24 1 26.70 29.50 1 38.9 129.0 5.0SMDJ26A 5.0SMDJ26CA 26 1 28.90 31.90 1 42.1 119.0 5.0SMDJ28A 5.0SMDJ28CA 28 1 31.10 34.40 1 45.4 110.0 5.0SMDJ30A 5.0SMDJ30CA 30 1 33.30 36.80 1 48.4 103.0 5.0SMDJ33A 5.0SMDJ33CA 33 1 36.70 40.60 1 53.3 93.9 5.0SMDJ36A 5.0SMDJ36CA 36 1 40.00 44.20 1 58.1 86.1 5.0SMDJ40A 5.0SMDJ40CA 40 1 44.40 49.10 1 64.5 77.6 5.0SMDJ43A 5.0SMDJ43CA 43 1 47.80 52.80 1 69.4 72.1 5.0SMDJ45A 5.0SMDJ45CA 45 1 50.00 55.30 1 72.7 68.8 5.0SMDJ48A 5.0SMDJ48CA 48 1 53.30 58.90 1 77.4 64.7 5.0SMDJ51A 5.0SMDJ51CA 51 1 56.70 62.70 1 82.4 60.7 5.0SMDJ54A 5.0SMDJ54CA 54 1 60.00 66.30 1 87.1 57.5 5.0SMDJ58A 5.0SMDJ58CA 58 1 64.40 71.20 1 93.6 53.5 5.0SMDJ60A 5.0SMDJ60CA 60 1 66.70 73.70 1 96.8 51.7 5.0SMDJ64A 5.0SMDJ64CA 64 1 71.10 78.60 1 103.0 48.6 5.0SMDJ70A 5.0SMDJ70CA 70 1 77.80 86.00 1 113.0 44.3 5.0SMDJ75A 5.0SMDJ75CA 75 1 83.30 92.10 1 121.0 41.4 5.0SMDJ78A 5.0SMDJ78CA 78 1 86.70 95.80 1 126.0 39.7 5.0SMDJ85A 5.0SMDJ85CA 85 1 94.40 104.0 1 137.0 36.5 5.0SMDJ90A 5.0SMDJ90CA 90 1 100.0 111.0 1 146.0 34.3 Part Number VR IR@VR Bi-Polar V μA min(V) 5.0SMDJ11A 5.0SMDJ11CA 11 800 5.0SMDJ12A 5.0SMDJ12CA 12 5.0SMDJ13A 5.0SMDJ13CA 5.0SMDJ14A Uni-Polar 2/5 VBR@IT 5.0SMDJ Series Transient Voltage Suppressors 5.0SMDJxxA(CA) ROHS ELECTRICAL CHARACTERISTICS (TA=25℃, continued) Part Number Uni-Polar VR Bi-Polar IR@VR V μA VBR@IT min(V) max(V) IT VC@IPP IPP① mA max(V) A 5.0SMDJ100A 5.0SMDJ100CA 100 1 111.0 123.0 1 162.0 30.9 5.0SMDJ110A 5.0SMDJ110CA 110 1 122.0 135.0 1 177.0 28.3 5.0SMDJ120A 5.0SMDJ120CA 120 1 133.0 147.0 1 193.0 26.0 5.0SMDJ130A 5.0SMDJ130CA 130 1 144.0 159.0 1 209.0 24.0 5.0SMDJ150A 5.0SMDJ150CA 150 1 167.0 185.0 1 243.0 20.6 5.0SMDJ160A 5.0SMDJ160CA 160 1 178.0 197.0 1 259.0 19.3 5.0SMDJ170A 5.0SMDJ170CA 170 1 189.0 209.0 1 275.0 18.2 ① Surge waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR: Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR: Reverse Leakage Current ORDERING INFORMATION RATINGS AND V-I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) FIG.2:V- I curve characteristics (Bi-directional) IPP VC VBR VR V VF IPP 3/5 VC VBR VR IT IR V IR IT IPP VR VBR VC 5.0SMDJ Series Transient Voltage Suppressors 5.0SMDJxxA(CA) FIG.4: Pulse derating curve FIG.3: Pulse waveform PPP derating in percentage(%) 100 IPPM(%IRSM) 150 tr = rise time to peak value td = decay time to half value tr=10μs 100 ROHS 80 Peak value 60 Half value 40 50 20 td t(ms) 0 0 1.0 2.0 3.0 4.0 0 0 TA(℃) 25 50 75 100 125 150 175 SOLDERING PARAMETERS Pre Heat Pb-Free assembly (see FIG.5) -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. tp TP Critical Zone TL to TP Ramp-up TL tL TS(max) Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Reflow Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ 4/5 FIG.5: Reflow condition Temperature Reflow Condition Ramp-down Preheat TS(min) ts 25 time to peak temperatue (t 25℃ to peak) Time 5.0SMDJ Series Transient Voltage Suppressors 5.0SMDJxxA(CA) ROHS PACKAGE MECHANICAL DATA A Dimensions C Ref. H F G D E L J K Millimeters Min. Max. Min. Max. A 6.60 7.11 0.260 0.280 B 5.59 6.20 0.220 0.244 C 2.75 3.20 0.108 0.126 D 0.76 1.52 0.030 0.060 E 7.74 8.13 0.305 0.320 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.15 2.62 0.085 0.103 J 8.12 5/5 L 0.320 4.69 K DO-214AB (SMC) Inches 3.07 0.185 0.121
5.0SMDJ33CA 价格&库存
很抱歉,暂时无法提供与“5.0SMDJ33CA”相匹配的价格&库存,您可以联系我们找货
5.0SMDJ33CA
    • 1+2.03500
    • 100+1.62800
    • 750+1.45200
    • 1500+1.37500
    • 3000+1.30900
    库存:4722
