BSDFN2C031U
BSDFN2C031U
    BORN(伯恩半导体)
    DFN1006-2
    骤回料 钳位电压低 DFN1006 VRWM=3.3V ESD接触±8KV 空气±15KV 信号口等
BSDFN2C031U 数据手册
BSDFN2C031U ESD Protection Diode »Features ■ 50Watts peak pulse power (tp = 8/20μs) ■ Bidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ IEC 61000-4-2 ±8kV contact ±15kV air ■ IEC 61000-4-4 (EFT) 40A (5/50ns) ■ IEC 61000-4-5 (Lightning) 7A (8/20μs) »Applications »Mechanical Data ■ Cell Phone Handsets and Accessories ■ DFN1006 package ■ Microprocessor based equipment Personal Digital Assistants (PDA’s) ■ Molding compound flammability rating: UL 94V-0 ■ ■ Packaging: Tape and Reel ■ Notebooks, Desktops, and Servers ■ RoHS/WEEE Compliant ■ Portable Instrumentation »Schematic & PIN Configuration DFN1006 Revision 2018 www.born-tw.com 1/4 BSDFN2C031U »Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 50 Watts Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 7 A VESD 15 8 kV Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 125 ℃ Storage Temperature Tstg -55 to + 125 ℃ ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) »Electrical Characteristics Parameter Symbol Reverse Stand-Off Voltage VRWM Holding Voltage VH Holding Current IH Conditions Min Typical 2.0 IT=IH Max Units 3.3 V 3.2 V 15 Reverse Leakage Current IR VRWM=3.3V,T=25℃ Clamping Voltage VC IPP=7A,tp=8/20μs Trigger Voltage VT Junction Capacitance Cj mA 6.2 8 500 nA 7.5 V 16 V 0.65 VR = 0V, f = 1MHz pF »Electrical Parameters (TA = 25°C unless otherwise noted) Symbol IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VT IT IPP Parameter Working Peak Reverse Voltage VT VRWM Maximum Reverse Leakage Current @ VRWM VH IR VH VC Trigger voltage VRWM VT Test Current VH Holding voltage IH Holding Current IPP Note:. 8/20μs pulsewaveform Revision 2018 www.born-tw.com 2/4 BSDFN2C031U »Typical Characteristics Figure 2: Power Derating Curve 110 10 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) Figure 1: Peak Pulse Power vs. Pulse Time 1 s waveform 50w 8/20µ 0.1 100 90 80 70 60 50 40 30 20 10 0 0.01 0.1 1 10 100 1,000 0 80 70 e-1 50 40 30 td=Ipp/2 20 0 6 5 Test Waveform Paramters tr=8µs td=20µs 4 3 2 0 5 10 15 20 25 30 0 Time (µs) Revision 2018 150 7 1 10 0 125 8 Clamping Voltage–VC (V) 90 Ipp 100 9 Waveform Paramters tr=8µs td=20µs 100 Percent 75 Figure 4: Clamping Voltage vs.Ipp 110 60 50 Ambient Temperature - TA (℃) td – Pulse Duration - µs Figure3: Pulse Waveform 25 2 4 6 8 10 12 Peak Pulse Current–IPP (A) www.born-tw.com 3/4 BSDFN2C031U »Outline Drawing – DFN1006 »Marking »Ordering information Order code BSDFN2C031U Revision 2018 Package DFN1006 Base qty 10k www.born-tw.com Delivery mode Tape and reel 4/4
BSDFN2C031U 价格&库存
很抱歉,暂时无法提供与“BSDFN2C031U”相匹配的价格&库存,您可以联系我们找货
BSDFN2C031U
  • 10+0.34712
  • 100+0.27972
  • 300+0.24603
  • 1000+0.22076
  • 5000+0.17518
  • 10000+0.16503
库存:14160
BSDFN2C031U
  • 1+0.30712
  • 500+0.20372
  • 5000+0.17842
  • 10000+0.16280
库存:8990
