BPT-1115-0-AAA31-01R
    DEFOND(德丰)
    插件
    按动开关 直插 15A 125V
BPT-1115-0-AAA31-01R 数据手册
(X) (X) X X X Spring Knob Lever Terminal board Housing Terminal Movable contact Stationary contact Terminal Cover Knob Housing Lever Yoke 15 X X X X 4 X X X X 15 X X X X 15 X X X 5 15 X X X X 15 X 6 X X X 15 X X X X X X 15 X X 7 15 X 8 X X X X X X X 15 X X X X 9 15 X 10 X X X 11 12 13 Actuator Cover Spring terminal Housing Contact Actuating pin Terminal Accordion-like cap Top Cover Lamp assembly Contact Nest base Nest Spring Housing Contact arm Terminal 15 (X) X X X X X 15 X 16 X X X X 15 (X) X X X X 17 15 (X) 18 X X X X X 15 15 X X X X X 19 15 (X) 20 X X X X X 15 (X) X X X X X 21 CRE • single pole, single / double throw centre-off, momentary on, momentary off • ratings - 16A 125VAC, 8A 250VAC 3/4HP 125/250VAC T105/T65 - 16A 125VAC, 8A 250VAC - 10(4)A 250VAC, T85 with µ or not CRE-XXXX (X) 22 15 X X X X X X XXX CRP • single pole, single throw • ratings - 12A 125VAC, 6A 250VAC T105 - 10(4)A 250VAC T85 CRP-XXXX 15 X X X X X X XXX 23 15 (X) 24 X X X X 15 X X X X 15 X X X X X 25 15 X 26 X X X X 15 X X X X X 27 15 X 28 X X X X 15 X X X X X X X 15 X X X 29 Shaft Cover Spring Housing Terminal Shaft Cover Detent plate Housing Terminal Contact Common Terminal 15 X 32 X 15 X X 33 15 X X X X 15 X 34 X X X 15 X X X X 15 (X) X X X X 35 15 (X) 36 X X X 15 X X 37 Lever Contact arm Terminal Housing Cover Yoke Contact Leaf spring Housing Lever Contact Contact arm Terminal 15 X 40 (X) X X X X 15 X X X X X 41 X 42 X X X X 43 15 X X X X X 15 (X) 44 X X X X X 15 X X X X 15 X X X X 45 Knob Latch wire Housing Lever spring Spring Contact Lever Terminal Base Knob Core pin Contact spring Contact Base Housing Lever Spring Terminal X X X X X 15 X 48 X X X X X 15 (X) X X X X X 49 15 X X X X X 15 X 50 X X X 15 X X X X X 51 15 X 52 X X X X 15 (X) X X X X X 53 15 X X X X X 15 X 54 X X X X X X X X 55 Knob Housing Cover Contact Common plate Return spring Spring lever Slider Stopper Actuator Housing Button Actuator Spring Bottom plate Slider Spring arm Terminal A Contact Terminal B 58 59 60
BPT-1115-0-AAA31-01R 价格&库存
很抱歉,暂时无法提供与“BPT-1115-0-AAA31-01R”相匹配的价格&库存,您可以联系我们找货
