BTHQ96040 AV -COG-FERE-12-I2C
    BATRON
    BATRON - BTHQ96040 AV -COG-FERE-12-I2C - Graphic LCD, 96 x 40, Black on Grey, 3V, I2C, No Font, Tran...
BTHQ96040 AV -COG-FERE-12-I2C 数据手册
Specification BTHQ 96040AV2-FERE-12-12C-COG Doc. No.:COG-BT96040A-05 Version july 2008 Data Modul AG - www.data-modul.com DOCUMENT REVISION HISTORY DOCUMENT REVISION FROM TO A DATE DESCRIPTION CHANGED BY CHECKED BY 2008.07.30 First Release. LINDA ZHU TAN XIAO Based on DI a.) Test Specification: VL-TS-COG-BT96040A-XX REV.C 2008.07.07 b.) VL-QUA-012B REV.X 2008.02.18 According to VL-QUA-012B, for positive mode, LCD size is small because Unit Per Laminate=28 which is more than 6pcs/Laminate. Data Modul AG - www.data-modul.com 2 CONTENTS Page No. 1. GENERAL DESCRIPTION 4 2. MECHANICAL SPECIFICATIONS 4 3. INTERFACE SIGNALS 6 4. 4.1 4.2 ABSOLUTE MAXIMUM RATINGS ELECTRICAL MAXIMUM RATINGS –FOR IC ONLY ENVIRONMENTAL CONDITION 7 7 7 5. 5.1 5.2 5.3 ELECTRICAL SPECIFICATIONS TYPICAL ELECTRICAL CHARACTERISTICS TIMING SPECIFICATIONS COMMAND DESCRIPTION 8 8 9 11 6. LCD SPECIFICATIONS 12 7. LCD COSMETIC CONDITIONS 20 8. REMARK 20 Data Modul AG - www.data-modul.com 3 Specification of LCD Module Type Item No.: COG-BT96040A-05 1. 2. General Description • 96 x 40 dots FSTN B & W Positive Reflective Dot Matrix LCD module. • • • • • Viewing angle: 12 O’clock. Driving scheme: 1/68 duty, 1/9 bias. Driving IC: ‘SITRONIX’ ST7549Ti (COG) LCD controller/driver or equivalent. Logic voltage: 3V. “RoHS” compliance. Mechanical Specifications The mechanical detail is shown in Fig. 1 and summarized in Table 1 below. Table 1 Parameter Outline dimensions Viewing area Active area Display format Dot size Dot spacing Dot pitch Weight: Specifications 46.0(W) x 36.2(H) x 1.98(D) (Excluded pins and EPOXY) 40.00(W) x 23.00(H) 35.217(W) x 18.225(H) 96 x 40 0.352(W) x 0.441(H) 0.015(W) x 0.015(H) 0.367 (W) x 0.456(H) Approx: 6.5 Data Modul AG - www.data-modul.com Unit mm mm mm dots mm mm mm gram 4 Data Modul AG - www.data-modul.com 5 COG-BT96040A VDD 'SITRONIX' ST7549Ti (COG) LCD CONTROLLER/ DRIVER OR EQUIVALENT SDA SCL VSS VLCD 40 96 X 40 DOTS 96 RES Figure 2: Block Diagram 3. Interface signals Table 2 Pin No. 1 Symbol VDD 2 RES 3 4 5 6 SDA SCL VSS VLCD _______ Description Power supply for logic (+3V). Reset Input Pin. _______ When RES is " L ", initialization is executed. Serial input data. Serial clock input. Ground (0V). Power supply for LCD driver. Data Modul AG - www.data-modul.com 6 4. Absolute Maximum Ratings 4.1 Electrical Maximum Ratings-For IC Only Table 3 Parameter Power supply voltage(VDD1) Power supply voltage(VDD2) Power supply voltage(VLCDIN) (VDD standard) Power supply voltage(V1,V2,V3,V4) (VDD standard) Symbol Min. Max. Unit VDD1 -0.5 5 V VDD2 -0.5 5 V VLCDIN 4.5 13 V V1,V2,V3,V4 0.3 VLCDIN V CSB,RESB,A0, Input voltage -0.5 5 V /WR,/RD,D7~D0 Note: The modules may be destroyed if they are used beyond the absolute maximum ratings. All voltages are with respect to VSS unless otherwise noted. Insure that the voltage levels of V1, V2, V3, and V4 are always such that VLCDIN≥V0≥V1≥V2≥V3≥V4≥VSS. 4.2 Environmental Condition Table 4 Operating Storage Item Temperature Temperature (Topr) (Tstg) (Note 1) Min. Max. Min. Max. Ambient Temperature -20°C +70°C -30°C +80°C 90% max. RH for Ta ≤ 40°C Humidity (Note 1)
BTHQ96040 AV -COG-FERE-12-I2C 价格&库存
很抱歉,暂时无法提供与“BTHQ96040 AV -COG-FERE-12-I2C”相匹配的价格&库存,您可以联系我们找货
