820A0062-03
820A0062-03
    TAMURA
    AC/AC WALL MOUNT ADAPTER 14V 12W
820A0062-03 数据手册
Linear Wall Plug Adapters w w w. t a m u r a c o r p . c o m AC Output with Screw Terminal Connections • Approved to UL1310 & CSA • Operating Temp = 0˚C to +40˚C • Withstand Voltage = 1,500V (input to output) • High Quality Robust Design • Class II Transformer • Inherently Limited Design Rated Output at 100% Load Volts mA Part # Mechanical Dimension Table SERIES PREFIX 820A-03 830A-03 LENGTH(L) MM(INCH) 75 (2.95) 75 (2.95) WIDTH(W) MM (INCH) 63 (2.48) 63 (2.48) HEIGHT(H MM(INCH) 50 (1.97) 50 (1.97 Output Type (AC/DC) 820A0060-03 10 1200 AC 820A0061-03 12 1000 AC 820A0062-03 14 850 AC 820A0063-03 16 750 AC 820A0064-03 18 650 AC 820A0065-03 20 600 AC 820A0066-03 22 550 AC 820A0067-03 24 500 AC 830A0060-03 10 2000 AC 830A0061-03 12 1600 AC 830A0062-03 14 1430 AC 830A0063-03 16 1250 AC 830A0064-03 18 1110 AC 830A0065-03 20 1000 AC 830A0066-03 22 900 AC 830A0067-03 24 830 AC L Wall Plug Adapters W H TA M U R A C O R P O R AT I O N 43352 Business Park Drive. | 95 USA Tel: 800-872-6624 Fax: 909-676-9482 P.O. Box 892230 Temecula, CA 92589-2230 | www.tamuracorp.com Japan Tel: 81 (0)3 3978-2111 Fax: 81 (0)3 3923-0230 United Kingdom Tel: 44 (0) 1380 731 700 Fax: 44 (0) 1380 731 702 Hong Kong Tel: 852-2389-4321 Fax: 852-2341-9689
820A0062-03 价格&库存
很抱歉,暂时无法提供与“820A0062-03”相匹配的价格&库存,您可以联系我们找货
820A0062-03
