BSD3A081V
BSD3A081V
    BORN(伯恩半导体)
    SOD-323
    SOD-323 VRWM=8V Unipolar ESD接触±8KV 空气±15KV 信号口/IO口等
BSD3A081V 数据手册
BSD3A081V ESD Protection Diode »Features ■ 230Watts peak pulse power (tp = 8/20μs) ■ Unidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ IEC 61000-4-2 ±30kV contact ±30kV air ■ IEC 61000-4-4 (EFT) 40A (5/50ns) ■ IEC 61000-4-5 (Lightning) 15A(8/20μs) »Applications »Mechanical Data ■ Security ■ SOD-323 package ■ Power Line ■ Molding compound flammability rating: UL94V-0 ■ Power management ■ Packaging: Tape and Reel ■ RoHS/WEEE Compliant »Schematic & PIN Configuration SOD-323 Revision 2018 www.born-tw.com 1/4 BSD3A081V »Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs) PPP 230 Watts Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 15 A VESD 30 30 kV Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 150 ℃ Storage Temperature Tstg -55 to + 150 ℃ ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) »Electrical Characteristics Parameter Symbol Reverse Stand-Off Voltage Reverse Breakdown Voltage Conditions Min Typical VRWM VBR IT=1mA Reverse Leakage Current IR VRWM=8.0V,T=25℃ Clamping Voltage VC IPP=15A,tp=8/20μs 15 Junction Capacitance Cj VR = 0V, f = 1MHz 90 Max Units 8.0 V 9.0 V 1 uA 20 V pF »Electrical Parameters (TA = 25°C unless otherwise noted) Symbol IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT I Parameter IF Working Peak Reverse Voltage Maximum Reverse Leakage Current @ V RWM V C V BR V RWM Breakdown Voltage @ IT IR V F IT V Test Current IPP Note:. 8/20μs pulsewaveform. Revision 2018 www.born-tw.com 2/4 BSD3A081V »Typical Characteristics Figure 2: Power Derating Curve 10k 110 Percent of Rated Power for Ipp P pp – Peak Pulse Power - Ppp(W) Figure 1: Peak Pulse Power vs. Pulse Time 230w8/20μs waveform 1000 100 10 0.1 1 10 100 100 90 80 70 60 50 40 30 20 10 0 1,000 0 25 td – Pulse Duration - µs Figure3: Pulse Waveform Percent Ipp 80 e-1 50 40 td=Ipp/2 20 125 150 Test Waveform Paramters tr=8µs td=20µs 40 Clamping Voltage–V C (V) 90 30 100 45 Waveform Paramters tr=8µs td=20µs 100 60 75 Figure 4: Clamping Voltage vs.Ipp 110 70 50 Ambient Temperature - TA (℃) 10 35 30 25 20 15 10 5 0 0 5 Revision 2018 10 15 Time (µs) 20 25 30 0 5 10 15 20 25 Peak Pulse Current–IPP (A) www.born-tw.com 3/4 BSD3A081V »Outline Drawing – SOD323 C A DIMENSIONS SYMBOL E B 1 2 MILLIMETER A MIN 1.600 MAX 1.800 MIN 0.063 MAX 0.071 B 0.250 0.350 0.010 0.014 C 2.500 2.700 0.098 D D H L 0.106 0.039 1.000 E 1.200 1.400 0.047 0.055 F 0.080 0.150 0.003 0.006 L F INCHES 0.475 REF 0.019REF L1 0.250 0.400 0.010 0.016 H 0.000 0.100 0.000 0.004 L1 »Marking 1 08W Pin Style: 1. Cathode 2 2. Anode »Ordering information Order code Package Base qty Delivery mode BSD3A081V SOD323 3000 Tape and reel Revision 2018 www.born-tw.com 4/4
BSD3A081V 价格&库存
很抱歉,暂时无法提供与“BSD3A081V”相匹配的价格&库存,您可以联系我们找货
BSD3A081V
  • 5+0.21168
  • 50+0.16814
  • 150+0.14637
  • 500+0.13004
  • 3000+0.10274
  • 6000+0.09617
库存:127
