ES1A-ES1J SERIES
RECTIFIERS
SMA FAST SURFACE MOUNT RECTIFIERS
ROHS
SMA
FEATURES
● Super fast switching time for high efficiency
●Low forward voltage drop and
high current capability
.062(1.60)
.055(1.40)
●Low reverse leakage current
.114(2.90)
.098(2.50)
●Plastic material has UL flammability
classification 94V-0
.181(4.60)
.157(4.00)
.012(.305)
.006(.152)
MECHANICAL DATA
.103(2.62)
.079(2.00)
●Case: Molded Plastic
●Polarity: lndicated by cathode band
●Weight: 0.002 ounces,0.064 grams
.060(1.52)
.030(0.76)
●Mounting position: Any
.008(.203)
.002(.051)
.208(5.28)
.188(4.80)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating at 25℃ ambient temperature unless otherwise specified.
Single phase, half wave ,60Hz, resistive or inductive load.
For capacitive load, derate current by 20%
CHARACTERISTICS
SYMBOL
ES1A
ES1B
ES1D
ES1G
ES1J
UNIT
Maximum Recurrent Peak Reverse Voltage
VRRM
50
100
200
400
600
V
Maximum RMS Voltage
VRMS
35
70
140
280
420
V
VDC
50
100
200
400
600
V
Maximum DC Blocking Voltage
Maximum Average Forward
Rectified Current
@TA=55 ℃
I(AV)
1.0
A
IFSM
30
A
Peak Forward Surage Current
8.3ms Single Half Sine-Wave
Super Imposed on Rated Load(JEDEC Method)
Peak Forward Voltage at 1.0A DC
0.95
VF
Maximum DC Reverse Current
@TJ=25℃
at Rated DC Blocking Voltage
@TJ=100℃
Maximum Reverse Recovery Time(Note 1)
Tyical Junction Capacitance (Note2)
Tyical Thermal Resistance (Note3)
Operating Temperature Range
Storage Temperature Range
1.25
1.70
5.0
IR
μA
100
35
TRR
30
CJ
nS
25
pF
RθJA
40
℃/W
TJ
-55 to +150
TSTG
-55 to +150
NOTES: 1.Measured with IF=0.5A, IR=1A, IRR=0.25A
2.Measured at 1.0 MHz and applied reverse voltage of 4.0V DC
3.Thermal resistance junction of ambient.
Rev 8: Nov 2014
V
www.born-tw.com
112
Page 1 of 2
ES1A-ES1J SERIES
RECTIFIERS
FIG. 1 – FORWARD CURRENT DERATING CURVE
FIG. 2 – MAXIMUM NON-REPETITIVE SURGE CURRENT
40
0.8
0.6
0.4
SINGLE PHASE HALF WAVE 60Hz
RESISTIVE OR INDUCTIVE LOAD
50
75
100
125
150
175
PEAK FORWARD SURGE CURRENT
AMPERES
AVERAGE FORWARD CURRENT
AMPERES
1.0
0.2
30
PULSE WIDTH 8.3ms
SINGLE HALF-SINE-WAVE
(JEDEC METHOD)
2
AMBIENT TEMPERATURE (℃)
5
10
100
NUMBER OF CYCLES AT 60Hz
FIG.3 – TYPICAL JUNCTION CAPACITANCE
FIG.4-TYPICAL FORWARD CHARACTERISTICS
100
INSTANTANEOUS FORWARD CURRENT,
(A)
100
ES1A - ES1D
CAPACITANCE (pF)
ROHS
ES1G-ES1J
10
T J = 25°C f = 1 MHz
ES1A -ES1D
10
T J = 25°C
PULSE WIDTH 300us
ES1G
1.0
ES1J
0.1
1
1
4
10
0.4
0.6
0.8
1.0
1.2
1.4
1.6
INSTANTANEOUS FORWARD VOLTAGE ,VOLTS
REVERSE VOLTAGE ,VOLTS
Rev 8: Nov 2014
0.2
www.born-tw.com
112
Page 2 of 2
1.8
很抱歉,暂时无法提供与“ES1D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.11362
- 500+0.08856
- 1500+0.07463
- 5000+0.06869
- 25000+0.06146
- 50000+0.05746
- 国内价格
- 1+0.29700
- 500+0.09922
- 2500+0.06611
- 5000+0.05423
