BTHQ42005VSS-SMN-LED WHITE
    BATRON
    BATRON - BTHQ42005VSS-SMN-LED WHITE - Alphanumeric LCD, 20 x 4, White on Blue, 5V, Parallel, English...
BTHQ42005VSS-SMN-LED WHITE 数据手册
BATRON Available from Midas Components LTD Telephone Number: +44(0) 1493 602602 Website: www.midascomponents.co.uk Email: sales@midascomponents.co.uk Specification for BTHQ 42005VSS-SMN-LEDwhite Version July 2003 0 Fax 089/ 56017-119 DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 www.data-modul.de VL-FS-BTHQ 42005VSS-06 REV. A (BTHQ 42005VSS-SMN-LEDwhite) JULY/2003 PAGE 2 OF 13 DOCUMENT REVISION HISTORY 1: DOCUMENT DATE DESCRIPTION REVISION FROM TO A 2003.07.04 First Release. (Based on Test Specification: VL-TS-BTHQ 42005VSS-XX, REV. C, 2003.02.10). CHANGED BY HELEN HE DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 CHECKED BY LU MIN YUAN www.data-modul.de VL-FS-BTHQ 42005VSS-06 REV. A (BTHQ 42005VSS-SMN-LEDwhite) JULY/2003 PAGE 3 OF 13 CONTENTS Page No. 1. GENERAL DESCRIPTION 4 2. MECHANICAL SPECIFICATIONS 4 3. BACKLIGHT SPECIFICATION 6 4. INTERFACE 7 5. 5.1 5.2 ABSOLUTE MAXIMUM RATINGS ELECTRICAL MAXIMUM RATINGS (Ta=25°C) ENVIRONMENTAL CONDITION 8 8 8 6. 6.1 6.2 6.3 6.4 ELECTRICAL SPECIFICATIONS TYPICAL ELECTRICAL CHARACTERISTICS TIMING SPECIFICATIONS TIMING DIAGRAM OF VDD AGAINST V0 CHARACTER GENERATOR ROM (KS0066U-10B) 9 9 10 12 13 SIGNALS DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de VL-FS-BTHQ 42005VSS-06 REV. A (BTHQ 42005VSS-SMN-LEDwhite) JULY/2003 PAGE 4 OF 13 Specification of LCD Module Type Model No.: BTHQ 42005VSS-06 1. General Description • • • • • • 2. 20 characters (5 x 8 dots) x 4 lines STN Transmissive Negative Blue Dot Matrix LCD module. Viewing Angle: 6 O’clock direction. Driving duty: 1/16 Duty, 1/5 bias. ‘SAMSUNG’ KS0066UP-10BCC (Die) LCD Controller & Driver or equivalent. ‘SAMSUNG’ KS0065B-PCC (Die) LCD Segment Drivers or equivalent. White LED05 backlight. Mechanical Specifications The mechanical detail is shown in Fig. 1 and summarized in Table 1 below. Table 1 Parameter Outline dimensions Viewing area Active area Display format Character size Character spacing Character pitch Dot size Dot spacing Dot pitch Weight: Specifications 98.0(W) x 60.0(H) x 14.0 MAX.(D) 76.0(W) x 25.2(H) 70.35(W) x 20.74(H) 20 characters x 4 lines 2.90(W) x 4.697(H) (5 x 8 dots) 0.65(W) x 0.65(H) 3.55(W) x 5.347(H) 0.568(W) x 0.574(H) 0.015(W) x 0.015(H) 0.583(W) x 0.589(H) Approx.72.0 DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 Unit mm mm mm mm mm mm mm mm mm grams www.data-modul.de VL-FS-BTHQ 42005VSS-06 REV. A (BTHQ 42005VSS-SMN-LEDwhite) JULY/2003 PAGE 5 OF 13 Figure 1: Module Specification DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de VL-FS-BTHQ 42005VSS-06 REV. A (BTHQ 42005VSS-SMN-LEDwhite) JULY/2003 PAGE 6 OF 13 3. Backlight specification Figure 2: Backlight Specification DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de VL-FS-BTHQ 42005VSS-06 REV. A (BTHQ 42005VSS-SMN-LEDwhite) JULY/2003 PAGE 7 OF 13 4. Interface signals Table 2 Pin No. 1 2 3 4 Symbol VSS VDD V0 RS 5 R/W 6 7 8 9 10 11 12 13 14 15 16 E DB0 DB1 DB2 DB3 DB4 DB5 DB6 DB7 LED(+) LED(-) Description Ground (0V). Power supply for logic (+5V). Power supply for LCD driver. Register Select Input: “High” for Data register (for read and write) “Low” for Instruction register (for write), Busy flag, address counter (for read) Read/Write signal: “High” for Read mode. “Low” for Write mode. Enable . Start signal for data read /write. Data input/output (LSB). Data input/output. Data input/output. Data input/output. Data input/output. Data input/output. Data input/output. Data input/output (MSB). Anode of backlight. Cathode of backlight. DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de VL-FS-BTHQ 42005VSS-06 REV. A (BTHQ 42005VSS-SMN-LEDwhite) JULY/2003 PAGE 8 OF 13 5. Absolute Maximum Ratings 5.1 Electrical Maximum Ratings (Ta = 25 ºC) Table 3 Parameter Power Supply voltage (Logic) Power Supply voltage (LCD drive) Symbol VDD - VSS VLCD =VDD – V0 Vin Min. -0.3 -0.3 Max. +7.0 +15.0 Unit V V Input voltage -0.3 VDD+0.3 V Note: The modules may be destroyed if they are used beyond the absolute maximum ratings. All voltage values are referenced to VSS = 0V. 5.2 Environmental Condition Table 4 Item Ambient Temperature Humidity Vibration (IEC 68-2-6) cells must be mounted on a suitable connector Shock (IEC 68-2-27) Half-sine pulse shape Operating Storage Temperature Temperature (Topr) (Tstg) Min. Max. Min. Max. 0°C +50°C -10°C +60°C 95% max. RH for Ta ≤ 40°C < 95% RH for Ta > 40°C Frequency: 10 ∼ 55 Hz Amplitude: 0.75 mm Duration: 20 cycles in each direction. Pulse duration : 11 ms Peak acceleration: 981 m/s2 = 100g Number of shocks : 3 shocks in 3 mutually perpendicular axes. Remark Dry no condensation 3 directions 3 directions DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de VL-FS-BTHQ 42005VSS-06 REV. A (BTHQ 42005VSS-SMN-LEDwhite) JULY/2003 PAGE 9 OF 13 6. Electrical Specifications 6.1 Typical Electrical Characteristics At Ta = 25 °C, VDD = 5V±5%, VSS=0V. Table 5 Parameter Supply voltage (Logic) Supply voltage (LCD) Input signal voltage (except OSC1) Supply Current (Logic & LCD) Supply Current (LCD) Supply voltage of white LED05 backlight Symbol VDD -VSS Conditions Min. 4.75 Typ. 5.0 Max. 5.25 Unit V VLCD =VDD –V0 VDD=5.0V, Ta=0 °C, Note1. VDD=5.0V, Ta=25°C, Note1. VDD=5.0V,Ta=50 °C, Note1. “High” level “Low” level Character mode, VDD = 5V Checker board mode, VDD = 5V Character mode, VDD = 5V, Note (1) Checker board mode, VDD = 5V, Note (1) Forward current =40mA - 4.80 - V 4.10 4.40 4.70 V - 4.20 - V 2.2 -0.3 - 1.0 VDD 0.6 1.5 V V mA - 1.2 1.8 mA - 0.2 0.3 mA - 0.2 0.3 mA 3.8 4.0 4.2 V VIH1 VIL1 IDD I0 VLED Number of LED dies =1x2=2 Note (1) : There is tolerance in optimum LCD driving voltage during production and it will be within the specified range. DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de VL-FS-BTHQ 42005VSS-06 REV. A (BTHQ 42005VSS-SMN-LEDwhite) JULY/2003 PAGE 10 OF 13 6.2 Timing Specifications At Ta =0 °C To +50 °C, VDD = +5V±5%, VSS = 0V. Refer to Fig. 2, the bus timing diagram for write mode. Table 6 Parameter E Cycle Time E Rise/Fall Time E Pulse Width(high, low) R/W and RS Setup Time R/W and RS Hold Time Data Set-up Time Data Hold Time Symbol Min. Max. Unit tc tR,tF tW tSU1 tH1 tSU2 tH2 500 230 40 10 80 10 20 - ns ns ns ns ns ns ns Max. 20 120 - Unit ns ns ns ns ns ns ns Refer to Fig. 3, the bus timing diagram for read mode. Table 7 Parameter E Cycle Time E Rise/Fall Time E Pulse Width(high, low) R/W and RS Setup Time R/W and RS Hold Time Data Output Delay Time Data Hold Time Symbol tc tR,tF tW tSU tH tD tDH Min. 500 230 40 10 5 DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de VL-FS-BTHQ 42005VSS-06 REV. A (BTHQ 42005VSS-SMN-LEDwhite) JULY/2003 PAGE 11 OF 13 Figure 3 : Write Mode Timing Diagram Figure 4 : Read Mode Timing Diagram DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de VL-FS-BTHQ 42005VSS-06 REV. A (BTHQ 42005VSS-SMN-LEDwhite) JULY/2003 PAGE 12 OF 13 6.3 Timing Diagram of VDD Against V0 Power on sequence shall meet the requirement of Figure 4, the timing diagram of VDD against V0. VDD 95% LOGIC SUPPLY VOLTAGE V0 0V 50ms(typical) 0V LCD SUPPLY VOLTAGE Figure 5: Timing Diagram of VDD Against V0. DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de VL-FS-BTHQ 42005VSS-06 REV. A (BTHQ 42005VSS-SMN-LEDwhite) JULY/2003 PAGE 13 OF 13 6.4 Character Generator ROM (KS0066U-10B) DATA MODUL AG Landsberger Str. 322 80687 München Tel.: 089/ 56017-0 Fax 089/ 56017-119 www.data-modul.de
BTHQ42005VSS-SMN-LED WHITE 价格&库存
很抱歉,暂时无法提供与“BTHQ42005VSS-SMN-LED WHITE”相匹配的价格&库存,您可以联系我们找货
