BON-102A
BON-102A
    OTHER
BON-102A 数据手册
Switzerland Bonpen Bonpens by Bonkote™ are refillable flux pens, that enables fine and accurate flux application on your work area. Available in 6 distinct styles, for different applications. You can also use a single cartridge, and simply buy the various replacement tips. Also available the Trial kit (BON-102A) containing 6 different Bonpen types. Features Excellent for fine and accurate application of flux No flux evaporation - flux density can be kept constant Flux can be refilled - economical design Replacement of both cartridge and pen tips is available (5pcs of each are packed) Nothing is filled in the cargtridge when shipping General Specification Dimension Grip O.D.: 12.50mm Total length 187mm (including Cap) Weight (empty) Approx. 9.0g Capacity 8 ml Component Polypropylene(PP) / Polyethylene(PE) / Nylon ESD SAFE Applicable solvents Flux / Alcohole / Fluoric lubricant / Anti-flux migration material 14.0 mm ø 4.3 mm BON-102 BR-102 Bonpen; Brush-type, thin Cap & Brush; Brush-type, thin 9.5 mm ø 4.0 mm BON-102B BR-102B Bonpen; Felt-type, thin Cap & Brush; Felt-type, thin www.ideal-tek.com Switzerland 14.0 mm ø 6.6 mm BON-102D BR-102D Bonpen; Brush-type, flat Cap & Brush; Brush-type, flat 12.0 mm ø 4.0 mm BON-102F BR-102F Bonpen; Felt-type, flat Cap & Brush; Felt-type, flat 12.5 mm ø 4.5 mm BON-102K BR-102K Bonpen; Felt-type, knife Cap & Brush; Felt-type, knife 10.0 mm ø 2.5 mm BON-102S BR-102S Bonpen; Brush-type, ultrafine Cap & Brush; Brush-type, ultrafine 18.0 mm ø 5.2 mm BON-102T BR-102T Bonpen; Brush-type, thick Cap & Brush; Brush-type, thick www.ideal-tek.com Switzerland CA-102 BON-102A Cartridge for Bonpen Bonpen KIT contains 6 different types www.ideal-tek.com
BON-102A 价格&库存
很抱歉,暂时无法提供与“BON-102A”相匹配的价格&库存,您可以联系我们找货
